Question about Magnum Air 2 HP 5 Gallon Twin Tank Air Compressor
Pulled head. When reinstalled, blowing air out air filter hole. Why?
    New Friend:
  • 51 Answers
Stuck reed valve, Try swapping them. Or make sure they fit properly. When re-installing them. AGAIN !!!!
Posted on Apr 21, 2015
    Top Expert:
  • Magnum Master
  • 51,174 Answers
One of the check valves has failed
My starter cord will only pull out about 6 inches and then it's stuck...
If the recoil will only pull out a little and it appears to be good when you removed it, then pull the plug on the engine and pull the recoil rope 3 times all the way. Important - watch the plug hole each time to see if black debris blows out. Then squirt 1 time WD40 in the cylinder head thru the plug hole. Clean, gap the plug or replace if required. LM19 I think, plug is marked. RE-install plug, attach laminator connector. Pull recoil rope again, should be free if engine isn't seized. Make sure oil has been changed this year, 30W, and is full. Check air filter also while you are doing this basic maintenance.
Jun 19, 2016 | Honda HRX217VKA Lawnmower
WHAT CAUSE ENGINE JAM/THE ENGINE TOOK IN WATER THROUGH THE BREEDER HOLE
It is called hydrolic lock.It happens when you get fluid in the cylinder and the piston cant compress it and the valves are closed so there is no place for it to go. Pull the plugs out crank the engine over slow at first then fast to get the water out. Clean the plugs and reinstall and hope you didnt blow a head gasket or bend a rod at the least. Dont forget to change the oil and filter and check trans ect.
Jun 01, 2014 | Toyota Corolla Cars & Trucks
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Replace fuel line on husqvarna 142
You need to remove the carb to do this, remove the top cover, remove the two screws holding the air filter on and remove, remove the two 10mm nuts holding the filter back plate and remove, remoce the two 7mm headed screws secuting the carb, remove the two cross head screws holding the bottom of the bracket, the bracket will now come away along with the carb, unhook the fuel hose from the carb, now grab the fuel hose through the fuel filler hole, pull the hose with the filter out through the filler hole, take a new hose, slice one end into a long taper, push the taper through the hole in the crankcase floor and into the top of the tank far enough to be able to grab the end with a pair of long nose pliers through the filler hole, pull down into the tank, trim the end and refit the filter.
Apr 05, 2012 | Husqvarna Garden
It was running after a carb re-build. now my bulb isn't pulling gas when i pump it
The bulb and/or fuel lines could have a small hole in them, losing vacuum, introducing air into the fuel system and causing problem. First off, check inside the fuel tank and make sure the fuel filter is attatched to fuel line. This is a common place for the line to break and if it does, it floats, introducing LOTS of air and a malfunctioning purge/primer bulb. When you depress the bulb, the vacuum created actually allows gas to Flow to the carburetor as it is pushing any air/old gas back to the fuel tank. So, in summary. Carefully check the condition of ALL of the fuel lines ,fuel filter and the bulb itself. If they are dry, non-flexible, or cracked, they need to be replaced.
Sep 16, 2011 | Poulan Garden
I have condensation dripping off the inside case of my domectic caravan air conditioner
Clean the air filter and blow the fins off to stop this problem dirt will cause it to draw water so pull the cover blow out the air cleaner and blow out the coils inside andon the roof this shoud take care of your problems. IF it does not clear up try cleaning the drain hole in the top of the unit by removing the outter cover and make sure the drain tube isclean.
Mar 10, 2010 | Dometic Rooftop RV Air Conditioner
How to replace engine air filter in 2001 honda odyssey
The air cleaner element is inside the air cleaner housing on the driver's side of the engine compartment.
To replace it:
1. Remove the two pins holding the air intake cover by pulling the head on each pin. Remove the air intake cover.
2. Loosen the four bolts by using a Phillips-head screwdriver.
3. Disconnect the clip from the bolt on the air cleaner housing, then remove the air cleaner housing cover.
4. Remove the old air cleaner element.
5. Carefully clean the inside of the air cleaner housing with a damp rag
(The coolant lines inside the air cleaner housing may be warm. Do not open the hot air valve when cleaning the inside of the air cleaner housing)
6. Place the new air cleaner element in the air cleaner housing.
7. Reinstall the air cleaner housing cover. Reinstall the clip on the bolt; make sure the clip is under the washer. Tighten the four bolts.
8. Reinstall the air intake cover. Reinstall the two pins and secure them by pushing on the heads until they lock.
Hope this helps you through the process.
Nov 23, 2009 | 2001 Honda Odyssey
Blows air out the back when hoss is hook
Sorry I have been away. the head valve is stuck. remove 4 head screws, take off cap without ripping gasket, try to pull up on head valve. clean inner nad outer oring and housing and reinstall wiht litium grease. hand acutate the head valve to make sure its free
good luck
May 05, 2009 | Air Tools & Compressors
Magnum Air 2 HP 5 Gallon Twin Tank Air Compressor Logo
141 people viewed this question
Top Magnum Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
JOHN LAPIER
Are you a Magnum Air Tool and Compressor Expert? Answer questions, earn points and help others
