Question about 2007 GMC Canyon - Crew cab, 5 short bed - ProCap Bed Caps
Need wiring diagram for a rear view mirror temperature guage
    Problem Solver:
  • 36 Answers
I hate to keep saying this but you can get it online.
Posted on May 13, 2015
I have power from wiring harness on outside mirrors. No power coming out of connector. need color wiring diagram on 2003 F150
Haynes manuals will have the information they run around $30.00 any auto part store.Good Luck.
Aug 03, 2016 | 2003 Ford F150 Regular Cab
Uplander wiring diagram
Unplug the wire that leads to the morror.
Aug 31, 2014 | 2006 Chevrolet Uplander LS
Rain sensor were is it located
The rain sensor is located at the inside rear view mirror.
Apr 14, 2012 | 2006 Chrysler 300
Need a diagram for installing a drivers side electric power mirror on a 1995 mercury villager van
here's 1996, all I have. Please rate.
Mirror, Power — Outside Rear View NOTE: This procedure applies to both RH and LH power outside rear view mirrors.
Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws and the outside rear view mirror mounting hole cover (17K709) from the front door (20124).
  1. Remove the wire clip.
  1. Disconnect the power outside rear view mirror electrical connector.
  1. Remove the three power outside rear view mirror bolts and the power outside rear view mirror.
Installation
To install, reverse the removal procedure. Tighten the three power outside rear view mirror bolts to 3-4 Nm (27-35 lb-in). Glass, Outside Mirror
Removal and Installation
Refer to the glass replacement procedures in Manual Mirror for power outside rear view mirror glass (17K707) Trim Cover
Removal
  1. Remove the front door trim panel. Refer to Section 01-05 for the removal procedure.
  1. Remove the two outside rear view mirror inside mounting hole cover screws.
    Remove the outside rear view mirror mounting hole cover.
Installation
To install, reverse the removal procedure. Mirror Control
Removal
  1. Use a small flat-blade screwdriver to pry the power outside rear view mirror control switch from the instrument panel (04320).
May 13, 2010 | 1995 Mercury Villager
Electronic compass and temperature gauge quit working
the first thing i would do is check all the fuses
if there all good then youll need a wireing schematic
check for power and ground at the mirror if all checks good replace the rear view mirror good luck
Nov 27, 2009 | 2002 Ford Expedition
2008 Honda Pilot Rear View Mirror Installation
At most auto parts stores, they carry what is called "Rearview mirror adhesive" - It costs about $4 or $5, and comes is a little "blister" package. It is a special two-part adhesive (utilizing a pre-cleaner and a "gluing" agent) that is REQUIRED for installing these mirrors on glass - Super glue will not work for this,... All you will do with superglue is make a mess... - The adhesive isn't terribly hard to use, but it does require a bit of patience, and I'd recommend following the instructions to a "T" for the best results (Temperature, time, etc..). Hope that helps some...
Sep 12, 2009 | Honda Pilot Cars & Trucks
The temperature display on the rear view mirror shows OC
The temperature display on the rear view mirror my 2002 Trailblazer LT is either way incorrect - like obviously too high or too low - but mostly just shows "OC" all the time. Is this an expensive fix? Is this an easy fix that I could do myself? What do I need to replace and how
Jun 30, 2009 | 2002 Chevrolet TrailBlazer
How do I remove the left side mirrer on my 2000 ford explorer?
Mirror — Outside Rear View Removal
NOTE: Do not remove the exterior mirror assembly when repairing an individual part. Individual components can be installed without removing the exterior mirror.
  1. Disconnect the battery ground cable (14301).
  1. Remove the front door trim panel; refer to Section 501-05.
  1. Remove the speaker.
    1. Remove the screws.
    1. Disconnect the electrical connector.
  1. Remove the outside rear view mirror (17682).
    1. Disconnect the power mirror wiring clips.
    1. Remove the outside rear view mirror nuts.
    1. Remove the outside rear view mirror.
      • Feed the power mirror wiring through the opening in the front door (20124).
Installation
  1. NOTE: When the battery (10655) is disconnected and reconnected, some abnormal drive symptoms may occur while the vehicle relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 mi) or more to relearn the strategy.
May 29, 2009 | 2000 Ford Explorer
Replace driver side mirror on 2001 Nissan Quest
SECTION 501-09: Rear View Mirrors 2001 Villager Workshop Manual REMOVAL AND INSTALLATION Mirror —Exterior Rear View Removal
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the upper speaker.
    1. Remove the bolts.
  1. Position the watershield aside.
  1. Remove the exterior rear view mirror access panel.
  1. Disconnect the exterior rear view mirror electrical connectors.
    • Release the wiring harness locator.
  1. Remove the exterior rear view mirror.
    • Remove the bolts.
    • Feed the wiring harness through the door opening.
Mar 31, 2009 | 2001 Nissan Quest
2007 GMC Canyon - Crew cab, 5 short bed - ProCap Bed Caps Logo
79 people viewed this question
Top BAK Vehicle Parts & Accessories Experts
Leighton Hurry
Level 1 Expert
Lawrence Oravetz
Are you a BAK Vehicle Part and Accessory Expert? Answer questions, earn points and help others
