Question about Hardware & Accessories
Non-digital lighting timer will not keep the correct current time?
I've been resetting this timer for the past few days because it never keeps up with the current time. It looks like it's going a bit slow, but I'm not sure. All I know is the current time is wrong when I check back a few hours later. I have it set to timer, not outlet. I've also double checked that I'm using the buttons correctly (down for on, up for off). I can hear the spinner/motor inside running. It's been in use daily for about three months so far. Time to get a new one, or can I fix it?
techman
  • 3130 Answers
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Posted on Apr 14, 2006
johnny5846
  • 379 Answers
SOURCE: Setting the day/time stamp on my answering machine
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
follow these steps carefully , see if that helps ya.
Posted on Dec 28, 2008
SOURCE: Casio Wave Captor Watch wont set to correct time.
You need to manually adjust or set the hands to the home position as they are not where the watch thinks they should be. This can happen when you bring your watch close to a strong magnetic field. Look in the manual to do this. Afterwards your watch should set to the correct time.
Posted on May 07, 2009
  • 8 Answers
SOURCE: How to reset 1999 E 320 check engine light
Make sure you are using premium gasoline and have the car scanned (OBD2) most likely you will need to replace O2 sensor.
Posted on Jul 03, 2009
SOURCE: We have a Dynex 19
After cussing at the thing for a while to get its attention,
I thought the problem over and fixed it as follows:
I went into the setup menu and selected the "reset default option. The set went to blue screen. The next step was to rescan the channels. Then in the time setup menu I turned off the automatic time update. So far have not had any more problems.
Posted on Aug 19, 2009
Utilitech wall timer
Utilitec timers do not have replaceable batteries.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Older timer designs have batteries, while more modern timers have internal rechargeable battery that is integral with circuit board, and cannot be replaced. The battery holds memories in event of power outage, but current time must be reset if power is out for extended time.
If you have continual problems with failed timers, then have electrician friend run test on your power for spikes, shortages and surge that will cause timers and other non-hardened electronics to fail frequently. Also check for polarity and grounding issues. Also if you have motors, other electronics and/or fluorescent lights on same circuit, this can cause interference.
Also check load limitations, and load on timer to make sure you are not exceeding the timer rating. For example using timer to control motor when timer is rated for non-inductive incandescent loads.
Reset timer using reset button, and then re-program. Buy another timer at Lowes and return defect in new package for refund.
Buy Intermatic ST01C timer. This timer uses CR2 battery, and timer electronics operate separately from electric line. Rated for any load: motors, cfl bulbs, led, incandescent, etc.
http://waterheatertimer.org/ST01C-program.html
Add a comment
Jul 18, 2013 | Hardware & Accessories
I need to know how to reset the timer
If you reset ST01C timer using reset button, then all programs are lost, plus current time of day.
Generally this timer needs to be reset if error message appears and as last resort for troubleshooting problem. Timer does not need to be reset after battery goes bad, all you do is set current time of day, and then program remain inside timer indefinitely (or until timer is reset of goes bad)
If setting current time of day does not work, you use reset button.
For ez programming steps with illustrations:
How to reset ST01C using reset button:
Push and hold ON-OFF button and then push reset button using toothpick or paperclip.
Release reset button but keep holding ON-OFF button until INIT displays.
Then release ON-OFF and 12:00 should be flashing.
If timer functionality does not restore, then try replacing timer battery.
If functionality will not restore, then timer is bad.
This timer does not need electric current for setting timer, so timer display is not dependent on circuit breaker.
If you have a different timer, then add a comment with in-focus photo of timer for possible identification. Most other timers do not require 2-button reset procedure.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic Inc. ST01C Digital In-Wall...
The timer flashes, "no-op". Refuses to turn
no-op means 'no operation.
The manual says last resort to revive non-working timer is RESET timer.
This action will delete current day setting and all programming
Hold down ON/OFF and use paper clip to push in reset button for 2 seconds.
Release reset button but keep holding ON/OFF button down until INIT flashes on screen
Then release ON/OFF button and 12:00 should display.
At this point, timer can be re-programmed.
Simple step by step shows on following link:
If timer will not accept programs, or operate after RESET, then timer has gone bad.
ST01C comes with 1 year limited warranty.
Most in-wall timers have same limited warranty.
Replacing timer:
-Advantage of ST01C is timer does not need Neutral wire to operate, and wiring can be simple.
-If you are using ST01C for 3-way switching, then easiest thing is to replace with same timer.
-If you are using timer as astronomic dawn-dusk, then replacements include EJ500, Utilitec 0192773, Aube T1034, T1070, T1072, T1073.
-If you are using timer for 7-day operations then there are numerous options:
http://waterheatertimer.org/Programmable.html#Aube
Jan 08, 2011 | Intermatic Inc. ST01C Digital In-Wall...
How do I program a Noma N1506 timer?
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Utilitech self-adjusting wall timer 0192773. I hooked up the timer (4 wires). The automatic modes does not work and will not turn on and off the lights on set times. All it will do is turn lights on and...
I have been testing the 0192773, and other timers, for wire and program difficulties.
Good news: your timer is wired correctly. This timer will not operated lights with incorrect wiring.
programming steps are long, but same as other programmable timers.
The 0192773 is a 7-day or sunrise/sunset timer
1) Most programmable timers will not 'work as expected' if there is a conflict in programming.
They suggest you make a schedule of times before programming
2) One of the things this timer offers are individual days -or- groups of days > for example weekend only -or- weekdays only -or- all days of week -plus- individual days. For me, it was a bit confusing keeping that straight while programming
3) Each Program has ON time and OFF time
So Program1 ON has to be set same days as Program1 OFF
4) The other difficulty was how fast the display shifted back to current time when I was programming. If I looked at the instructions for a moment, my display would change before I could catch up. So it's possible that an ON or OFF time could be missed easily.
5) Finally, if you are using the timer as a sunrise/sunset, you need to enter Sunrise or Sunset with program1 ON and program1 OFF
I think the problem is in your programs:
You can use paperclip and hold in reset button for a few seconds and start over
Or
You can press PROG button and and re-check and re-set each program.
By the way, when setting current time, I noticed the timer let you chose a year up to the year 2099. I thought that was an optimistic outlook for both operator and timer.
Oct 22, 2010 | Intermatic Inc. ST01C Digital In-Wall...
If you keep hitting the program button after making sure no program events are set, it just keeps cycling back through the 1-7 day program event options.
The ST01C programming is long and hard to understand
Intermatic has posted a EZ-version for programming
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/st01c.aspx
First of all, you have to set current date on all brands of programmable timers before programming. On some timers, the wiring has to be correct before the timer will let you program.
If you have the ST01C, push the reset button with a paper clip until time flashes to 12:00, and then start over
When I have a problem with a timer, I go back to the manual and start writing out the instructions.
If you can write the instructions, then they usually make better sense >>> and then you wonder who wrote the manual.
Finally, the ST01C, and most digital timers, come with a 1-year limited warranty >> timers go bad.
Oct 19, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Sprinkler timer not keeping current time of day
Open following link for Intermatic sprinkler-timer parts list
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If yellow dial is not keeping correct time, then clock motor has gone bad.
Replace clock motor.
Feb 28, 2010 | Intermatic R8806P101C -...
I have a holiday living power stake timer, how do i program it?
I have the directions for this item and tried to paste them here, but exceeded the amount of space allowed. Will send in several replies. FIRST:
HOLIDAY LIVING HEAVY DUTY OUTDOOR DIGITAL POWER CENTER
MODEL #LW28080 ITEM #0050024
INSTRUCTIONS:
NOTE: To set up Timer for the first time, plug in the timer for 10 minutes, then insert a sharp pointed object or opened paper clip into the pin hole marked "RESET" to clear all settings.
SET THE CURRENT TIME
1. Press the CLOCK button.
2. Press the DAY button to set the current day of the week.
3. Press the HOUR button to set the current hour. Be sure to take note of AM / PM.
4. Press the MIN button to set the current minute.
5. Press the ENTER button to finish setting the time.
Note: If you do not touch any buttons for 10 seconds, it will automatically save the time.
Continue to Digital Timer Mode or Photocell Timer mode below.
To have your lights turn on and off at specific times throughout the week, choose Digital Timer Mode.
To have your lights turn on every day at dusk and off at dawn or after 1 - 12 hours, choose Photocell Timer Mode.
Nov 21, 2009 | House Brand Hardware & Accessories
Hardware & Accessories Logo
136 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
