Question about GMC 2012 Terrain SLT-1
Yes i know about the 4 bolts what i need to know is wear do i find them they are not showing are theyhidden thanks jim
  • GMC Master
  • 3,287 Answers
Ummm.. a little more detail is needed. What are you trying to do?
Posted on Apr 21, 2015
Head torque for a 2007 Kia Spectra
All Kia Spectras use the 2.0L 4 cylinder engine, and that engine has two different size cylinder head bolts that each require their own torque spec. Use the following torque sequence (see picture) and tighten them down in three steps. You will need a torque angle gauge or some way of knowing how far you've tightened the bolt for steps 2 & 3.
Apply a light coat of engine oil on the threads and under the heads of the bolts before torqueing.
M10 bolts: First step = 16.6*19.5 lb-ft, second step = Turn another 60-65 degrees, 3rd step = Turn another 60-65 degrees
M12 bolts: First step = 20.3-23.1 lb-ft, second step = Turn another 60-65 degrees, 3rd step = Turn another 60-65 degrees
secureimgcontent.asp?sg={35e8408a-ee5b-49af-b57f-38d1032aa0d4}&guid=00719062
Please let me know if you have any questions, and good luck!
Jim
Mar 06, 2016 | Kia Cars & Trucks
About water pumps
most of the water pumps on cars had a hub pressed onto the pump shaft and 4 small bolts holding the pulley onto that hub
even viscous fan hubs ( fan clutch) is bolted to the hub pressed onto the shaft
comment with a photo of the water pump that has the bolt in the middle and comment on the engine make and model
Oct 17, 2015 | Cars & Trucks
I have a snapper m1529e snow blower and need shear bolts for the auger, I was told by a local mechanic that it used a 1/4 inch machine bolt. I am worried that this might not protect the machine. Thanks...
Yes, 1/4" bolts should work fine. Just make sure they are grade 1 or 2, if you use say a grade 5 or 8 bolt, the bolt will not shear thus defeating the purpose of a shear pin. For what it's worth I have the same snowblower as you. When I found no one locally carried them, I resorted to to using regular bolts. I have had them shear just like they should when you hit something by accident. No damage to the machine after 3 years...and yes, someone in the family tried a grade 8 bolt on their ls and it basically destroyed the auger...
Feb 28, 2013 | Garden
The briquet holder has "corroded" and is failing,
Yes there is.All need is just get screws to do that.Or better still get a griller engineer to do that for yoy.
Dec 17, 2010 | Barbeques Galore Cook-On Complete Kitchen...
Pulley on motor tilted to left and belt keeps coming off
jim, Yes. The motor should be mounted to a bracket with 4 bolts. Loosen these, align the pulleys, then tighten the bolts. You can see the four elongated holes in the base of the motor at the following page. Scroll down until you see the 9 product diagrams. The one labeled "Motor" shows the four holes in the base of the motor.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=315.228390&pathTaken=partSearch
Mar 22, 2010 | Craftsman 10" Table Saw
After the rhino 660 warms up the reverse starts slipping. Has anyone had this sort of problem, and if so what did you do to fix it.
yes ive seen this issue before, remove the seats and engine cover, remove the clutch cover and inspect the belt for wear, but most of the time the bolt that hold the driven clutch to the transmission becomes loose, not only will it slip it will also have no engine brake. remove the bolt and apply some red loc-tite to the threads and torque to specs. hope this helps any more ? let me know thanks......jf
Nov 24, 2009 | 2004 Yamaha XT 660 X
Need to adjust timing chain on a 1980 KZ440 Kawasaki motorcycle
There should be a spring loaded pressure bar with a external set bolt you loosen a little to let the spring push the bea against the chain.
Mar 19, 2009 | kawasaki ZX 400 Motorcycles
Broken rear door handle
hi jim,
you need to open the door panel, after removing the panel, raise up your window completely and you can see the nuts or bolts that are holding your door handle.
tnx 4 using fixya,
drcool
Oct 05, 2008 | 2003 Volvo S40
GMC 2012 Terrain SLT-1 Logo
142 people viewed this question
Top GMC Heating & Cooling Experts
Doug Adams
Doug Adams
Darrell
Stan Ford
Are you a GMC Heating and Cooling Expert? Answer questions, earn points and help others
