My sansui sw 120 sub all of a sudden won't power up? What might be the problem please? Thankyou
Sansui 7070 receiver Hum
Your filter capacitors in the power supply section are to blame and they need to be replaced.
Mar 30, 2014 | Sansui 221 Amplifier / Reciever
On my Sansui sw-100 sub, I have 2 speakers connected to the high level output, that dont operate
Yes in order to have audio going to your spare speakers from the sub .You would need to use the hi level inputs comming from the reciever outputs connected to these hi level inputs..The sub will then crossover the audio to their proper outputs..Hope this helps you
Jan 15, 2014 | Audio Players & Recorders
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
Jan 10, 2013 | Sansui 32" TV
Connecting sansui subwoofer to back of tv panasonic
I assume that the sub-woofer is "POWERED TYPE" ..otherwise if it is a PASSIVE type you can not..
So,if it has a power plug for 110 VAC it is "powered type" ..Than you need to find out the AUDIO output 2xRCA plugs of your TV on the back and connect it to the 1x RCA input of Sub...you need a "Y type RCA cable " to make 2x stereo output of TV into the 1x MONO input RCA jacks for sub..Than while listen TV your sub will work too but you need volume adjustment once on the sub controls (if it is a Powered )
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 21, 2011 | Audio Players & Recorders
Sansui sv-2012 tv volume is very low and suddenly increase
Hi srinivas_327,
This is common for some sansui televisions,
All you need to do is to go in the audio settings and turn "ON" the AUTO volume option .
This will help all your channels to have a similar volume , so you won't be surprised by sudden increase in volume.
Hope this helps ...:)
May 10, 2011 | Televison & Video
I require a User manual for a Sano 120 CD Player
Can you give me the exact model number for your audio player.
There is no player available with model number Sansui Sano 120,
Please cross check your model number and leave it as comment and we would solve your issue,
Rnj VINODKUMAR
Oct 16, 2009 | Televison & Video
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Distorted sound coming out of SW channel only
try turnind down the sub from the amp itself it might be putting out more volts than the subs input can handle check your standing wave feature to make sure the trim is not up too high
Jan 13, 2008 | Pioneer SX-315
93 people viewed this question
 Grubhead
Grubhead
