Question about John Deere Garden
I have a john Deere St yellow deck with the Kohler engine my magnets in the flywheel busted can I take them out and still run it till I can afford to buy the parts
  • John Deere Master
  • 1,169 Answers
Although Jay Plesset is wrong about the alternator powering the ignition system you won't be able to run it without the magnets and the alternator due fact the electric PTO will quickly drain your battery as you no longer will providing the charging of the system.
Now there is a pair of magnets that operates the magneto but they cast into the flywheel and I have never had them to come loose or break so I am assuming that you are referring to the ones inside the flywheel.
Posted on Apr 21, 2015
  • 2,826 Answers
It's unlikely that it will run without the magnets. They power the spark.
  • Eugene Rounds Apr 21, 2015
    It is a magneto system so the alternator does NOT power the Spark. The magmets that power the magneto I have never seen them to break loose as they are cast into the flywheel itself.
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
mowerman1857
  • 389 Answers
SOURCE: v-belt route installed on 48" deck of John Deere LA130
http://jdpc.deere.com/pimages/PU00/PU00859________UN28APR08.gif
Copy and paste this in your address bar and it should take you to a picture of how to route the belt
Posted on Sep 18, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
JD gx345 not charging with engine running
Remove flywheel and check the 4 magnets are still glued in place on the inside of the flywheel. If any of the magnets are loose or two are unglued from the flywheel the voltage will only be slightly above 12v
instead of closer to 14 something volts. The magnets will still be inside and maybe stuck to the coils. Re-glue with JB weld or similar type of two part epoxy. Magnets should be glued around the inside of the flywheel-equally spaced with alternating polarities.
Sep 17, 2016 | John Deere Garden
I have a john Deere stx38 yellow deck Kohler motor does this mower have any fuses that has anything to do with getting fire
Hello I'm wade No it doesn't! It is all ran by key switch. If you can remove air filter and spay starting fluid in engine if it starts then you having fuel delivery problem. Fuel shut-off solenoid usually sticks not causing fuel to get into engine and that solenoid is what kills the engine when key gets turned off. If you have any further question I'm here to help. Wadembly@aol.com
May 07, 2015 | John Deere Garden
How to fix ajohn deere L120
what kind of engine does this have Kohler, Briggs and Stratton , Kawasaki, etc.. need this information. There is a thing under the flywheel called a stator ( alternator ) a lot of times on Kohler the magnets inside the flywheel comes loose and sticks to the stator and then cannot charge the battery.also the regulator could be bad
Jul 28, 2014 | John Deere Garden
Why is my John Deere L110 17 1/2 firing but not starting. It pops like a gun shot
this could be a engine timing problem this model should have a 17.5 hp kohler engine , now kohler's are now famous for having coil problems cus of overheating it and the other cause could be if you reciently shocked this engine hard (Heavy load) sometimes the flywheel pully (iron thing on top) comes loose or you shear the keyway on shaft anyways ck out my youtube video on easy way to change kohler coil for help doing this (all you need is 6 mm wrench , two hands and a playing card)
Apr 24, 2014 | John Deere Garden
Have a 2000 J.D. x475 62" deck engine will crank and crank but will not attempt to fire
Check for rust on the flywheel magnet and the coil, make sure the air gap on coil is correct, check for broken primary wire.
Aug 18, 2013 | John Deere Garden
I need a diagram of the belt on a black deck John Deere STX38 can you assist Thanks Deb
Follow this link: http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt then do a "model search"
click on which model (either yellow deck or black deck) alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or this website:
OutdoorPowerInfo.com © 2011
Or just 'google':
Installation of John Deere STX38 and STX46 Hydro Drive Belt (Black Deck)
Good luck.
Mar 05, 2011 | John Deere Garden
Kohler engine backfires but does not run
sheer pin on engine shaft is busted. take off the fly wheel and look inside or on the shaft.
Sep 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I find the model or year on 38" John Deere with no hood?
A ten year old mower that probably cost about $1500.00 at least twn years ago that has not been taken care of is not worth much.
John Deere is a good name as in Kohler. How much is it worth? It is currently worth what you paid for it, you just made it worth that much.
Mar 08, 2010 | Garden
John Deere ZTRAK 737 zero turn - runs rough - one plug
My idea would be to replace the coil to that plug
Jim Kite paris, il
Apr 18, 2009 | John Deere Garden
Garden Logo
62 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
