Question about Sony Handycam DCR-DVD108 DVD Camcorder
Getting error E61:10 what do I do can I send it somewhere to be fixed or is it dead
Battery charges but blurry gray screen is all I get
  • Judy edmonds
    Judy edmonds Apr 22, 2015
    Camcorder fully charged never dropped just error message
  • Judy edmonds
    Sony handicam Dvr108
Jvc GR-210 E3 error How do I fix. What does it mean.
Your battery after sitting for six years may give you the impression that it's completely charged, but may go dead as soon as you place it in the camara.if the charge cord can be plugged into the camara, try that, if not get an ohm meter (usually under $5 @harbor freight) , charge your battery and test it.let it sit overnight of the charger and retest it.it should have the same voltage as indicated on the battery or a little higher. If battery has no voltage overnight replace it.
Jan 26, 2015 | JVC Video Cameras
When i turn on the dsi (fully charged) in the top left corner of the top screen, it says 000FE00 (the rest of the screen as well as the touch screen is all black) for about a millisecond and then it turns...
To fix the issue with your Ds getting 0000FE00 just follow the steps below.
1. Start your DSi and wait until the Battery is Empty. (Having an empty Battery lowers the time to boot up. The Ds got two internal flash memorys that are both damaged when you have this error. With the low Battery the resetted one gets loaded while the other can't in the same speed)
2. Remove the Bolts and extract the Battery for around 1.5 hours.Why we did this? All the Electricity needs to be out of the System to make sure it's only getting the Bootup Information from the Chip that got resetted and not from the other, if the other one could send it's information, we would still have the Error.
3. Reinstall your Battery.
4. You need to be fast now: Insert your Flashcard, and start your DSi.Start the Application you used the last time, before the Error appeared and close it legitly. In case off the SuperCard DSTWO SNES Emulator, just press the Exit Button. Other Flashcards like the R4i need to be soft resetted to the flashcard's menu, and need to boot up some game's rom.
5. -Not Necessary but just feels a little more safe- Format your NDSi.
6. Charge your Battery and enjoy playing your NDSi Systems again.
- Usually changing battery will fix this problem for best results follow the steps above.
It work for me and for others hopefully it wil fix your problem. If you have questions please let me know.
May 07, 2011 | Nintendo Dsi Pink Console
Computer plugged in, battery dead, icon says (plugged in, not charging. startup message said not able to determine wattage of incoming power. Computer was dropped on power jack. Replaced power. Powers...
I would take it to somewhere like Batteries Plus. they usually have the battery in stock and the guys at the one near me were very helpful and willing to try it for mine.
Oct 29, 2009 | Dell Inspiron 1000 Notebook
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Camera wont turn on.
try replacing the battery. Check best buy, radioshack or other camera dealers for a battery. Possible deadcell battery. These lith-ion batteries die with no warning. If there is no change, the camera is defective!! hopefully htis helps
Jul 20, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Casio EX-Z75
I had the same problem, the charger kept blinking red when I attempted to charge the battery.
This morning I called casio and they are sending me a out a new battery free of charge, and i don't have to send the old one back. It only took about 10 minutes and they said I should get it in about a week or so. So hopefully this helps everyone who has the same issue as I did.
Dec 23, 2007 | Casio Exilim EX-Z750 Digital Camera
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
71 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
