Question about Viore Televison & Video
Viore plasma the screen is flickering. I can kinda see the menu when I push the menu button but is very difficult. Also sometimes it shuts itself off,or will not shut off when I push the power button
    Top Expert:
  • Viore Master
  • 75,304 Answers
Flickering can be adjusted. To get more details; just Google for the site "Electro help". There is more details about how to rectify this fault. Surf the site with patience.
Posted on Apr 21, 2015
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
IrishDruid
  • 2712 Answers
SOURCE: Randomly shutdown and eo1 error
There are several things that can cause it. You are best to have an expert technician come in and take some test on it in order to determine if it is from vertical blanking failure or something else. It is not easy to fix this yourself, if you have no experience, because there are a lot of parts that have to be removed before you can reach the components. It could be as simple as a loose connector ribbon or a bust capacitor, but it could also be more complicated. Hence, in my honest opinion, better get a qualified technician.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 14, 2008
SOURCE: Viore DLP TV
The lamp is most likely over heating. Check the fan in the lamp assembly compartment. Its located in the rear of the tv... try removing the lamp compartment and replacing the fan.
A quick fix is to put a small 7-10 inch box fan with its back flush to the lamp
compartment's vent - this will draw the heat out.
Posted on Sep 26, 2008
jerryg50
  • 1689 Answers
SOURCE: Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Posted on Jan 02, 2009
SOURCE: Viore 42" plasma tv has
The tv was working fine until this morning, then the picture went out but the sound is still working.
TV is only 3 years old, no real electrical problems
Posted on Feb 02, 2011
I have a viore lcd tv and i dont have the remote the issue is that i cant get to the hdmi with the tv/av button. It just goes to the menu or it shuts off the tv
Don't you hate that, now-daze most all functions are available only with the remote. Here's a link to ebay, selling Viore remotes, find your model....it's the only cure.
http://www.ebay.com/bhp/viore-tv-remote-control
Apr 25, 2017 | Viore Televison & Video
Flashing picture
Sounds like main board fault. Contact any "Experienced" service technician, or, the authorized service center for Viore.
Gopakumar Gopalan Google
Feb 24, 2014 | Toymax Viore 42 in. Plasma TV
Viore pdp42v18ha
There are many reasons for the flickering screen to a PDP. If you wish to get more details about this, check the site lined below. Pull up older posts there, either by its left side bar, or see it in Timslide option. http://electronicshelponline.blogspot.com/. It is difficult to enter all of those here by this window.
Jun 26, 2013 | Televison & Video
Viore 42" plasma has picture but no sound
check first at the sound set up menu might set to off. if the settings is ok and the speaker is also good, the cause is either bad amplifier circuit or sound processor at the main board. at this time you will need a trouble shooting.
Oct 07, 2012 | Toymax Viore 42 in. Plasma TV
Flickers after 5min of use. Perfect sound, turns on fine and excellent picture quality when in blue screen menu mode. Why?
This intermittent problem is very difficult to rectify. Just contact the authorised service center for Hitachi at your town. The work is really a skilled one, that a user cannot do it with ease.
Jul 13, 2012 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Jan 29, 2011 | Toymax Viore 42 in. Plasma TV
My viore 42 in plasma is not projecting image. I
The video IC module seems to be giving problems. Open the back cover and take a peep inside. Look for the module just short of the screen. replace it if need be.
Nov 07, 2009 | Toymax Viore 42 in. Plasma TV
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
Plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Feb 01, 2008 | Akai PDP42Z5TA 42 in. Plasma Television
Televison & Video Logo
57 people viewed this question
Top Viore Televison & Video Experts
Tom Chichester
Brandon Murphy
George Scott
George Scott
Are you a Viore Televison and Video Expert? Answer questions, earn points and help others
