Question about GE Washing Machines
GE WSW2780 GAS SPACEMAKER LAUNDRY TUB WILL NO SPIN TUB NOT ATACHED TO ANYTHING CAN IT BE FIX THANKS
    Genius:
  • GE Master
  • 1,585 Answers
Belt???????
Posted on Apr 26, 2015
Maytag317
  • 1136 Answers
SOURCE: GE WSM2480TBAW Spacemaker Laundry, Won't Drain or Spin
you need to remove the slanted panel between the washer and the dryer. There will be 2 screws holding the top of the washer to the cabinet. Locate the screws on the back edge of the washer top along with the 2 brackets that hold the top.
Once the brackets have been removed, the washer top panel will pull toward you and lift off of the cabinet. You will be able to see the lid switch and test it. If you are testing the lid switch for continuity, remamber to activate the switch while testing. If the switch shows an open circuit, replace the switch.
Please let me know if this hhelps you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 23, 2009
  • 574 Answers
SOURCE: Ge Spacemaker Laundry the washer knob popped out
take knob off again and look at the stem where the knob goes does it have a round side and a flat side? if so the knob will have the same profile thats the way it goes on
Posted on Sep 09, 2009
blueextc3221
  • 15935 Answers
SOURCE: Loud scraping sound from bottom
CLICK HERE for the blowup diagram of your unit.
This can be a few issues - you will need to open it up and investigate further.
1. Drum Glider worn. (#1223)
2. Rear Bearing Failed. (#1212)
3. Broken/worn bearing support or shaft etc.
This unit is becoming increasingly harder to find parts due to its age.
Some parts are still available HERE should you take on this daunting task.
Thanks for using FixYA!!
Posted on Dec 31, 2009
mrbobfixit
  • 259 Answers
SOURCE: washer won't spin and empty the water out of the
Shirley, it may be the drain pump is obstructed or possibly the lid switch is broken. If you washed bath mats or rubber backed rugs recently i would go for the pump. If you washed a semi bulky item with a tendency to float I would go for the switch.
Get me a model number and I can help you with dis-assembly if you'd like further help!
Posted on Jun 11, 2010
Testimonial: "Thank you MrBob. I will get the model number over the weekend. :)"
wrightly
  • 140 Answers
SOURCE: "GE Quality Product Spacemaker Laundry"
you could have a broken belt or a frozen pump pulley. the leak has to be addressed to see where it's coming from. it could be from the pump hoses/connections. it could be the main tub seal that's leaking. if you're not handy with tools and test equipment, i suggest you call someone to have a look at it. these are problems that wont be resolved by pushing a button.
and thankyou for using this site. i hope you will continue to use this site.
if you have any further quesions or need further advice, repost another question. be sure to include the model number as well. you gave a good explanation, and that helps. anything you can think of can be of assistance
thanks,
mike
Posted on Jul 07, 2011
What does a blinking green light on a GE stackable washer/dryer mean
Can you provide more information on the year of your stackables and if you have the exact model or serial number, that would be helpful. Thanks.
Jun 02, 2016 | GE Spacemaker Washer and Dryer Electric...
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
The dryer timer stopped working
Is that a temperature senor in the GE spacemaker Laundry dryer? My dryer stops spinning when it gets too hot. After it cools down, it will spin and dry again.
Jan 05, 2013 | GE WSM2700W Unitized Spacemaker Washer and...
Wsm2700dawww dryer will spin laundry still wet
Possible that the speed is of the spin is not enough, check the belt , check for friction to the shaft in the washer.
finally check the drain valve /pump as if there is water logged on without flushing then the valve is clogged or dirty.
Aug 23, 2012 | GE WSM2480DWW Unitized Spacemaker Washer...
thanks,
mike
Jul 07, 2011 | GE Spacemaker Washer and Dryer Electric...
Hello: I have a tenant who is having problems with a GE Spacemaker washer/dryer -Stylemaster # is 622866-A. Here is how she describes the problem: ...it seems as though the washer isn't functioning...
If a spin and drain problem you can pull the front off to see if perhaps a small item (ie. sock or like size item) is stuck between basket and tub or in the drain hose? If it is a wash time problem that would be another direction.
Oct 06, 2010 | GE Spacemaker Washer and Dryer Electric...
Thanks
Vic
Jul 23, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
