Question about NEC PABX SL1000
Error message 55 poped-up, what is the error?
55.00.00 error message display on the control panel
Error 55 is a major Engine or DC controller issue.
HP LaserJet Enterprise Printers 55 00 0x and 55 0x 06 Errors
Try spares from salvaged printers. Look for "working pull from damaged unit". Of course reconfirm model and spare compatibility.
Printer Works RM1 9371 000 DC Controller As M775 mfp
HP LaserJet DC Controller For M775 Printer RM1 8898 - USD70+shipping
Mar 18, 2016 | HP LaserJet M775DN Laser Multifunction...
Adding new contact error keeps poping up
do you can to tell me some thing about this poping
like waht it's the message that showign for you
Dec 14, 2011 | Yahoo Mail
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
A window popes up and says hotspot not supported
Hi
Iam getting an error as hotspot not supported.. What can be done for that..
Oct 14, 2010 | Skype IM
My phone keeps poping up with the message
Try to reset your phone with the factory setting.
May 11, 2010 | Samsung SGH-t819 Cellular Phone
Error 55
Error 55 (internal communication problem)
  • On the HP 2 series you have to replace both the dc controller and formatter boards. On all other printers it can be several things: DC controller, formatter, main motor
Jan 18, 2009 | HP LaserJet IIIp Printer
Error message hpqSTE08exe
Pls try:
  • Start, run (alternately, Windows Key + R)
  • type "msconfig" minus the quotes;
  • click on Startup tab;
  • un-check any instance of the hpqSTE08.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 01, 2008 | HP Pavilion dv6000z Notebook
CA Error Code - AEG OKO LAVAMAT 86700
c-a error message poped-up.washer stop working.............please help.
Sep 15, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Sony DSC H3 Flash not poping up?
Dear Frac1969,
There are many reasons when flash isn't poping up. Flash selection could be OFF from menu or its setting is Auto. Are you geting any error message in camera when you try to use Flash function?
May 21, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
NEC PABX SL1000 Logo
243 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
