Question about Kubota Garden
What is the part number for the foam air filter for the AV6500 Kubota generator?
Air filter part number.
    Genius:
  • 1,585 Answers
The lawn mower parts shop will tell u phone book
Posted on Apr 21, 2015
I have a V1902 Kubota running a 1500 watt generator, runs good except it has a light black haze out the exhaust, hours on engine 7,641 any suggestions
Sounds like its time for a carburetor cleaning and setting...the "black haze" is probably on your spark plugs too.. A too rich mixture will cause the engine to run hotter too...
Any GOOD small engine guy can take care of it.... install new spark plugs and get the carb taken care of.. you'll be fine!!
Sep 08, 2017 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Power washer runs until air filter is put back on
Have you replaced the air filter? Without the air filter the engine is getting enough oxygen to support combustion. With the air filter it does not get enough oxygen. If you have not replaced the filter it sounds like it is time to replace it. If you have been "cleaning" the old filter and reusing it, small particles may be lodged in the filter, reducing the airflow. Is it a pleated paper filter or a oil dipped foam filter. If it is a foam filter, have you cleaned it? If you replaced it was it a store replacement or a piece of foam you obtained and made it fit? Foam can be closed cell or open cell , both look similar but closed does not allow airflow and open does .
Jul 16, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Kubota troubleshooting
Try bleeding the generator as some air could have entered in the system.
Mar 13, 2017 | Electrical Supplies
I changed my aril filter on my sym joyride to a foam one. Now it's back fires, why?
NEEDS BACK PRESSURE WAS STANDARD THICKER AND FOAM LET MORE AIR IN IF SO COULD BE YOUR PROBLEM CHANGE FILTER OR PUT JET KIT IN
Sep 19, 2013 | Sym Motorcycles
Generator parts
you neer said what part you want and with it fits to.
generator and filter?
and suzuki sells them. is this a car? or a Power generator , this is a car forum.
Jul 15, 2013 | Suzuki Cars & Trucks
Engine surges
Hi Johnny,
I think the heart of your problem lies with the ethanol content in today's gas. It has at the very least 10%. The problem with gas containing ethanol, it only has a shelf life of about 30 days. What happens is the ethanol absorbs water from moisture in the air. The ethanol and water bond together and have a higher density than the petroleum based gas on top. It is exactly like oil floating on water. When this happens the octane rating of your gas drops dramatically, that's problem number one. Problem number 2, let's say your generator has a 10 gallon tank. Each gallon containing 10% ethanol, 1/10th of a gallon times 10. After about a month or two in a humid area you have a full gallon of water and ethanol sitting on the bottom of your tank. The best generator in the world will not run properly with this garbage sitting at the bottom. Problem number 3 ethanol is a strong solvent, it will deteriorate your fuel line. It will gum up the inside and make the exterior brittle. I would strongly suggest that you replace the fuel line with Tygon or any other ethanol safe fuel line and replace or install an inline fuel filter.Check out the website pure-gas.org to see if ethanol free gas is available in your area. Here are two products that I strongly recommend Sea Foam and Sea Foam Deep Creep. I would completely drain the tank on your generator, install the new fuel line, spray a liberal amount of Deep Creep into the fuel line and let it sit for about an hour. Then drain the fuel bowl, fill the fuel line again with Deep Creep and let it sit for a little while. With the fuel bowl off, you should be able to lift the float and have smooth action with the float pin, no sticking the Deep Creep should flow smoothly when the float is lifted, after this is done re-assemble the carburetor and attach the fuel line to the tank. Add enough gas to run the generator for about 20 minutes and then use the Sea Foam. I have had stunning results from Sea Foam, I am not affiliated with this product it just works great and that is why I recommend it so strongly. Try to get the spray can of Sea Foam because that will be the easiest way to get it into the carburetor while it is running. Bring the generator outdoors after you have added a little gas to the tank remove the air filter from the carburetor and start the engine. Spray the Sea Foam directly into the carburetor, do not spray so much that it stalls the engine. After a spray or two you will get a feel for how much you can spray without stalling. Now the fun begins. Sea Foam removes carbon fouling from the engine and cleans the jets in the carburetor and it does this incredibly well but it produces an amazing amount of smoke, this can be very alarming at first but do not worry this is absolutely normal. You will be stunned by how much carbon gets burned out. Close the windows in your house and tell your neighbors in advance so they don't call the fire department. There will be that much smoke. Intermittently spray and let the fouling burn out. Do this about four to five times then spray a bit in the gas tank and let the generator run until it is empty. After the generator is empty add a little Sea Foam to the crank case oil, read the can for the proper amount. Store the generator empty. Sea Foam has stopped valve tapping, erratic float problems, rough idles and hard starting issues for me, It is an amazing product. I know that the desire to have a full tank in the generator for when the power goes out is very strong but it will cause you nothing but grief in the long run. You are better off finding gas cans that are air tight, they will not allow moisture to be absorbed into the ethanol and you will have a much longer shelf life. When the power comes back on I use a kerosene pump to empty my generator and then I run the engine dry.By using this method I have an extremely dependable machine that starts on the first pull every time even after sitting for over a year.Sorry for being so long winded but this is what really works and for those that also read this post who are not mechanically inclined, the long winded explanation gives them a clearer idea on how to solve this problem. Good Luck,Michael Burke
Nov 28, 2011 | Coleman Powermate Powermate 5000W...
I have an older Craftsman 750 watt generator model 580.328310. Serial # on this unit is 029434. Unit runs great. I am looking for foam air filter, rubber foot for bottom and new gas gauge.
Take a look at the http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Generator-Parts/Model-580328310/0247/0702250?pathTaken=
look for the parts that you need and you can order them direct from Sears.
Jan 09, 2011 | Craftsman Garden
Step by step air filter replacement?
Remove seat, two bolts at rear...
unscrew wing bolt located in the middle of the air filter element
remove filter, and clean the mating area in the air box (WD-40 works well) Make sure not to get any dirt in here!!!
Remove the inner air filter cage, Clean the air filter (Stock ones are foam) I use kerosene or gas, but be careful, wash it then with soapy water and let it dry completely.
Use a foam filter oil, either spray on or in a bottle, and make sure it's covered completely, and tacky, not soaked. (I use Bel-Ray foam filter oil) Replace the air filter cage
Put a small bead of grease on the filter where it mates to the air box, this helps it seal.
Re-install air filter and seat, I use a little bit of lock-tite on the seat bolts, as they vibrate out.
Mar 20, 2010 | 2004 Yamaha YZ 450 F
Foam air filter needs replacing. It
I'm not sure what your question is, but you need to replace the air filter and in the future, don't clean the foam filter in gasoline. They will deteriorate with time, but gas will speed up that process. Wash it in dishwashing detergent next time.
Jul 13, 2009 | Homelite Garden
Can't find air filter for central pneumatic air compressor
i do not know which one you taking about! the Air intake or in line moisture type on the discharge.
but both are universal just go to air compressor shop or go on line.
Jul 02, 2009 | Air Tools & Compressors
Garden Logo
141 people viewed this question
Top Kubota Garden Experts
Vernon Taylor
Mike Henne
Level 1 Expert
Are you a Kubota Garden Expert? Answer questions, earn points and help others
