My tv will turn on manually, but only shows a blank screen, then cuts off automatically,. what do i do.
    Top Expert:
  • Televison & ... Master
  • 75,599 Answers
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Apr 21, 2015
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: the screen went blank and the tv will cut on but
Look to see if you do have 16~24 vdc feeding the backlight inverter board, check the power supply section for caps with leaking/bulging tops. So it can be the power supply or he backlight inverter board.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 14, 2010
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
I hooked my ps3 to the hdmi connection in the back,neither the system or the tv recognize the connection, i get a blank screen.I know the hdmi cable is good because I tested it.Any suggestions?
It could be that the PS3 is outputting a higher resolution than your TV can handle. Here is an excerpt from the PS3 manual:
If the video output settings do not match those required for the TV in use, the screen may go blank when the resolution is changed. The screen should, however, automatically go back to its original resolution after a while. If the screen remains blank for more than 30 seconds, turn off the system. Then touch the power button on the system front for at least five seconds to turn the system on again. The video output settings will automatically be reset to the standard resolution.
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Mar 09, 2011 | Televison & Video
Vizio p42hdtv10a
Bad interface circuit or power supply. Needs servicing..
Jun 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Can't watch show while recording
It doesn't do. No can do.Whatever channel you SWITCH ON TO AFTER you started recording be it timer or manual GETS recorded. Whether you switch onto inputs on your TV remote or cable remote IS the one getting recorded.
Jun 15, 2017 | Sony Televison & Video
Blank screen
Hold the power button (5-10 SECS) when turning it on and your PS3 will automatically set the correct video output.
Nov 05, 2008 | Sony Playstation 3 (PS3) Console
No Picture, No Sound
You can get a repair kit from www.magnavoxhelp.com for under 30.00 dollars.
Jun 15, 2008 | Philips Magnavox 51MP392H Rear Projection...
I have a panassonic 50" plazma tv, when using it as a pc monitor the screen goes blank how do i stop this, many thanks, patsy
Does the screen go blank after the computer has been sitting unused for a while or is it immediately blank and does not show a picture. If it goes blank after a while, look in your power settings under control panel on your computer and set the monitor cut off to NEVER, also check your screen saver settings. If it does not show a picture at all check the user manual of your TV to see the supported computer resolutions and then check under display settings on your computer to see if the resolution that you are using is compatible. Hope this helps.
Apr 02, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
