Question about Maytag Refrigerators
Not cool enough in refrig. Freezer ok. Fan not running
    Sergeant:
  • 168 Answers
Assuming you have a side by side, the freezer and refrigerator are cooled by the same compressor and coil. The freezer cold air is used to cool the refrigerator. The air is circulated from the top of the freezer by a fan into the refrigerator. If that is the fan that is not running, the fan could be the problem. The refrigerator also has a thermostat that could be bad.
Posted on Apr 21, 2015
    Genius:
  • Maytag Master
  • 1,585 Answers
Probly needs re charged
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
How do I determine and fix what is wrong with 2008 model whirlpool frig that the freezer I noticed first all food unfrozen then a couple days later refrigerator not cooling can hear running but contin
I ned more information to answer your question. What model do you have? This is very important to give you the correct information you seek. Thanks
Sep 16, 2014 | Whirlpool Refrigerators
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
Upper section of refrig. not cooloing. Remainder
check to make sure the freezer fan is turning. This should be inside the freezer unit at the top. It is probably behind an access panel.
If this fan is not turning, not enough cold air will move to the refrigerator side to keep it cold enough. If the fan has died, it will have to be replaced.
Oct 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore side by side refrig (no ice maker) Freezer works fine. The refrigerator side is not cooling. I have cleaned out the vent between the freezer and the refrigerator section by defrosting the...
Check to make sure the evap fan is running.
IF so, then let unit defrost, then turn back on, check for air comming thru top of refrig vent, if air moving ok, then let run for a few days and see if refrig warms again, if so then check for frost build up on back wall of inside freezer, if so, you have a defrost problem. With a defrost problem, defrost heater may be bad, defrost timer/electronic control may be defective. Either way, in most cases it is a defrost problem unless you don't have air moving and fan is running in this case you have a damper door problem inside air duct in refrig.
Sep 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
GE TBF19ZB won't cool. Motor is running, But, refrigerator and freezer are not getting cold enough. Refrigerator and freezer are set at middle settings
dirty condenser coils or condenser fan not working most common problems,condenser is at bottom of refrig. next to compressor.
Sep 07, 2009 | GE Refrigerators
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Refrigerators Logo
73 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
