Question about Haier 45-Pint Dehumidifier
Heat exchanger line frosting up. Then drips on the floor
    Top Expert:
  • Haier Master
  • 34,725 Answers
The condensate bucket may be missing or installed incorrectly. In some dehumidifiers poor design causes condensate to drip onto the floor.
Posted on Apr 21, 2015
Water is leaking out of the bottom
I get this complaint once in a while , most times it boils down to a unit that's being used on a Non level surface , most units are designed to gravity drain , if its not level , then Gravity is pulling wrong direction on unit so it drips on floor ;not in bucket
drips also can come from a frozen evap coil , this is a sure sign of blocked air flow and possible gas charge over heat (leak) unplug unit for 48 hrs to see if water continues to drain out , if so yep it's iced up
Jan 01, 2014 | Danby DDR586R Dehumidifier
Danby dehumidifier ddr4588ee ices up. Humidifier located in basement with temp around 60degrees. Unit is 1 1/2 years old.
According to your Owners Manual, the coils may start to frost at 60 degrees and the defrost sensor should turn ON and cycle periodically. However, the air temperature at the floor level in a basement, is colder than the air temperature by 5 to 8 degrees. So this may be causing the problem. In addition, if the air intake filter is dirty or clogged, the unit has to strain to keep up and will not function as it should.
If the unit is totally iced up, turn the unit Off and unplug it from the wall outlet. Allow is to thaw completely before attempting to clean the filter. You may want to put some old towels under it while it thaws. Once it's thawed, move it to a bathroom that has a shower. Plug it it in and set the humidity level at 45%. Turn the shower ON at a Medium hot temperature (enough to generate steam) and as you exit the batroom, close the door. DO NOT operate the bathroom's exhaust fan. Allow the unit to operate for 15 to 20 minutes, before returning to the bathroom. Then turn the shower OFF and check the unit for any frost and the amount of water collected in the bucket. If there is no frost on the unit and there's water in the bucket the unit is operating properly.
When you move it back to the basement, place it up off the floor on something sturdy, that can hold the weight and not be bothered by the vibration of the unit, when it's running. (ie a work bench, a counter top, etc.) Operate the unit as you normally do and monitor it for frost or icing up. And, whether or not the defrost sensor is cycling as it should. If you get no frost or just minor frost, it was the air temperature at the floor level, that was causing the problem.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Danby DDR4588EE Dehumidifier
Furnace/air cond. blower motor is smoking
I recently installed a horizontal gas furnace. All the electrical and gas supply was done correctly for sure, but upon the trial run, some smoke was coming out the supply lines into the house. I used some flex duct tape to seal all ductwork for air leaks. I also used some inside the first box coming off the heat exchangers to seal the inside of the box for leaks. Could the tape be burning because its to close to the heat exchangers and smoking or is it because its because its brand new and the heat exchanges have to burn a while? Please help
Jun 25, 2009 | Dehumidifiers
Dehumidifier
Most dehumidifiers these days have a built in defrost control, which turns the compressor off when the coils frost up while the fan continues to blow to help melt the frost off, so if it is frosting you may need a new defrost control, but first check the following: If your model has an air filter, clean it, as restriction of air flow will contribute to icing. Try to move the unit to a warmer location. Usually the best way to do this is to get it above the floor as far as possible, as the air temp is warmer closer to the ceiling than it is at the floor. Make sure there is plenty of room for air to circulate. (don't push it against a wall)
Sep 15, 2008 | Danby Dehumidifiers
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
Heats up basement
Dehumidifiers and how they work
Heat pump dehumidifiers
Dehumidifiers use a heat pump (similar to an air conditioner's heat pump) or chemical adsorbents to remove moisture from the air without cooling the air.
A heat pump dehumidifier uses a fan to draw indoor air over a heat exchange coil. The coil is almost freezing. The water in the air condenses on the coil and is drained. A second heat exchange coil reheats the air, which the dehumidifier exhausts into the room.
A heat pump dehumidifier dumps heat lost from the compressor and fan motors into the air. It returns to the indoor air the heat generated by the dehumidifier turning water vapour to liquid. I got this off the internet
Jun 24, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifier
Most dehumidifiers have a "Frost Guard" mounted on the condensor coil. If frost accumulates on the condensor coil the frost guard turns the compressor off until the frost melts, then comes back on again. For the dehumidifier to work properly, the surrounding (ambient), temperature must be higher than 65 degress. This temperature allows the moisture in the air to condense on the coils and drip into the reservoir without freezing up on the condensor coil. Also, if the humidity is too low, (below 45%), the same condition will occur. So it will help to keep the parameters in mind when you have this issue.
Thank you for your allowing me to advise you on this issue.
Dave E. (Illeagle)
Jun 02, 2008 | Goldstar DH5010B Dehumidifier
Ebac 880 E
The following statement is a parameter for all dehumidifiers and some of the control issues may vary, but the theory is the same.
If your model does not employ a "Frost-Guard" the condition you describe will avail itself when the above parameters are not met.
Simply unplug, or turn off the unit, until the above parameters are met or exceeded.
Dave E. (Illeagle)
Jun 01, 2008 | Ebac AD850 Dehumidifier
D50c
Dave E. (Illeagle)
Aug 10, 2007 | Friedrich D50C Dehumidifier
Frost, ice on coils DeLonghi DDE50E Dehumidifier
expected? of course! this is not ur solution try draining all the water to the sewerage if u cant try to pump it out with a vacuum cleaner (that can pump water) or a pump then turn on the Dehumidifier every time it frosts turn it off untill it defrosts or u can heat up the basement with a bellower and the Dehumidifier wont frost
Feb 05, 2006 | DeLonghi DDE50E Dehumidifier
Haier 45-Pint Dehumidifier Logo
162 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Vincent Cruz
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
