Question about Kenwood Tk272g Tk-272g Vhf 150-174
MY kenwood tk 272 g will not play audio while recieving. But i know the speaker works but i only hear it squelch on one channel
Is it possible for my radio to be on mute, or what can i do to recieve audio.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 16 Answers
1 try to check the volume button is not fouled.
2 try to do reset by the manufacturer. (With station stopped ,pressing the two buttons on the side station . Starts station for 2 sec. Releases the side buttons.
3 try to do the firmware update.
Posted on May 10, 2015
Junoon007
  • 1011 Answers
SOURCE: Bad audio quality and few output power (Alcance)
Sir,
This is the problem with the volume control sir. Plz try to change the Volume Control Setting with the help of the support of kenwood(if u have any warranty).
Thanks
g.luck
Posted on Oct 07, 2008
1HiTech
  • 13 Answers
SOURCE: How can I program my Kenwood TK-3101 Radio?
Here is a link to the Kenwood TK3101 Manual which explains how to program this radio.
http://www.hitechwireless.com/pdf/Kenwood/TK3101-manual.pdf
If you need custom programming please contact us.
HiTech Wireless 888.511.5162
Posted on Mar 27, 2009
kditterline
  • 127 Answers
SOURCE: Kenwood TK-361 Manual
http://safemanuals.com/ pleace rate me let me know if this helped.
Posted on Jul 16, 2009
ALLEN CLARKE
  • 47 Answers
SOURCE: Kenwood TK-3200L (K3) radio has (dial) tone only on all channels.
are the batterys charged?
Are the battery contacts cleaned
Posted on Nov 11, 2009
  • 3 Answers
SOURCE: Kenwood TK 3101 2-way radio just beeps when turned
Low batt. Charge for 8 hours and enjoy. It should work
Posted on Feb 20, 2010
Tk3312 will not recieve repeater but audio is fine and channels with out pl are fine
1- Did you choose the right Tone for both RX & TX?
If you have RF present but not the right tone, the green led should turn on.
One of the side key should be a Momentary "Squelch Off" (By default, it programs like that). Use it when you you see the green led turn on.
If you have the wrong Tone Squelch programmed, the side key will let you hear the repeater to confirm the problem.
2- If it didnt do the trick, Look for a RX/TX frequency mismatch. maybe your RX/TX frequencies are wrong for this channel?
3- If you have checked all the above, maybe your radio have a bad ceramic filter and your unit has lost it's sensibility. (Youll hear only people near to you.)
If it's the case, usualy only one half of the filter goes bad. Try swapping the Bandwith type in programmation. If WIDE, try NARROW or the opposite. If you receive in narrow but not in wide, the filter is bad. In more than 50 radios with Sensitivity problem, I only got one with both Wide/Narrow sides of filter bad.
If you have access to a spectrum analyser, on a "RX Test" you should see ~0.2uV. Anything higher than 0.3uV mean you have a serious RX problem.
Sep 06, 2012 | Kenwood Tk-3312 Uhf Handheld Radio
No audio from thd-7e but ok with headset
Hi Stuart,
no audio from the 7e???
You mean no audio from the internal speaker.
I suggest you play around with the volume control a few times to see if this sorts out the issue, if not, then there may be a speaker and or speaker wiring issue. In that case it will need a techie to resolve the problem.
I hope this has answered your query.
Cheers,
Peter
Nov 17, 2011 | Kenwood Protalk XLS TK-3130 (2 Channels)...
I bought additional kenwood tk 2100 radios and they are not sending the signal to my existingones. The fcc numbers and interior tk numbers are the same. How to I get them on the same frequency.
To change the channel frequencies on your TK2100, simply press and hold the PTT switch ("talk button") and Monitor key, then turn the power on. Now press the PTT switch again. The light should change from orange to red and a beep should sound. Next, adjust the channel switch to the channel you wish to program. Now simply press the PTT button to choose between 4 to 8 possible frequencies, depending on your model.
You can find the manual and frequency graphs here: http://www.heritageresale.com/documents/TK2100OwnersManual.pdf
Aug 26, 2011 | Kenwood...
Can not hear anything
Take the cover off, hook the antenna up and turn the unit on. Take a pencil with the eraser end and press around on the circuit board, look for cold solder joints....hope this helps..
May 17, 2010 | Radio Communications
Need manual for kenwood tk-270 transceiver does any one no were i
Field Programming procedure for the Kenwood TK-270 or TK-370 handhelds. Press and hold (light) & (dial) while turning on radio. Hold until (SEL) appears on the display. Pressing (SCN) allows you to program the following 1. Monitor KeyOff = off1 = Monitor momentary2 = Monitor Lock3 = Squelch off momentary 2. Scan KeyOff = offCo = carrier operateTo = Time operate 3. Dial KeyOff = offOn = enable 4. TA keyTA = talkaroundRV = ReverseOff 5. Lo KeyOnOff 6. PriorityNone1 = fixed2 = selected 7. Fixed Priority ChannelTurn selector to channel 8. Look back time ATurn selector to time in seconds 9. Look back time BTurn selector to time in seconds 10. Revert Channel1 = Selected2 = Last Call3 = Last used4 = Selected + Talkback5 = Priority6 = Priority + Talkback 11. Tx Dwell timeTurn selector to time in seconds 12. Drop out delayTurn selector to time in seconds 13. Time out timerTurn selector to time in seconds 14. Tot Pre-alertTurn selector to time in seconds 15. Tot Rekey timeTurn selector to time in seconds 16. Tot reset timeTurn selector to time in seconds
Apr 27, 2009 | Kenwood Radio TK 260 360 270 370 2100 3100...
TK 3100, No communication, codes check out OK
Try one of the side buttons to see if you can hear squelch noise. If so, hold it in then talk on an existing unit. If you can hear it, then the squelch code is wrong, if you still can't hear it, then the frequency is wrong or the unit is defective.
Geno
Jan 16, 2008 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Tk-3100
Hi Tucaraca.
With the radio OFF, switch to CHANNEL 1, press the SQUELCH and the PTT at the same time. Turn ON the power switch while keeping the PTT and SQUELCH until the LED indicator turns RED.
Release the buttons and then press the PTT to CHANGE the FREQUENCY.
Press the PTT once each time until you get to the right frequency you desire. The 8 standard frequencies are as follows: 464.500, 464.5500, 467.7625, 467.8125, 467.8500, 467.8750,467.9000 and 467.9250 MHz. Once you get to the frequency you use, wait a few seconds and listen for the confirmation tone. Each frequency has a different confirmation tone so take note in case you need to program a second radio.
After you hear the confirmation tone, press the SQUELCH to confirm, and then press the SQUELCH again to lock the new frequency. Wait until the LED turns off, then switch off your radio.
Same procedure for CHANNEL 2.
WARNING: You must be legally licensed to use any frequency on any PLMRS such as the TK-3100 series. You must also apply for FREQUENCY COORDINATION and submit FCC form 601. FCC can impose steep fines and imprisonment if they catch anyone using an unlicensed radio on a controlled frequency. Visit FCC.GOV for more information.
Nov 27, 2007 | Kenwood TK-3100K2 (2 Channels) 2-Way Radio
Kenwood Tk272g Tk-272g Vhf 150-174 Logo
191 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jason
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
