Question about Air Tools & Compressors
I had to pull the head off compressor when i put it back on air was blowing out the exhaust. there was a couple of plates under head did i put them back wrong
    Sergeant:
  • 157 Answers
Chances are very good that's what happens. Those 'plates' are more than likely the valves that allow the air to enter the cylinder(s) and exit at the appropriate time and in the right direction.
Removal of the head to correct the problem is probably the only option you have.
Hope this helps.
Posted on May 31, 2015
4 Suggested Answers
  • 1388 Answers
SOURCE: Compressor is building up pressure very slow.
It could very well be the valve plate however before you order parts take a look at the cylinders. Unplug the unit, remove the cover from crank side and turn the compressor by hand till the/a piston is at top of stroke. Examine upper cylinder for scratches /wear or failed vinyl piston ring. On oil-free compressors, dirt and grit is sucked-in from the bottom of the cylinder and causes leaks between cylinder wall and piston. If scratched, air pressure is leaking down thru cylinder wall. Failed reed valves cause a pulsation at the intake port (air seems to be pumped out the intake). If you see a model number anywhere on the pump that begins with " WL", your pump is made by Campbell Hausfeld. Parts can be ordered from www.chpower.com. other-wise order parts from sears parts. Cylinder kits are around $40. Good Luck on the repair and email if you have questions.
Posted on Apr 02, 2009
  • 35 Answers
SOURCE: Kobalt 221565 air compressor. Has external oil
"bleeder under switch will not quit exhausting air while motor is off"
This is an indication of a bad check valve... the Nut-like fitting where the air enters the tank is really the check valve. Half of it is hidden, sticking down into the tank. Oil in the outlet air is most commonly an overfill or use of improper, detergent oil(standard motor oil). Could be also that the piston rings are clogged up with burnt oil. Sounds like you need to remove the pump head to replace a gasket anyway. Remove the valve plate also and clean. Spray carb cleaner down around the piston/cylinder, work the piston back and forth, spray some more. Change your oil using 30w non- detergent oil or synthtic non-foaming 20-50w. .
Posted on Oct 23, 2012
My 60 gallon compressor model vh631400aj is putting oil in the air tank (blow by)I pulled the heads off and the rings look fine but the top of the pistons are oily .any ideals
I think you need rings. You could have enough wear on the rings to leak past without it showing much by looking. All it would take is a couple of thousandths to cause problems. Check the fit real good when you put them in to know that your cylinders are OK. That unit should be pretty good for lighter duty, but if you run it hard or at high pressure it is going to wear.
Jun 13, 2017 | Air Tools & Compressors
SPT WA-1220H Portable Air Conditioner stopped blowing COOL air?
sounds like the compressor has died and is tripping its overload protection. Give it a good funeral, and next time, buy a brand name model.
Oct 06, 2014 | Kenmore Ac Airconditioner Remote Control...
Kobalt 221565 air compressor. Has external oil leak and air leak at head gasket. Leaking oil in to out let air and the valve bleeder under switch will not quit exhausting air while motor is off.
Oct 09, 2012 | Air Tools & Compressors
Air compressor model no. 921.153101 blowing air trough air cleaner
If you get air movement out of the air cleaner and it only compresses air to 25psi, you have bent or broken reed valves in the head. Take the head off the cylinder and inspect the valve plates and reed valves. This is a Craftsman compressor so you'll most likely have to get parts through Sears at www.searspartsdirect.com. For best results replace everything between the head and cylinder; gaskets, valve plates and reed valves.
Oct 03, 2012 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I took top of compressor off and the 2 plates that have 2 small brass plates that seem to fit into a groove on the 2 plates but cant seem to figure the correct assembly for the plates and brass plates.
The link below is not exactly like your compressor but will give you an idea of how heads are assembled. If gaskets need replacing try making them out of automotive gasket material or use the metal from aluminum soda/beer can. If you need to replace a reed valve, make it out of feeler gauge material. The reed valve needs a little wiggle room to work, try to use gasket material of same thickness. There are two chambers in the head (upper most part), one chamber is intake the other is exhaust. The intake valve is usually slightly cleaner looking than exhaust valve (exhaust valve gets hotter, looks burned) and exhaust chamber in the head is usually darker sometimes oily. Intake reed is closer to piston. Exhaust reed is closer to top of the head.
http://www.ereplacementparts.com/campbell-hausfeld-dp400000av-2005-air-compressor-pump-parts-c-32345_32355_33008.html
Oct 31, 2011 | Northstar Air Compressor Pump - 5 HP, 15.9...
Compressor sucks air in through the outlet quick connect where the hose attaches. won't build pressure.
I have seen this condition many times. Usually, the comperssor head was removed for cleaning or repair and the valve plate was assembled incorrectly. Easy fix. Remove the head and flip the valve plate. Make sure that other components are correct. Examine plate for warping, gaskets for signs of leaking. Make sure that the motor is turning in the correct direction (fan blades on compressor pulley blowing air towards pump). Finally, take a look at the intank check valve. The valve will allow air into the tank and not let it flow back to the pump. In your case the valve must be faulty because because air was flowing from quick connect to pump. Good luck
Sep 28, 2011 | Dewalt D55270 gas powered air compressors
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Nov 13, 2010 | Craftsman 15 gal Air Compressor 3 hp UMC...
My Makita MAC2400 air compressor keeps blowing the circuit breaker. The circuit breaker to the compressor not the one for the house. It will only run for about 15-20 seconds before the breaker pops. I have...
Your compressor should fill within 5 min or so. Here are a few things to check. As compressor is running check all air connections/fittings with soapy water (including regulator, drain fittings and quick connects). Repair as needed. If no leaks, unplug compressor and listen for air leaking from check valve at tank (remove 1/4 airline at checkvalve, brass valve at tank). Replace checkvalve as needed. If no leak at checkvalve, problem most likely valve plate in head of pump. The valve plate has two reed valves that sometimes break. Bad reed valves will cause compressor head to become very hot and discharge air will be hot. Replace as needed. Parts are available at www.toolpartsdirect.com. Good luck.
Aug 05, 2010 | Makita MAC2400 Electric Powered Air...
Air blowing out the intake
Cylinder head has two ports, intake (clean air coming in) and exhaust (air going into tank). Problem with my Sears compressor was the gasket that separates the two ports was blown. This causes exhaust to come out the intake port. Blown gasket may be a result of adding to much oil. Disconnect power supply, remove cylinder head, order or make new gasket, and reinstall. Connect power supply and watch the pressure build. My first attempt with home made gasket material allowed the pressure in the tank to build. Air was coming out the side of the cylinder head. Going to NAPA to buy the correct gasket material since Sears don't seem to sell the cylinder gasket anymore through Sears Parts. Good Luck
Aug 22, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
105 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
