Question about Samsung Cell Phones
How to factory reset my Samsung gravity SGH-T459
    Top Expert:
  • Samsung Master
  • 10,875 Answers
  • 945 Answers
SOURCE: HOW DO I GET MY UNLOCK CODE FOR SAMSUNG SGH-T459
Ok,enter wrong password for more then 5 times,it ll ask u to enter the puk number....now call your customer care and get the
puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
Posted on Nov 05, 2009
  • 51 Answers
SOURCE: how do i unlock my samsung gravity sgh-t459 for
1. Turn on your Samsung Gravity without the SIM card inside.
2. Now type in #7465625*638*UNLOCK_CODE#
Where UNLOCK_CODE represents your 8 digit unlock code. (Warning: Entering more then 3 incorrect unlock codes, may permanently lock your phone!)
3. If everything worked, your phone will say “Network Lock Deactivated
You can get unlock code from your service provider. Hope this helps
Posted on Mar 31, 2010
SOURCE: how to take apart the samsung gravity sgh-t459
Remove battery cover and battery. Using a #00 philips head screwdriver, remove the 6 screws around the perimeter. Slide phone open and carefully pry up on the edge of the green (or blue) trim near the space bar. The colored back should unsnap. There will be two philips head screws visible on the now exposed circuit board. Remove these and carefully pull up on the rectangular ribbon cable to disconnect the main circuit board from the keypad circuit. Carefully peel the two button contacts from either side of the phone. On the spacebar edge, there will be a clip holding the circuit board in place. Gently pry it away from the board and the board should come free (there will be clips on the other side but you should be able to lift the free side of the board up and slide it out from under the clips). Remove the QWERTY keypad. Unglue the remaining ribbon cable from the keypad frame. Undo the 8 silver screws securing the keypad frame to the hinge and lift frame off. There will be 4 screws visible on the back of the LCD case. Remove these and insert a thin plastic spudger at the top of the frame and carefully work your way around. The two halves will separate (should hear two snaps on each side). You will now be into the keypad/LCD section of the phone. Removing everything else is pretty straight forward. Follow these directions backwards to reassemble.
Posted on May 17, 2010
  • 532 Answers
SOURCE: my samsung gravity wont turn on or charge at all
The battery is bad and should replace it.
Thanks.
Posted on Jul 28, 2010
  • 131 Answers
SOURCE: forgot unlock password for samsung gravity sgh-t459 tmobile
Your problem is not a simlock but a user code (also known as security code, phone lock, pattern lock etc).
You can reset it for free here:
http://www.unlocksamsungonline.eu/free-phone-lock-unlocking/
Posted on Jul 31, 2012
Unlock my SGH-T459 SAMSUNG FOR FREE
You can't get any Free Code if your Mobile is locked by any Service Providers. If it is Locked so, Unlock your Samsung SGH-T459 Gravity Phone by Clicking this site http://www.onlinegsmunlock.com/. Follow the Instructions:-
1 - Switch ON your Samsung SGH-T459 Gravity without any SIM Card.
2 - Compose : #7465625*638*CODE#
Dec 12, 2012 | Samsung Gravity SGH-T459 Cell Phone
Forgot unlock password for samsung gravity sgh-t459 tmobile
phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Jul 29, 2012 | Samsung Gravity SGH-T459 Cell Phone
How to unlock samsung gravity sgh-t459
There are lot ways To Unlock the Phone ,but Unlock code is easy and Correct way to Unlock the Phone from Network Lock,You need to specify the Current Network Lock and Country and get the Unlock code at here Onlinegsmunlock.com
and Unlock it,then You can use it any GSM Network ...You can follow the instructions below and Unlock it step by step..
Samsung SGH-T459 Gravity Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Samsung SGH-T459 Gravity mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung SGH-T459 Gravity mobile phone, your phone may get hard locked and sometimes become unusable.
Method 1:
1 - Switch ON your Samsung SGH-T459 Gravity with a NOT ACCEPTED SIM Card.
2 - Samsung SGH-T459 Gravity will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung SGH-T459 Gravity shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung SGH-T459 Gravity.
3 - Compose : #0111*CODE#.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung SGH-T459 Gravity is locked to.
CODE: Its the unique Unlock Code for your Samsung SGH-T459 Gravity.
If method 2 does not work, you can try method 2 again but this time without any SIM card on your Samsung SGH-T459 Gravity.
Aug 05, 2011 | Samsung Gravity SGH-T459 Cell Phone
Samsung gravity unlock code
The Samsung Gravity SGH T459 unlock code can be obtained from a SAMSUNG UNLOCK CODE website. They provide simple and detailed steps in unlocking your phone. You don't have to go through a headache to fix your problem.
Oct 04, 2010 | Samsung Gravity SGH-T459 Cell Phone
My samsung gravity wont turn on or charge at all
Thanks.
Jul 28, 2010 | Samsung Gravity SGH-T459 Cell Phone
I POWERED DOWN MY GRAVITY SGH-T1459 WHEN I POWERED IT UP THE PHONE ASK ME FOR THE PASSWORD TO UNLOCK IT HOW DO i UNLOCK THE PHONE
try 0000 or 00000000 which is default code. if wrong than you have to factory reset it by *2767*2878# without sim card. you data will be lost.
Apr 28, 2010 | Samsung Gravity SGH-T459 Cell Phone
Cell Phones Logo
88 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
