Question about Haier Refrigerators
I have a compact refigerater haier e2002601553 what number is the coldest setting 1 or 7. Seems like stuff on top shelf is freezing if not full, before I tested just thought I would ask
    Genius:
  • Haier Master
  • 1,585 Answers
As it goes up it gets colder ans 7
Posted on Apr 21, 2015
aborcass
  • 2651 Answers
SOURCE: Amana TempAssure
heres a link to your owners manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/12642722.PDF
Posted on Apr 19, 2008
  • 80 Answers
SOURCE: thermostat setting on frigidaire bar fridge 1 - 10
10 is the coldest. Hope this helps you:) I keep mine at 6 and its great.
Posted on Mar 16, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My refrigerator freezes everything
Not only the thermostat needs to be considered but the adaptive defrost board and the air damper between compartments. Something happened yesterday and my solution was changed to a clarification request. Sea Breeze
Posted on Nov 18, 2009
sonicboomele
  • 1557 Answers
SOURCE: Hello the westinghouse fridge i
six is the coldest setting 1 is the lowest
Posted on Feb 16, 2011
mpcheeseman1
  • 1400 Answers
SOURCE: My Haier mini fridge (model
Hello
Number 1 may be the warmest.Set it to 2 or 3 and give it some time,a couple of hours to level out.
If this does not work try a higher number.
If still no luck then the thermostat or sensing bulb is bad and should be replaced.
Posted on Mar 24, 2011
Jenn air side by side, refrigerator side is freezing items at 2 on a 1 to 7 scale, how to I fix it?
Thermostat may be off a little but 1 coldest and 7 warmest? Cheap fix be to adjust thermostat and make sure damper flap isn't stuck open
Oct 24, 2016 | Refrigerators
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
Is 0 or 7 the coldest setting on the dial/ Haier HNSE032BB 3 2 Cubic Foot Compact Refrigerator
The higher the number the colder... so 7 is the coldest...
heatman101
May 08, 2011 | Refrigerators
My Haier mini fridge (model # HSW02C) is freezing everything in it's contents no matter what number setting (1-7) it's on. Is 1 supposed to be the coldest setting, or is 7? What should I do?
Hello
Mar 24, 2011 | Haier Refrigerators
My Haier compact frig runs all time, at #1 setting: freezes all
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Jul 05, 2017 | Haier HSB03 Compact Refrigerator
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Temperature control
I would suggest buying a little refrigerator thermometer.
Turn the t-stat all the way up to the coldest setting. Watch the thermometer by checking it from time to time when it reaches 36 to 38 degrees slowly turn the t-stat down till you here the compressor shuts off. Remember water freezes at 32 degrees.
Jan 14, 2008 | Haier HSB03 Compact Refrigerator
Refrigerators Logo
364 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
