Question about Keurig Platinum B70 Coffee Maker
Water comes out the bottom during the brewing cycle
    Genius:
  • 1,585 Answers
Probly needs serviced seals
Posted on Apr 21, 2015
Drips only a little bit of water tried viniger thru did not help.. 2 bottles
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig B70 Coffee Maker
My keurig is not dispensing water properly
5.Power on machine.
Mar 28, 2011 | Keurig Coffee Makers & Espresso Machines
Only brews half a cup on the largest cup setting?
5.Power on machine.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
Won't brew only drop at a time wiuth coffee grounds ]
5.Power on machine.
Mar 26, 2011 | Keurig Platinum B70 Coffee Maker
The water res. is full all the right buttons are pushed but coffee won't brew. What do I do next? It only has a small drip.
5.Power on machine.
Mar 25, 2011 | Keurig Elite B40 Coffee Maker
My B66 will not allow anything to come out of the dischare side, tank and water valve on supply side are all clear and De-scle mode is showing and started De-scle procedure but it will not discharge...
5.Power on machine.
Mar 24, 2011 | Keurig B66 3-Cup Coffee Maker
Did not make the large cup of coffee. Then we de-scaled the machine with vinegar. The computer seems off. The hot water is coming back into the water reservoir.
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Nov 21, 2010 | Keurig B50 Coffee Maker
Keurig b30 won't brew
Jan 08, 2010 | Keurig B100 Coffee Maker
KeurigB50 Coffee Maker will not brew. Gets to the
Jan 01, 2010 | Keurig Ultra B50 1-Cup Coffee Maker
My keurig wont brew
Sep 03, 2009 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
102 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
