My model is in picture below. The speakers only work on max volume and are really scratchy and quiet. Already tryed reset
Samsung ht q-20 quiet at full volume after kids were playing with it. All speakers work just barely audible at max volume. Help!!!
First, check to make sure all wires are plugged into the correct location. If the problem persists try changing the amp or play source that you are using to see if it is a problem with that. Their is sometimes a secondary volume knob on the speakers as well. Hopefully this helps.
Feb 15, 2012 | Samsung Audio Players & Recorders
In turning up volume on eon g2 15 I get crackle sound and then when I mess with switch it finally works. The speaker has been used probably 10 times max. Its not a cord problem..perhaps its the control?
This model has very cheap pots. What really happens is the center pin on the pot breaks leaving the wiper that rides on the carbon track to lift, causing this problem. Use caution as this condition continues the pot will go bad enough to send max volume to the system causing severe damage to the speaker, and maybe the listener. THE GREAT OZ.
Aug 08, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Sound coming from speakers is very quite. must
check your manual for a quiet mode, or reset factory defaults. it might be stuck in "attenuator" mode, where sound is muffled, in case you're answering a phone.
Jan 23, 2010 | Onkyo Tx-sr507 A/V Receiver
Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Aug 04, 2009 | Creative Labs Gigaworks S750 Computer...
Exact same problem; low volume
1st check your PC if audio is fine with headphones or some other speakers , then check your control panel and test sounds compatibility might that you are using wrong speaker setting in the PC.
The below is the company web link to your speaker set , try this too
http://www.polkaudio.com/homeaudio/specs/recent/amr50/
if nothing works please msg me the exact config of ur PC
Aug 02, 2009 | Polk Audio AMR50 Computer Speakers
Headphone out jack is really quiet.
If you're trying to plug the speakers into the headphone connector that will happen.
Headphones are having a high impedance and those loudspeakers a low impedance.
That's why your volume is down. It stresses your audio-amplifier and even blow your finals.
Cheers,
Gerard
Jan 30, 2009 | Televison & Video
Scratchy loud noise when volume dial is turned
It means that the volume pot is dirty.You need to find a way to get some WD-40 into the pot.This usualy requires that you take the access to the inside off and spray right inside the pot.Once you do this move the volume dial from min to max a few times and it should fix it.
Jan 05, 2009 | Altec Lansing VS2221 Computer Speakers
KLH Scratchy Channel
Return the unit to where you purchased it and get a new one.
Sep 19, 2006 | KLH R3100 Receiver
Low volume
> Open Control Panel
> Sound Properties
> Speaker Properties
> Enhancements
Loudness Equalization : on
Equalizer: Choose one (Jazz seems to be loudest setting but sounds of hallway effect so I use powerful for clarity.)
This has more than doubled the level of volume on my acer 5570.
- verc
Jul 16, 2006 | HP Compaq nc6320 Notebook
87 people viewed this question
 Grubhead
Grubhead
