The water temp has reversed it self on my washer /dryer
Even the rinse is hot now after operating correctly for nine months
  • Anonymous Apr 24, 2015
    checked them both, both ends, still doesn't work . Appears the cold doesn't work now
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 40 Answers
Had one do this the other day, I found one of the screens on the washer where you hook the hoses up, has a screen. The screen was clogged only allowing one temp of water pressure to come into the machine correctly. Check the screens on the machine hose hookup.
Posted on Apr 21, 2015
Rinse cycle water temp
You may have a leaking hot water electrovalve, replace it.
Sep 06, 2016 | LG WT4870CW 27" Top Load Washer with 4.5...
Washer temp setting changes by itself
I also have a Whirlpool washer/dryer for my condo, although I don't know the model number of mine. I had the same problem -- after it was precisely a year old, suddenly one day the hot and cold started coming out reversed. I was able to fix mine by more or less temporarily fiddling with the water pressure. What I did was one time, when the rinse cycle was running and the washer was filling up with hot water (grrrr...), I completely shut off the valve supplying hot water. So at that point the water stopped filling into the washer, and then I started tinkering with the cold water, twisting the valve off and on a few times. Then BINGO, suddenly the cold water "kicked in" and for the remainder of the rinse cycle, it filled the washer with cold water. I then turned the hot water valve back on, and since then it has been running correctly.
Jun 05, 2010 | Whirlpool Washing Machines
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Only hot water in washer on all settings
Are the hoses connected to the correct inlet valve on the machine?
If so, then the inlet valve itself may be faulty.
Jun 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is rinsing with hot wateer nomatter what temp. setting is used. I have tried to switch hoses twice now, no difference in rinse but now on correct wash temp.
The MAH5500 series washers have automatic temperature control functions so the washer can control water temp regardless of water heater settings and other factors. I would say either your definition of "hot" is not truly "hot" (over 110 degrees), or the washer's ability to sense has failed (which would also affect fill temp on "wash" fills also). If someone has worked on the washer recently, maybe they reversed the wiring to the water valves inside the machine? ATC temps are as follows: Cold 70-90, warm 90-110, and hot is unregulated at 110 degrees and up. These are normal temp ranges for ATC controlled machines, and are completely safe for fabrics.
Apr 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water temperature control not working
the fill hoses are backwards,,,reverse fill hoses...on the job...also your under warranty ..call for service but you can do it your self..
Jan 17, 2009 | Whirlpool LTE6234D Top Load Stacked...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
The clothes in the washer dryer at the end of the wash are really hot and therefore start to shrink the dryer button is not on and the wash is on a 30 degree heat can you help?
If you have washer set for a warm rinse and the cold water inlet screen is restricted you will get too much hot water. Another thing I have seen is if another near by faucet has a sprayer on it and the sprayer is off, but the hot and cold valves supplying the sprayer are on, the hot water can feed back through that faucet and give you an increased rinse water temp in your washer. Also, make sure hot and cold hoses are attached to the proper side of the inlet valve.
Sep 02, 2008 | Whirlpool Washing Machines
Washing Machines Logo
Top Washing Machines Experts
