Question about HP Office Equipment & Supplies
The LCD control panel is not functioning even though the hp LaserJet 9500 is working.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 63 Answers
Check for loose contacts some abuse may have loosened display contacts
Posted on Apr 22, 2015
SOURCE: HP Laserjet 9500 HDN
magenta motor is knackered, change it. the clunking noise when printer starts up is the fuser gears meshing together, nothing to worry about. you can change/swap the motor with another motor and see if the startup error message changes from 59.6M(magenta) to 59.C(cyan) or something similar.
Posted on Jul 07, 2008
SOURCE: HP LaserJet 3030 Message: Scanning error cannot connect
I had the same problem on XP and Vista and it turns out that if your don't have the HP Toolbox Running/starting up with pc this caused my problem. Once I lunched it to startup with I am able to scan using the Scan To Button on my Scanner.
-Cepedare
Posted on Dec 20, 2008
efs_perpends
  • 1996 Answers
SOURCE: Hp laserjet 5200tn no display
Is it in sleep mode, or is this some other issue? Scroll down to the resets submenu in this article .
In fact, you might try simply resetting the printer, to try and clear the memory, but if you choose to do so, make sure you have printed a configuration page beforehand so you have all the info needed to set it up again.
Or you could try an online diagnostic session with HP, available here.
Finally, your model home support page with other troubleshooting options here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Sep 04, 2009
  • 2973 Answers
SOURCE: how to print a custom size paper on HP Laserjet
USe the Page Setup in the word processor. It is how the word processor uses the printer that matters. There you will find Custom and you can specify the page size.
Posted on Nov 17, 2009
Testimonial: "Thank you for the advice!"
  • 223 Answers
SOURCE: HP cm1312nfi control-panel display WHITE, it still...
Try doing a hard or reset or nvram:
1. Turn the printer off, disconnect the phone line
2. Hold down the right arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
If the lcd does not display anything contact hp or a local service provider as there is a definite power failure.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Hp laserjet 9500 control panel failure after removing rhe formatter.
Control panel will not light with the formatter removed, it is controlled by the formatter. The only thing you can do with the formatter removed is an engine test.
Apr 28, 2015 | HP Office Equipment & Supplies
Printer ready light never comes on but printer works
I've had this fault myself, If memory serves me right the control panel ( small though it is) we found to be the problem, once replaced the unit the displayed correctly, weirdly all functions of the printer were still available even though we were unable to see the display.
we were able to get config pages etc, and like you say the indicator lights were working- sort of - when they wanted to.
replace the diplay PWB ( its small and reasonably cheap)
Mar 14, 2014 | HP LaserJet 1500L Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  3. Turn on the printer.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
I have a laserjet printer 6mp and i have tried everything and it won't print. even though it says ready int he control panel. please help
I finally got my LaserJet 6P to work with Snow Leopard - after about a year of it not working
Using a generic USB to Parallel Connector
Thought I had tried this before but apparently not
Went into the Printer Driver and instead of selecting the already recognized HP 6P Driver, I selected
Generic PCL Laser Printer
And then checked off the Duplex Box
Works likes a charm
Amazing
Nov 24, 2010 | HP LaserJet 6mp Printer
Sound won't work
I recommend you to try with System Restore to restore the system when everything was OK.
Jun 24, 2009 | HP vs15 15"LCD Flat Panel Monitor
Hp laserjet 2600n
Overview Though it's priced for the home-office budget, the HP Color LaserJet 2600n performs like a printer in a higher cost category. The result: powerful, networkable printing-plus high-impact, professional documents and marketing materials-without breaking the bank. Includes black, cyan, yellow, and magenta print cartridges.
  • Save space with the compact design that you can put anywhere, even on your desk
  • Give your brochures and flyers a competitive edge with HP's image-enhancing ImageREt 2400 color technology
  • Spend less time waiting around for documents; the first page prints in less than 20 seconds, even when the printer has been in Sleep mode
  • Process complex documents that have text, images and graphics with the powerful 264MHz processor and 16MB memory
  • Monitor the print status via the convenient front panel, on-screen LCD display
  • Replenish the paper less frequently, with the optional third tray (250 sheets), which brings the capacity to a total of 500 sheets
  • Stay on top of toner replacement with HP SureSupply, which sends alerts when a cartridge is low and helps you monitor its remaining life
Aug 06, 2008 | Office Equipment & Supplies
Hp LaserJet 950
my printer is clj 9500 error show 66.01.11 please help me
Jul 18, 2008 | HP LaserJet 9500n Printer
Hp 9500hdn has error 8388D4 EIO devise 3 disk not funtional
Try the following steps to reinitialize the HDD:
1 Turn the printer off.
2 Turn the printer on.
3 Press and hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) on the control panel during the
memory count.
4 Hold PAUSE/RESUME (LJ 9500) or START (LJ 9500mfp) down until all three error lights illuminate
steadily.
5 Press (the 5 button on the MFP) until INITIALIZE DISKS appears on the display panel.
6 Press (the 6 button on the MFP).
7 The printer begins initializing the disk (this might take a moment). The control panel displays the
HP event logo and eventually displays READY.
Oct 02, 2007 | HP Color LaserJet 9500HDN Printer
Seeker5211
Seeker5211
