Question about Danby Freezers
Model duf408we, what are steps involved for replacing thermostat? -Ernie
Why My haier model hcm070la Chest freezer the compressor is not kick on
check thermostat, or relay on one side or back cclose to the compressor area there is a removable lid. removed and look for a thermostat disconect the 2 wires and bridge them then plug the the freezer on if runs replace the temp thermostat for a new one should be freezer thermostat
Nov 07, 2016 | Haier 7 cu. ft. / 198 liter Chest Freezer...
How do I rewire the thermostat on a delfield uc4048h model with an after market thermostat
buy the right one, DANFOSS CONTROL KIT
parts and service manual, http://download.partstown.com/is-bin/intershop.static/WFS/Reedy-PartsTown-Site/-/en_US/manuals/DEL-4SERIES_spm.pdf
replacement parts,http://www.partstown.com/is-bin/INTERSHOP.enfinity/WFS/Reedy-PartsTown-Site/en_US/-/USD/ViewEasyAskSearch-Start?Action=CA_AttributeSelected&Question=Model=%27UC4048%27&CategoryPath=All%20Products%2F%2F%2F%2FAttribSelect%3DManufacturer%3D%27Delfield%27&CatalogCategoryID=
Apr 14, 2015 | Delfield Freezers
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
I need a pictorial wiring diagram for this unit, can you help me?
here is a link the manufacture. There is a some information  and manuals posted there. it looks like you may have a something like what they call a 335-935 http://www.caravell.dk/ Their manul at the bottom of all the languages shows a picture of the compressor and the thermostat device and knob. The cooling unit wiring should involve fans, lights and compressor. Compressor will have cutout safety and temp switches as well as the thermostat. and a capacitor. maybe but not likely a relay. It should all be visible around the compressor. Some starting devices may be on the compressor under the plastic cover where the wires go in. If any of those are bad and you do not have a warranty a hard start kit for $18 will replace all the starting components if that is what you need. Let me know if this gets you what you need or have more questions just ask.
Feb 15, 2011 | Caravell 11.4 cu. ft. / 323 liter Chest...
Frigidaire for Kenmore Freezer-Compressor won't start
Set the thermostat to the coldest and check if there's power to the compresor relay , if yes the relay or the compresor are bad (in this case replace the relay which is the cheaper first step ,but if the compresor still won't start probably is burned out) If there isn't power to the compresor put a jumper wire to the thermostat if the compresor runs replace the thermostat.
Jul 31, 2009 | Freezers
Need newq thermostat
found part locally
Dec 30, 2008 | Freezers
The Fridge stays too cold at -6.
Yes it is the thermostat. Replace it or have it replaced.
Jun 13, 2008 | Freezers
Frozen freezer
send me the model number and ill take you through it step by step hold my rating till we are done you have a defrost problem its going to need either a defrost timer a defrost thermostat or the heating element
Feb 20, 2008 | Freezers
Freezers Logo
88 people viewed this question
Top Danby Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Michael Van Der...
Michael Van Der...
Are you a Danby Freezer Expert? Answer questions, earn points and help others
