Washer is not fully draining - Washing Machines
  • Washing Mach... Master
  • 2,160 Answers
Make and model will help people on this site figure out your issue. also, if you put it on spin only cycle, will it drain out for you? the more specifics you can give, the better your answers will be.
Posted on Apr 21, 2015
Maytag Neptune washer machine won't spin or fully drain
    • 1 Open your home's breaker box and flip the circuit breaker switch to "On." If it is already set to "On," flip it to "Off" and then back to "On" to reset it. A power surge may have interrupted your wash cycle so the drain/spin cycle never actually started.
    • 2 Move the washer away from the wall and straighten the drain hose if it is twisted or turned in a way that makes it difficult for water to flow through it. Replace a kinked hose with a new hose.
    • Sponsored Links
    • 3 Push on the washer door to make sure it is fully closed. The washer will not drain or spin unless the door is closed tight. Press the "Start/Pause" button after you close the door.
    • 4 Wait for about 30 seconds after you press "Start/Pause." The washer will not operate until it has been able to fully lock the door and restart the drain process.
    • 5 Run the clothes through a complete cycle again, making sure you use cold water if there are a lot of suds in the washer. Too much soap in the washer can make it hard to drain. Use high-efficiency or low-sudsing detergents on subsequent uses.
Feb 15, 2013 | Washing Machines
LG WM210HW doesn't fully drain
Pull the drain boot that runs from the tub to the pump and check it for blockage. Post the results back to me.
Feb 03, 2013 | Washing Machines
LG WM2277H front load washer, how do I fully drain it so it can be stored in a Pod in the winter and moved to my new house?
It's a bit late, as I guess you have moved by now!
The best way to drain fully is to remove the outlet hose and let the machine lean backwards against an outside wall so that all water drains out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 11, 2011 | LG WM2277H Front Load Washer
What does the IE error code mean? The washer wont drain.
The IE fault code indicates that your washer is not filling properly with water This error code is displayed if the washer is not fully drained within 10 minutes. I will give you troubleshooting tips for both the fill problem and the drain problem.
To troubleshoot a drain problem, follow these steps:
  • Follow the steps on page 17 of your owner's manual to clean the drain pump filter. If you do not have your owner's manual, you can access it on our Manage My Home website.
  • Check your drain hose for kinks or clogs.
  • Make sure that the drain hose is properly installed according to the installation instructions for your washer.
Here are some troubleshooting steps for the filling problem:
  • Make sure that the water valves behind your washer are fully open.
  • Check the filter screens on the inlet valves where your fill hoses connect to the back of the washer. If debris is clogging the screens, remove the screens and thoroughly clean them. Flush the inlet openings thoroughly with water to prevent debris from entering the washer and corrupting the inlet water valves.
  • A drain installation problem can cause siphoning of washer fill water. Make sure that the drain hose is properly installed per the installation guidelines for your washer.
Jan 13, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Doesn't drain fully. Have replaced the pump. House drain is clear. Will not fully drain on all three different cycles.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 27, 2010 | Maytag Legacy MAV208DAWW Top Load Washer
Water seems to be coming from underneath
Check that your drain hose is fully inserted into the wall/floor drain. then run an empty load with just water and watch it during the drain cycle to see if either the drain is backing up or if it's not fully connected at the back of the washer. if the drain is backing up you can try a drain sn ake available at most hardware stores and that will most likely clear it. If it's leaking at the connection at the back of the washer try to push it in fully or replace the hose altogether. It's not the water inlets because they always have pressure on them and would leak constantly. or you could have a cracked basket in which case you will be better to buy a new machine. cracked baskets don't happen very often though. And once in a blue moon it could be an off balance issue where its actually splashing out. Either way you need to spend some quality time with your washer and see why it's crying =]
May 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't fully drain.
If this washer has a self cleaning filter(cone shaped) it's probably plugged. Also could be the pump or the belt. Good luck..
Mar 17, 2010 | Whirlpool Washing Machines
Doesn't fully spin all the time, sometimes takes 3 attempts to fully drain water
The pump filter is probably clogged if the washer is drained tip it forward till it is lying on its front disconnect the pump hose es and find the filter and clean the stuff out of it.
Mar 12, 2010 | Whirlpool LSQ8000 Top Load Washer
At the end of a cycle, water has accumulated in the bottom of the machine and laundry comes out wet. The machine is in a basement and worked fine, but we decided to clean up the original installation...
Several possible causes of a top load washer not fully draining.
a.) Kinked or obstructed drain hose
b.) New drain outlet is too high and the pump is not powerful enough to fully drain the washer
c.) Failing pump motor, that does not fully drain the washer.
Ask more questions if this info does not help resolve the problem. We can solve this!
Jan 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
GE washer will not go to spin cycle or drain.
Possible lid switch not fully engaged. It will no drain or spin if lid switch is not fully engaged. I would also check the drain line for pluggage.
Oct 22, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
