Question about Fender Passport 150 PRO Portable PA System
I use this for fitness classes. After 1or 2 songs -the music starts cutting out the power is still on the passport and i know my ipod is working correctly - what could be the problem ?
The light indicating power is on is lit . I tried the system out at home for 35 mins and it didnt happen at all ,, help please
    Habit-Forming:
  • 61 Answers
How is the iPod connected at the class?
The VIP channel will override the signal if a mic is connected.
Are you using the same cable for dance AND home?
Is the ipod getting interference at the class from a wi-fi signal?
See attachment. It might help. https://classrooms.at.ufl.edu/wp-content/uploads/portable-pa-system.pdf
Posted on Jun 02, 2015
Testimonial: "thank you for your response, I'm going to try the troubleshooting first but might need to get it serviced."
3 Suggested Answers
  • 1138 Answers
SOURCE: Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Posted on Oct 19, 2009
  • 1138 Answers
SOURCE: i have the passport 250 on mic 1or 2 when pluged
Read the section of the manual dealing with the voice over function for paging. Available here:http://support.fender.com/manuals/manuals_elec/fenderaudio//PassportP250.pdf Note pages 7, 8 and 9 especially 9 under VIP subject.
Posted on Jun 21, 2010
My daughters high school dance team uses a samson 308i speaker/pa system. it is only 6 months old but the music will cut out from one of the speakers. It is not the speaker (we switched them) not the...
You have to double check the cable from Ipod to PA system. Most probably the audio out cable from ipod is not correclty fitting the output port of ipod. If you are using any cover for ipod., remove it and check. If the output pin is not correctly fit in to ipod both chanels will mix and output will be like karaoke sound....Use good quality output cable for ipod. Its a suggestion...
Jan 10, 2018 | Music
Sound cuts out
check the free air circulation in the power amp module, also check your speaker's impedance, let me know further, sorry for the late answer.
Sep 01, 2012 | Peavey XR 1220 Powered Mixer Mixer Powered
One of my Fender Passport 500 speakers has started to crackle sometimes, particularly when the song has a lot of base. What could be causing this? Would a regulator help?
You have probably blown the speaker... swap left and right to verify it is the speaker... These speakers are NOT too well suited for bass... They typically have low impedance speakers in series. You run a risk of popping the amp running with a blown speaker. You MAY have to replace all the speakers in the defective cabinet. ALL the speakers must be identical. The Passport 250 uses four 2 ohm speakers in series... not sure about the 500. It may have two 8 ohm in parallel. Do not use the speaker until it is fixed... the amps are hard to repair if a defective speaker cooks them.
Sep 08, 2011 | Fender Passport Deluxe 500watt Sound...
Hi, I have a cortex DJ Mix 300 but only some of the songs on my ipod are being picked up on the database when I load it up. It doesn't seem to make a difference whether the files are MPEG or other...
There are different digital formats and some are not compatible to transfer file names... It is frustrating isn't it?... run into this all the time. To fix the probllem you would probablly have to buy a music editing software packaage that you could edit the files and put them all in the compatible mode.
Aug 06, 2011 | CORTEX DMIX-300 Mixing Deck For iPod, MP3...
I just bought a fender passport 150 and it isn't very loud and the channel lights aren't even coming on when I plug in my guitar or my mic. You can hear the guitar and mic but only when the volume...
Turn down the VIP knob and try it. This is on channel 1 for announcement voice overs overriding everything. It has a threshhold setting for adjusting that. Here is the manual for it.
http://support.fender.com/manuals/pro_audio/Passport_P150_manual.pdf
Jun 05, 2011 | Fender Passport 150 Pro 150-Watt Class-D...
I have the passport 250 on mic 1or 2 when pluged in microphone goes in and out 3-4 no problems
Jun 09, 2010 | Fender Passport Deluxe 500watt Sound...
I have a 2600 peavey amplifier and when i turn the volum up it cuts off for about 2-3 seconds what i need to do
check that the cooling fans are working. if they are not then you are probably triggering the thermal overload protection.
Nov 08, 2009 | Peavey Pv 2600 Power Amplifier
Open Questions:
Fender Passport 150 PRO Portable PA System Logo
174 people viewed this question
Top Fender Music Experts
Michial Gueffroy
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
