Question about Poulan Garden
My poulan pro 17" rear tine tiller stalls wheels and tines when I start to till and starts to smoke. What could it be its brand new?
  • Ashley Carte Apr 21, 2015
    It's 4 stroke and it don't smoke out the exhaust its either transmission or belt. I bought it at rural king already assembled and first day I brought it home it tilled good for a few minutes then stalled on a few small roots and eventually got to where it was just stalling on dirt. I thought if it just stretched the belt or something I would fix it but if it was transmission I would take it back because I've only had it 3 days and didnt purchase warranty.
  • 52 Answers
Please recheck your fuel and oil mixture. Most times too much oil will cause these problems. If you are certain that is not the problem, please check the unpacking and assembly instructions - even if you had someone else assemble the tiller for you. Once in a while things get left where they are supposed to be. If you smoking is happen due to fuel system delivery issues - you may need to adjust the carburetor portion of your tiller if it is available to do so. Most instruction manuals will have a trouble shooting section for common issues and answers on how to fix them. Cheers!!
Sincerely,
MPKramer
Posted on Apr 21, 2015
SOURCE: mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Posted on May 27, 2010
  • 2926 Answers
SOURCE: My Poulan Pro Tiller starts
It may be the drive belt is slipping, depending on the model number of course. What is the model number?
Posted on Jan 31, 2011
  • 3 Answers
SOURCE: i have a craftsman 17" 5.5 rear tine tiller chain
Go to sears.com. at top of page about center of page find parts. put in model #. It will give you a breakdown of the whole tiller.
R.G.S.
Posted on Mar 23, 2011
heatman101
  • 43501 Answers
SOURCE: Own a "Craftsman Rear Tine
Can you move the tines by hand???
They should turn by hand if you try to move them...if not then they are bound up by something...
either a bearing has gone bad, something has wrapped around them, or there is something stuck in there that will not let them turn...check for a rock stuck between one of the tines and the housing around them...
Get the tines moving freely and you will be okay again...
heatman101
Posted on Mar 31, 2011
SOURCE: tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Posted on Apr 16, 2011
Gilson roto tiller model 51082
Something in the wheels drive is jammed preventing them from turning. That is why the turning belt starts to smoke when it is turning but cannot unstick the wheels. Need to unstick them for unit to work.
Apr 01, 2016 | WI Gilson Bycast Club Chair
Engine won't start
-Check spark plug. If it's wet then it's flood. Replace new plug.
-Check spark at spark plug. If no spark then the coil is bad.
-If there is spark then check fuel line. It might be on Closed position
or is clogged.
Good luck
Mai
Aug 16, 2014 | Poulan Pro PRRT850 17 Tine Tiller
Tines on tiller
-Check the locking bolt that hold the tine shaft to the main shaft. Possibly it's broken. If so replace new bolt. you should be good to go again.
Good Luck
mai
May 24, 2014 | Craftsman 17 In. Dual Rear Tine Tiller
Engine surges
sounds like a carb problem if new bring it back to the store
May 05, 2012 | Husqvarna DRT900 960930011 17 Rear Tine...
I have a 17
wheels can be removed by using a needle nose pliers to remove the hair pin clip.
Jan 26, 2012 | Husqvarna 17" 90Torque Rear Tine Tiller
I have 2 poulan pro 900 series tillers and they are fairly new anyway when I engage tines they work fine until they hit dirt. then they stop and have a loud clicking noise. I'm sure that they are more than...
If your tiller is one that has power to the wheels and the tines at the same time ... are the wheels going? If it is one with no power to the wheels, are the belts engaging?
Mar 23, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
I have apoulan pro prrt850 17 inch rear tine tiller. When I took it out of storage, it started great but I could not engage the tines. The lever that moves the transmission into forward, till, or reverse...
If the gearbox has a fill plug, remove and let it air-dry or blow compressed air into it to help dry. Then, get some PB Blaster aerosol penetrant/lubricant from the auto parts store and spray as much as you can ito the box. Let is soak 24 hours or so and THEN come back to it and see if you can get it unfrozen.
Mar 17, 2011 | Poulan Pro PRRT900 17Inch 205cc Briggs...
Troy built horse loses power when I engage tines into the dirt. What do I need to service?
sounds like you are trying to till too deep raise tines up a little with the depth gauge then till the same spot again and see if that helps
Mar 10, 2011 | Troy-Bilt 21AE682L766 Big Red 10 HP...
Sears rear tine rototiller 32-29978 manual
If you find one please let me know as I have the same tiller and no manual.
May 02, 2009 | Craftsman Garden
Garden Logo
123 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
