Question about Garden
Why won't it start?
I have replaced the wires to the battery after they snapped off at the connector; have brand new battery; checked the seat safety switch; checked the spark plug; replaced the fuse; brand new gas; blades not engaged. Will not even turn over.
  • BANalepa
    BANalepa Apr 25, 2015
    Thank you so very much!! The wrench to the solenoid was the trick and it turned out to be the starter solenoid!!
    Sergeant:
  • Garden Expert
  • 187 Answers
When I turn the key nothing happens.
There are several elements that go into cranking (turning over) the engine.
  1. Battery
  2. Fuse
  3. Key Switch (and wiring)
  4. Starter Solenoid and wires
  5. Starter motor
To begin with check the fuse. It's a 20amp car style fuse located under the hood near the battery.
If the fuse does not fix the problem let's move on to the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion(normal meaning YOU in the seat, PTO off, BRAKE pressed all the way down). If it starts cool! It is likely a bad battery.
  • Charge the battery for a few hours, on a charger.
  • Then perform a voltage measurement of the battery.
  • Switch a volt meter to DC Volts and clip it to the battery. It should read between 12-13 volts. If not the battery is suspect. If it is 12-13 volts see if it will crank, but continue to watch the volts. If they drop below 10ish volts, the battery may have a bad cell.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter solenoid. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good, the wires and connections are good, and the engine is not locked up. Don't crank it for more than a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test as long as the key is off, or if the safety switches or wiring are damaged, or if the safety switches are in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the positive terminal of the starter solenoid, in order to do this. When you apply this current from the battery to the positive terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first; if it works you do not need to do the basic jump test.
If these tests cause the engine to crank, but it will not crank with the key, then you know you have a problem somewhere in your starter wiring, safety switch system, fuse, or in your Key Switch. Of course you did check the battery terminals for tight, clean connections, right?
Most modern riding mowers have the following 4 safety switches:
  • Seat switch
  • PTO switch
  • Reverse switch (RIS) and Reverse Relay (RIO)
  • Brake/Clutch switch
If you need detailed instruction for testing your wiring and safety system, I will need your complete machine info.
  • Make
  • Model
  • Year
  • Engine Model
  • Transmission Model
  • Deck Size.
On a John Deere (100 series) the starting current flows through the following items in this order:
  1. Battery to Fuse then to the Key Switch.
  2. With key switch in the start position, the current flows from the Key Switch to PTO.
  3. With PTO off, current flows from the PTO to Brake/Clutch Switch
  4. With Brake/Clutch Pedal all the way down, the current flows through the switch to the starter solenoid.
  5. If the Starter Solenoid is in good shape, the solenoid connects the battery to the Starter and the engine cranks. Cranking does not mean running; it just means the engine turns over. Running is dependent on many other systems.
Those components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch. You can trace the voltage with a multi-meter. Connect the black lead to ground and look for 12 volts at each successive switch. If the voltage disappears at one particular step, there is your suspect.
Electrical elements that are NOT part of the starting system:
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO.These switches are called slightly different names by different manufacturer, but they all do the same thing. These two separate components work to allow the blades to cut while you are backing up (without killing the engine). They have nothing to do with the starting system.
The Seat and the RIO (the reverse latch not the button) switches are tied into the engine kill system. They provide a ground path for grounding the Coil. This same system controls the fuel shut off valve beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, if you turn the key and nothing happens, the problem has nothing to do with the Seat and Reverse switches.
Note: With the Key in the RUN position, power flows from the Key Switch to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't start and run.
Posted on Apr 22, 2015
Heated and cooled seat on 2004 expedition stopped working how to reset them
Heating and the cooling both don't work ? Just one seat or all seats ?
Your best bet have it checked for DTC'S - diagnostic trouble codes to start .
Climate Controlled Seat Module (CCSM) Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1342 ECU Is Faulted CCSM INSTALL a new CCSM and CARRY OUT programmable module installation (PMI). REFER to Climate Controlled Seat Module . B1358 Ignition Switch or Blower Electronics Circuit Short to Ground CCSM Go To Pinpoint Test Q . B2477 Module Configuration Error CCSM This DTC indicates programmable module installation (PMI) has not been done to a newly installed module. CARRY OUT PMI. REFER to Section 418-01 . CLEAR the DTC. CARRY OUT the self-test. B2486 Climate Controlled Seat Module Voltage Out of Range CCSM DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 294 (WH/LB) for a fault. REPAIR as needed. If okay, REFER to Section 414-01 . Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2488 Thumbwheel Switch Voltage Out of Range High CCSM Go To Pinpoint Test R . B2521 Tach Circuit Failure CCSM Go To Pinpoint Test Q . B2729 Cushion Over-Temp Detected CCSM Go To Pinpoint Test S . B2730 Back Over-Temp Detected CCSM Go To Pinpoint Test S . B2731 Differential Temperature Fault CCSM Go To Pinpoint Test S . B2792 Heat Switch Short to Ground CCSM NOTE: If HEAT is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2792 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1551 (VT/WH) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . B2793 Cool Switch Short to Ground CCSM NOTE: If COOL is pressed for greater than 20 seconds on the climate controlled seat switch, DTC B2793 will set in the CCSM.
CLEAR the DTC. If the DTC does not clear, DEPOWER the supplemental restraint system (SRS). REFER to Section 501-20B . DISCONNECT driver safety belt buckle pretensioner electrical connector or passenger safety belt buckle pretensioner electrical connector of the affected seat and CONNECT restraint system diagnostic tool 418-F395 to the safety belt buckle pretensioner harness connector. CONNECT the battery ground cable. CHECK circuit 1550 (WH/OG) for a short to ground. REPAIR as needed. If okay, INSTALL a new climate controlled seat switch. Once the repair is complete, DISCONNECT the restraint system diagnostic tool from the safety belt buckle pretensioner harness connector and CONNECT the safety belt buckle pretensioner connector of the affected seat. REPOWER the SRS. REFER to Section 501-20B . U2362 UBP Invalid Data Node ID CCSM NOTE: DTC U2362 indicates a network concern, the CCSM is not the source of the fault.
CLEAR the DTC. If the DTC does not clear, REFER Section 418-01 .
Nov 26, 2016 | 2004 Ford Expedition
Craftman 18 hp won't start with key
Check Battery. If headlight equipped turn key to headlight on position and see if headlights are lit. No light dead battery dead tractor,
Charge battery. If after charging weak or no start forget the battery and get new, Life of battery is two to three years,
If battery good make sure that parking brake set and blades are not engaged. Safety lockout will prevent tractor from cranking. The tracker has a safety interlock on the seat that requires a body warm or cold sitting on the seat if the parking brake is not set. The seat switch is known to fail. Try bouncing on the seat?
OK if battery OK and seat is sat or park brake set we can assume the safety interlock circuit is disabling the start circuit.
Need model to provide more answers
This website video shows how to check the component. Your model would be similar.
How to test lawn mower electrical safety switches
This electrical diagram is for a typical lawn tractor. Your model would be similar but different . This will give you an idea. The switch on the seat has two sets of contacts.26045611-oxnapdkevdwqbvzn03d44ye1-1-0.png
Jan 09, 2016 | Garden
1998 Honda Accord Won't Start
Park neutral safety switch maybe be the reason for the no crank ! Try putting the vehicle in park ,then try to crank the engine . Testing the electrical circuit is the best way to trouble shoot this problem , along with do a voltage drop test on the starter circuit ! This will test the battery cables an connections .
Starter Voltage Drop
How to voltage drop test starter motor circuit
Does it have a manual or automatic transmission ? Manual ? clutch switch . Looking at a wiring diagram I also see a starter cut relay !
http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter vehicle info. year , make , model and engine size . Under system click engine , under subsystem click starting . Then click the search button , then click the blue link ! Check the starter cut relay also . Videos on youtube showing how to test a relay controlled circuit !
May 29, 2017 | 1998 Honda Accord
1998 Ford Ranger won't start.
Check the igntion signal to the starter solenoid.
Oct 10, 2012 | 1998 Ford Ranger
How to replace ignition switch
Disconnect the battery to prevent ignition short circuits. Lower the steering column by removing the 15 mm column mount bolts. The column will drop safely down and the steering wheel rest in the seat.
Place the trouble light in a secure area under the dash and locate the ignition switch. The switch will have two black connectors that should be snapped firmly in place. The switch is easily recognized by the wiring harness that will have larger orange and red wires than other connectors. These are the main power supply wires. Carefully unplug the two connectors. Do not confuse these connectors with the lighting connector. The lighting connector is much longer, flat and does not have any large, power wires.
Locate the small, round, dimmer switch with a rod going into it. Leave it plugged in, but disconnect the mounting screws. The ignition switch shares a mounting screw with the dimmer switch. Remove two additional mounting screws holding the ignition switch in place. Gently pry out the switch rod that runs the length of the column to the key and tumbler.
Install a new switch by fitting the activator rod, mounting the new ignition switch with the screws and plugging in the wiring harness. Install the dimmer switch with the shared screw. Remount the column, attach the battery cables, and check the repair by starting the vehicle.
Jul 15, 2012 | Chevrolet Cars & Trucks
TROY-BILT Pony 13AN77TG766 - Brand new battery will not start
use jumper cables and jump t direct to the starter and see if it cranks over that will test the starter if it cranks look at the safety switches and battery cables
Apr 23, 2012 | Garden
Wheres fuel pump
The fuel pump is mounted inside the fuel tank. The tank will have to be pulled down to access. Some models have an assess panel under the rear seat. To see if yours does, pull the rear seat bottom out.
Sep 18, 2011 | 2000 Kia Sephia
Replaced battery, bike started fine. Let it sit overnight, won't start. Won't even crank, just clicks once then nothing, the Neutral light shuts off and the lights started flickering.
To begin with, I'd have that battery load tested to see if it's any good. I've seen brand new batteries that were bad. It it checks OK, check all the connections that go to the battery. Be especially attentive to the smaller wires that attach to it. I've seen battery acid eat the wire out of the insulation leaving the insulation intact and the wire appeared fine. If the wire bends too easily, be suspect. If the wires have the "crimp on" connectors, make sure they're tight. Your problem sounds like a bad connection somewhere.
Good Luck
Steve
May 19, 2011 | Harley Davidson FXST Softail Standard...
Want start or turn over
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the 2 large cables (1 coming from the battery and 1 going to the starter) are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on, transmission in neutral, and the Deck PTO is off, that you are getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you probably have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
You should check under the seat of your mower and locate a small square box with normally 2 wires connected to the end of it. While looking at the switch, press down on the back of your seat and make sure your seat is activating the switch. If not, you must get the switch correctly positioned so it makes contact and pushes the button. If you found nothing wrong there, go to the next step.
Make sure the 2 wires are connected and the wiring is in good shape. Disconnect the wires from the switch and make sure there isn't any corrosion on the terminals of the switch or the connector. After you have done this, reconnect the switch and try again to see if the mower will start.
If not, disconnect the switch again and place a jumper wire between the 2 prongs of the connector and tape them so they will not ground out on the frame. Start your mower and see if it operates correctly. If so, you have got a bad seat safety switch and it needs to be replaced. This was only a troubleshooting procedure. You should never operate a mower with this switch disconnected, because you could be seriously injured. Go buy a new switch and replace it. You will need the make, model and serial number of the mower in order to get parts. I hope I've helped! Thank you! Dane
Dec 22, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
John Deer F725 won't start - one of the safety switches is prohibiting starting. Battery OK , even tried jump start ...but won't turn over.
My name is Dane and I am going to assist you in solving your problem. However, I would ask that you do one check for me before we go to the seat switch procedure. Please find the starter solenoid on your mower. Make sure that the large cables coming from the battery and going to the starter are clean and tight. Make sure that your 1 (possibly 2) wires going from your switch to your solenoid are also clean and secure. Use a volt meter on DC volts, or a test light and check the small lead on the solenoid and make sure that when the parking brake is on and the Deck PTO is off, that you aren't getting 12VDC when the key switch is turned to the start position. If you have a 2-wire system, 1 of them is for ground only. 1 of the 2 wires should get 12VDC. If you get 12VDC at the small terminal of the solenoid, but no power to your starter, the solenoid is bad.
But you are probably correct that you have a problem with the seat safety switch on your lawn mower. The seat safety switch makes sure that if you are ever thrown from your mower, the engine will die.
There is a small chance that either your clutch/brake safety switch or your PTO safety switch could also be at fault. Normally they won't go bad, but will just get out of posistion so that when you activate the clutch/brake they won
Dec 11, 2010 | John Deere Garden
Garden Logo
133 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
