Question about Refrigerators
Door will not remain closed
Fridge is approx 6 years old and main door will not stay closed - freezer section has no problems
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You do not have a door gasket problem. Though, you may have a food storage problem, where food is blocking the closure of the door.
When contractors deliver refrigerators and freezers they level them incorrectly. The front of the unit should be pitched slightly up to assist the door in closing and staying closed. You need to raise the leveling screws in the front behind the toe plate.
But, I do not think that is your problem! On the bottom hinge of your door is a rubber grommet. It is like a tongue and grove.
Lay on the floor observe the lower door hinge. While on the floor open and close the door. You should hear a "pop" when the grommet engages to the closed position. If there is no resistance then the grommet is worn and will not lock and keep the door closed.
The grommet is inexpensive. You must take the door off to replace. This is a common problem.
Go into the following website. Put in your unit model number. Your model number is located on the upper side wall in your fresh food section of your refrigerator. Several diagrams will appear and you will see the part number and cost of the lower door grommet.
Posted on Apr 25, 2015
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Check to see if the shelves are not hitting the door shelves. the crisper drawers are in properly and there is not something too large in the door shelves. This is the usually reason for the doors not to stay closed. the other reason could be a bad door gasket.
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
Everything is freezing in the vegetable drawer
For this problem, its indicating towards problem with damper assembly.----------
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is remained open, its not closing.Due to this the cool air from freezer section is running in to fridge section non-stop.Due to this the vegetables and other food in the bottom drawer freezing.--------- In this problem the damper assembly needs to be replaced.---------------
This should help.Thanks.Helpmech.
Oct 31, 2011 | Kenmore Refrigerators
GE Profile refrigerator Model PFS22SISBSS is not cooling, the digital temp control is at 74 when I try to lower it will go to 34 then immediately back to 74. The fan and freezer are both working. A repair...
The problem is damper assembly.In the damper assembly there is a door.This door opens and close with the help of motor.The damper is located between freezer and fridge section.The cold air from freezer section enters to fridge section via this damper door.---------- What repairmen did was proper, but may be that door is not properly got open, it got closed again.Or there is ice got collected between the freezer and freezer section, so this is not letting the cool air to pass from freezer to fridge.----------- ---------- This damper assembly needs to be replaced.Actually this door functions correctly with motor.He open the damper door manually and thought, the cool air will enter the fridge section non stop, but that door is again got closed, by some how.--------- You will have to get the damper assembly part replaced, to get the air flow work properly.------- As the repair man has already ordered the part, otherwise you can get this parts from online sites like www.repairclinic.com or from sears parts direct site.-------- Getting the damper door assembly, replaced will help.Thanks.Helpmech.
Sep 08, 2011 | GE Profile Stainless Bottom-Freezer...
Ro@hotmail.comtemp fridg& frezer will chang 30 to 40 degrees if you open either door it will take a long time for for temp to drop
The compressor is the part which cools the refrigerator.---------- First i will explain the working procedure of your sanyo refrigerator.---------- In the refrigerator, there is a part called compressor, the compressor is the part which cools the freezer section, When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold.--------- So the freezer section cooling/ freezing is must.If freezer is not getting properly cooled or not getting cooled, then fridge section will show the low or no cooling problem.--------------
In your refrigerator, its quite possible that compressor is got weak, nor complete faulty but little bit weak.So when you open and close the fridge or freezer door , the compressor is not that strong to maintain the required temperature.So its working hard to cool inside temperature, but its not doing it quickly as it should.---------.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- ----------------
There is manual reset procedure, sometimes the ice gets frosted all over and blocks the ventilation's for cool air to pass from one section to another, and this also causes problem.So directly going for compressor inspection, before that you can try manual reset procedure and see if that helps.---------
The manual reset procedure is as follows : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take approx 4 to 6 hours for your refrigerator to regain its regular cooling/ freezing .So after 4 to 6 hours check , Is the refrigerator cooling properly or is it taking time or temp is dropping once you open close door. If this problems are not noticed, then reset procedure has helped.------- But if same problem is noticed after reset procedure is followed, then you can get the compressor checked. -------- This should help. Thanks.Helpmech.
Aug 22, 2011 | Sanyo SR-3620 Compact Refrigerator
Frigidaire Side by Side Model: PHS68EJSB0 The temperature is warm on both the freezer and fridge. They are at about 25F and 60F. I have cleaned the condenser coils and they are wet now. Initially, the...
If you have the door alarm continuously beeping you will need to try and hard reset the unit. Turn the circuit breaker for 4-5 minutes and retry the unit. But if still the 5 beeps are coming on, then its problem with control panel board.Its not detecting door closed.------- The control board needs to be inspected.---------- If the doors are not getting closed, that means some cold air is getting out and thts why temp is not getting set.This is one possibility of temperature problem.-------- But if both doors are closed tight and no issue of air getting lost out, then other possibility for this problem is weak compressor.-----------
The compressor just keeps on running.The problem is weak compressor.The refrigerant in the compressor is got low.The compressor is weak.The compressor needs to be replaced.-------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
Aug 21, 2011 | Frigidaire Professional Series PHS68EJSB...
I have a Whirlpool side by side fridge freezer with ice maker and water dispenser which is about 3 years old. Model number I think is WSC5533. Recently I had an interior lamp bulb blow in the fridge which...
HI,
You may have a failing door switch which is causing this problem, if you remove the bulb and close the door, the the red light out? If so, its possible you bulb is fine, you door switch has failed.
I hope this helps
Jul 26, 2011 | Whirlpool Refrigerators
Freezer door was accidentally left open for about one hour. Now the refrigerator and freezer are not cooling.
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper frdige section is fine but freezer not. I have emptied, kept door shut, turned dial up but no...
I have a 2 year old SMEG FAB 32 Fridge/Freezer and the freezer section has suddenly lost temperature. Upper fridge section is fine but freezer not. I have emptied, kept door shut, turned dial up but no success.
Any suggestions on what the problem might be?
Wouldn't expect problems on a SMEG just 2 years old.
You could have a bad thermostat or the refrigerator could be low on Freon, make sure you clean off the exposed coils on the back of the fridge and underneath to free it from dust and dirt – use some type of a blower for underneath and the coils you can vacuum off or wipe off the coils, if not call a service tech to have a look @ the refrigerator – it might have a bad compressor
Apr 14, 2008 | Refrigerators
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
94 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
