Question about Stihl Garden
Where is the model number on a stihl grass trimmer?
  • Stihl Master
  • 1,807 Answers
Depending on age, either on the recoil housing, the engine cover or a sticker on the shaft
Posted on Feb 27, 2016
pippall
  • 1486 Answers
SOURCE: Fuel bubble cut on Stihl trimmer. ,how to start
yes you can temporary fix with puting some mastic sealer over the bubble and leave for a few hours.
Posted on Jul 24, 2009
SOURCE: I have a black and decker electric weed wacker,
replace the entire plug end
Posted on Sep 03, 2009
SOURCE: Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Posted on May 24, 2010
emissionwiz
  • 76132 Answers
SOURCE: Stihl, FS81 trimmer won't start
Well I would go with fuel supply. But did you pull the hose off the carb inlet and see if fuel flows freely from it? You do have a filter screen inside the fuel tank on most makes and it can get plugged, if it is plugged blow compressed air back into the tank to clean it and then dump and flush the tank..
Posted on May 18, 2012
My ryobi 30cc grass cutter model rtp 3000 runs but no power to cut gass
I have seen the flex cable broken between the power head and the cutter head .
Feb 20, 2016 | Stihl FS 85 Weed Eater
My stihl fs400 strimmer starts first time and runs on full throttle then dies a few moments later starts first time and does ame thing again
inside the muffler there is a screen that gets all gummed up, take muffler assy. apart and clean screen, if you have a propane torch, this works well as you burn crud off it becomes ash and wipes or blows off. first link shows how.
press the helpful button and follow me on fixya
Easy Repair on STIHL FS38 Grass Trimmer Clogged Spark Arrester
how to fix stihl trimmer
STIHL GAS TRIMMER REPAIR Stihl FS 40 Grass Trimmer RAN NO OIL IN GAS blown...
How to fix bogging out grass trimmer with clogged spark arrester
Feb 03, 2016 | Stihl Garden
Hi, i am Florencio Valiente looking for grass cutter spare parts please help me to it. STIHL FS55C.. unit cranck shaft assembly, 1 set spiral gear asssembly pls. advice..
New Stihl are sold by the local dealers only per Stihl policy.
I couldn't parts labeled Spiral gear so that maybe just a description problem here.
As for the crankshaft you will need know which version you have. Affects ignition timing.
Feb 08, 2015 | Stihl Garden
What is the gas oil ratio for stihl grass trimer
50:1 100ml of oil in 5L of petrol
Aug 05, 2014 | Stihl Garden
My stihl grass trimmer filter came off gas line in gas tank and I can not retrieve gas line.
Usa a bent coat hanger or wire to hook the fuel line out the top of the filler cap. It will stretch enough for you to push the filter back on.
Apr 12, 2013 | Stihl Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
Stihl carb
Try this link. It has the carby settings on page 26 & 27 of the Stihl FS 45 manual.
http://www.mccoyslawn.com/parts-manuals/Stihl/FS45_46_Manual.pdf
Apr 17, 2009 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
Garden Logo
55 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
