Question about Delphi Audio Players & Recorders
The yellow wire is pulled out of the plug on the back of the radio on my delphi x250 mp3, I need to know where in the plug it goes
    Top Expert:
  • Delphi Master
  • 10,875 Answers
  • 3 more comments
  • William griffin III Apr 21, 2015
    Not my plug mIne is a single 20 pin plug with 13 wires in it
  •  johnny rebel
    johnny rebel Apr 21, 2015
    so then it is diagram 2 c1 c2 c3 the yellow is the power to turn on your stereo.
  •  johnny rebel
    i cant find anything else on this besides the delphi website,i believe that you arent giving me all the info,what are the s/n and model,any other numbers?
  •  johnny rebel
    http://www.retrevo.com/samples/Delphi-ma...
    donset help but ty anyway
2 Suggested Answers
SOURCE: Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Posted on Aug 02, 2009
Need wiring help for Galaxy 959 Cb Mic
1) shield / ground 2) yellow/ audio 3) red / transmit 4) white / receive
Mar 17, 2013 | Galaxy Radios 959 40 Channel Am/ssb Radio
I had the same problems as the first guy but never got another answer back. I hooked up my yellow wire to my 12v constant boat battery and I got power because I could put in a disc and take it out but the...
Hi:) The yellow goes directly to the battery posative and the red goes to the ACC on the KEY switch if the radio is not connected to the posative ACC wire on the Key switch you will have no Radio at all the yellow is just for the radio's Memory and the CD motor and eject.
Here is a install pdf. site for that radio. http://www.docs.sony.com/release/CDXM10_install.pdf
May 12, 2011 | Sony CDX-M10 Car CD/ MP3 Player
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
I need a wiring diagram to hookup a Delphi X250 MP3 to a Massey swather
not sure about yours but most common colours are as follows
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Aug 30, 2009 | Car Audio & Video
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
Powering up Delphi SkyFi 3
I found the soloution to my problem on the "Shop Delphi" website. I had to do a hard reset described at this link:
http://www.shopdelphi.com/contact/ce/s_pf/#2516
It erased all memory in the Skifi and reset everything back to factory specs, but I have my radio back.
Rod in Tennessee
Mar 21, 2009 | Delphi SKYFi3 XM Radio Receiver
Wiring Diagram
If you could post a clear picture of the back of the radio where the plug goes in I might be able to help you. I need to see the number of pins, their configuration and the shape of the socket. It wouldn't hurt to see the colors of the wires in the plug too.
Jun 07, 2008 | Car Audio & Video
Wiring a new radio in 1991 ford explorer
1991 Ford Explorer XLT Radio and Speaker Wire Colors
Pulled out the stock radio and found two plugs on the back of it. One plug had 7 wires (Power, Dimmer, Amp etc.) and one had 8 (Speakers).
7 wire plug (I could see these wires immediately from the plug):
Car Radio Battery Constant 12v+ wire = Light Green w/ Yellow Stripe
Car Radio Ground Wire = Black
Car Radio Accessory Switched 12v+ wire = Yellow w/ Black Stripe
Car Radio Dimmer Wire = Light Blue w/ Red Stripe
Car Radio Illumination Wire = Orange w/ Black Stripe
?? Don't know ?? Red Wire (No power to wire Constant or Accessory)
Car Radio Amp Wire = Blue
8 Wire Plug (Wires were wrapped in a grey outer sleeve, had to cut sleeve to get to wires.):
Right Front:
White w/ Green Stripe (+)
Brown (no stripe) (-)
Right Rear:
Purple w/ White Stripe (+)
Light Blue (no stripe) (-)
Left Front:
Light Green (no stripe) (+)
White w/ Orange Stripe (-)
Left Rear:
Light Blue w/ Black Stripe (+)
Yellow (no stripe) (-)
Speaker Wires (found at the individual speakers in the doors)
Right Front:
Green w/ Orange Stripe (-)
Right Rear:
Orange w/ Red Stripe (+)
Black w/ White Stripe (-)
Left Front:
Orange w/ Green Stripe (+)
Blue w/ White Stripe (-)
Left Rear:
Red w/ Green Stripe (+)
Red w/ Blue Stripe (-)
Hope this helps. I spent hours looking for the correct color key and this one works for my '91 Explorer.
Feb 08, 2008 | JVC KD-G230 CD Player
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
935 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
