What year was my Underwood Universal Quiet Tab typewriter made? The serial # is B2600688.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Http://typewriterdatabase.com/underwood.4.typewriter-serial-number-database
Posted on Jun 24, 2016
  • 3594 Answers
SOURCE: Can someone tell me how to install a ribbon in an
Almost all manual typewriters are roughly the same. The ribbon winds to the outside of the spools, put it on the spindles that way, from the spool to the outside of the guide roll, tru the slot in the reversing arm tru the ribbon lift and back the same way to the other spool.
Posted on Apr 07, 2009
  • 3594 Answers
SOURCE: Does anyone know how to thread a ribbon in an old
I'll try as they are all pretty much the same. First type with the ribbon off to determine witch way the ribbon winds either to the outside (most common) or to the inside. Drop the ribbon on, if there is a reversing eyelet in the ribbon be sure it is wrapped onto the spool. The ribbon comes off the spool then there may be a guide or roll for it to pass around, then it will go thruogh the reversing arm then through the ribbon lifter aback the opposite way to the other spool DickyO
Posted on Jun 11, 2009
  • 46 Answers
SOURCE: I'm trying to thread a ribbon through my old
First, type a few letters to find out which direction the spools wind the ribbon (either to the inside or outside). Make sure the spools are installed to wind the ribbon in the correct direction. Second, make sure there is some ribbon wound in the empty spool so the eyelette on the ribbon for automatic reverse does not cause a jam by getting on the carriage side of the reverse guide. Take one spool in each hand, and let just enough slack in the ribbon to insert it behind the ribbon guide next to the platen. Note: the ribbon must go behind the two middle fingers of the guide and in front of the two outward fingers of the guide. If the guide has downward hooks on the outward guides, make sure the ribbon goes under the hooks to prevent the ribbon from bouncing out of the guide during typing. Next, make sure the ribbon passes through the metal guide fingers in front of the ribbon spool holders (these are for the automatic reverse - make sure the metal eyelettes in the ribbon stay on the spool side of the fingers or you will not get a reverse, and the ribbon will jam). Place the spools on the spindles of the spool holders. If the spool is hard to mount, check to see if there is a slot in the ribbon spool to align with a lever or mechanism on the spool holder of spindle. Hope this helps.
Posted on Jun 26, 2009
  • 16 Answers
SOURCE: How do I replace the ribbon on an Underwood
Really? An Underwood typewriter?
First, do you have a replacement ribbon that is not dried out? Does the ribbon come on one spool or two?
If the typewriter already has a ribbon installed, it is a simple matter of noting the path the current ribbon follows, and which way the ribbon winds onto the spools. Then install the new ribbon following exactly the same threading path. If there is not already a ribbon installed, then it is a little more complicated, and it will depend on your spatial relationship visualization skills.
1. Type a few letters on the typewriter, and take note of which way the spools turn.
2. Mount the two new spools containing the new ribbon so that the full spool will supply (unwind), and the empty spool will take-up (wind) the ribbon.
3. Thread the ribbon through all of the guides in the threading path - there are probably about 6-8 guides that the ribbon has to go through. The most important guides are the ones that carry the ribbon in front of the typeface elements as they strike the paper. But equally important are the guides that monitor the tension of the ribbon - they will cause the spool advance mechanism to reverse the ribbon take-up direction when the ribbon reaches the end of travel.
Posted on Sep 22, 2009
  • 19 Answers
SOURCE: Underwood no. 5 typewriter doesn't advance when hit keys
the cord is shaped much like a shoe lace, and these make great replacements, a spare clip can be fashioned out of a paper clip, it's not a precision part. the spring if broken can be replaced with any clock style spring, i bought a wind up kitchen timer at the dollar store (same for the shoe lace) and took the spring from that. for $2.14, got mine working good as new
Posted on Jun 15, 2010
Where abouts on the typewriter do i locate my underwood typewriter serial
according to http://oztypewriter.blogspot.co.uk/2012/05/where-to-find-typewriter-serial-number.html
you can find the serial number on the right hand side, underneath the carriage, and also on the right side of the carriage itself.
Feb 16, 2017 | The Office Equipment & Supplies
Underwood Noiseless Portable Typewriter spacebar guidewire is broken. How do I fix this?
What you have is a broken tab cord You can make one out of 50# test fish line. You will have to wind tension on the take up wheel befor attaching the cord.
DickyO
Apr 29, 2013 | Office Equipment & Supplies
How do you remove carriage on an underwood 565 typewriter
You don't want to do that, use an automotive brake cleaner and spray in the rails while moving the carriage back and forth, that should loosen it up, dis-assembly would unleash the angry mechanical gods upon you, might want to keep the spray away from the motor and belt as they are apparently scarce, otherwise toss it and find an old gray Underwood in good condition and go
Dec 17, 2012 | Underwood 1980s 565 Cr Electric Portable...
Carriage wont move on underwood 565 typewriter
Belt is slipping or broken..When it sits for awhile the belt stretches.
My typewriter carriage doesn't move along as I type.
I just have an underwood 18 typewriter and when I type the carriage doesnt move the margins are in the end and when I press the tab key It is moving but if press the space bar it doesnt move..what should I do?
Sep 18, 2009 | Royal Office Equipment & Supplies
210 people viewed this question
k24674
