Question about Canon PIXMA Office Equipment & Supplies
I have a paper jamb but cant find how to open it up to get to the back of printer
  • 186 Answers
SOURCE: paper wont load
You can try cleaning the rubber paper feed rollers, located where the paper feed into the printer. Use a rag moist with rubbing alcohol and rub all rollers thoroughly and this should help. Good luck John
Posted on Sep 12, 2007
  • 3 Answers
SOURCE: Paper light says on.. wont reset after jam is cleared
We have a few of the HL-2070N's and I have seen this issue on a few of them. Usually it indicates one of several instances that can be found on Brothers website in the FAQ's about what does the LED indicate area.
The main solution I have found is that depending on where the paper jammed it has affected the drum/toner cartridge assembly somehow or another.
  • I recommend taking the Toner Cartridge out of the drum unit
  • clean the corona wire by moving the blue tab at the front of the drum unit back and forth several times
  • I have even used can air here to get it even better all around the drum unit not just at the corona wire area
  • After make sure all is clean put all back together
This has cleared up most all of my paper jam LED issues and allowed for further printing.
Posted on Apr 03, 2008
SOURCE: paper jamb
you need a copier tech to fix it the fuser unit has to be removed to get jam out i done a lot of them and when some people try as you have to remove the jam they do more damage
Posted on Aug 20, 2008
yooperbud
  • 8637 Answers
SOURCE: Paper not feeding into printer: pulls to the right and jambs
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 29, 2009
  • 296 Answers
SOURCE: Printer starts to grab paper then paper jambs.
Hi, Follow these steps:- 1.Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. 2.Turn off the printer. 3.Remove any paper trays. Inspect them for wrinkled or damaged paper. 4.Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. 5.If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. 6.If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly.The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. 7.If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. 8.Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. 9.If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Thanks! mannu_rakesh
Posted on Sep 09, 2009
My canon MP287 cant print.black when photocopy. The paper also started to jam so it cant print. what will I do?
When there is a paper jamb make sure the whole piece of paper is removed because any tiny pieces of paper that are left behind will cause further paper jambs.
If the paper does not feed through the printer correctly then the rubber rollers are dirty/sticky. Clean the rollers with methylated spirits to stop the paper from sticking to the rollers.
Mar 02, 2013 | Office Equipment & Supplies
Hp 2410 loads paper but stops and says out of paper then paper jamb
Jamb:either of two stones, timbers, etc., forming the sidepieces for the frame of an opening.
Do you mean paper jam?
May 06, 2012 | HP PSC 2410 All-In-One InkJet Printer
I cant get the paper to feed without jaming is ther a way to adjust the feed
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Nov 03, 2011 | Canon Pixma iP2600 Photo InkJet Printer
I have a dell 1720dn printer and the paper is getting stuck at the back of the printer as is coming up out of the printer. It looks like the right side of the printed page is smudged and the paper is also...
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper.The rollers may be dirty or sticky andcauses the paper to not feed straight.
Aug 31, 2011 | Dell 1720dn Laser Printer
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi there have got a cannon pixma 492 had problem really since i brought then recently cant use had for 12mths only use a few times a month paper gets jammed then error 5200 please help i dont know what to...
When you removed the jammed paper, did the paper come out inone piece, if not did all the pieces that were removed make up the entire sheetof paper?
Otherwise there may be still a small piece/s of paper still in the printer,which is causing this error message. When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Jun 09, 2011 | Canon MP490 InkJet Printer
I have a Canon ip 4300. Recently I had a paper jamb (81/2 X 11)
it maybe the sensers which tell the faults has moved out of position or wires loose
Jul 06, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Cant Send or Receiver. Message says Check Printer
Any numerical code displayed with 'check printer'?
Dec 16, 2009 | Canon CFX-L4000 Plain Paper Laser Fax
Hp 5940 - print has paper jamb - Nothing vissible checked & stripped machine of any minute paper particals. disconnected everything for 24 hours. Still maintains it has a paper jamb. Any suggestions...
open the door and remove catridge then check all that sure there is not any poapaper jam issue.
then refix catridge again.
also check in back side if u can there is not any paper jam.
Nov 15, 2008 | Office Equipment & Supplies
old marine
old marine
