Question about Toys
I need the instructions for the abovr. - Toys
  • 3,287 Answers
What product specifically are you looking for help with - none is visible here.
Posted on Apr 21, 2015
I have a 1998 GMC Jimmy. It died while driving today. Had it towed home. It will not start. Have good fuel pressure and spark is yellowish. replaced coil and ignition module. Also swapped out ecm. tried...
I have replaced countless distributprs for this issue. also fuel pressure has to be abovr 50 psi or will not start needs 50 pdi to open poppit valves on injectors. also if the spiders ruptured will be to much fuel and won't start hook up fuel gauge turn key on till reaches max psi turn the key off shouldn't loose more tham 15-20 psi if it does suspect spiders leaking.
Oct 30, 2013 | 1998 GMC Jimmy
I need to know where the computer goes in a 1994 toyota t100 i bought the truck and the cpu is in the seat not connected
The T100 made for sale in the United States ( not other countries). is in the right front kick panel as the passenger sits in their seat at thier right foot up abovr the tip of thier shoe or in the panel where the door hinge is it has 4 electrical connectors plugged into it. It could be in other places if the vehical was built for othe r than US market.
Nov 06, 2010 | 1994 Toyota T100
How do change forkseals on an 1983 honda mangna
The fork tube needs to be removed from the motorcycle. Wheel, fender, pinch bolts on triple tree released and the tube slide out of the clamps. The fork has a drain bolt at the bottom, set it in a drain pan and with the screw removed pump the fork till the oill is out. Measure how much as you need to put the right amount of new oil in when your done. If the one your doing was a leakers you needto drain the other one anyway as the oil needs to be new and the same as the other so measure it. Fork oil is better than trans fluild as it is a little different. trans fluild will work. once the fluild is under control theres an allem bolt going in from the bottom of the fork, The dust cap abovre the seal just pulls off and if it's good you can use it over, some seals have a snap ring holding the seal in so look for it, once out or it's not there you can pull the fork tube out in a hammering action against the seal till it comes out ( it'll take a few strog hits.) with the sael out wipe out everthing and don't let the parts get out of order. If you do go to bike bandit . com and look up your bike and the break down of the fork will show the order. You can buy from them as well most parts are shipped out of San deigo Calif. I get them in Kentucky in a few days. Push the new seal in after the allen bolt in the bottom has been tightened, a small drift and a hammer working around till it's all the ay in. add new fork oil though the top air valve or take the big nut off measureing the amount that you recorded some use 6 oz some use 12 and everything inbetween. the books can mess you up as the fork may be off something else. reassemble and tighten carefully all the bolts you lossened or removed. ( all of them) work up and down with the front brake on rocking if if feels good it is , go riding.
May 13, 2010 | 1994 Honda VF 750 C Magna
Are renault trafic vans just total balls of **** please be honest turbo went , turbo changed , now abs light and service light coming on and if i drive abovr 60 mph glow plug light comes on what a ball of...
you just got a bad egg mate most of those egines are fine sure nissan and opel use the same engine in there vans. you probly need a set of glow plugs they are very easy to fit and not to pricey.
Dec 10, 2009 | 2006 Renault 181
My 4 wheel drive shifter got stuck in the neutral position
take the 4 screws out of housing pull up on it and then when you can see the shifter mounted take the screws or bolts out of it i think 2 pull shifter up till it comes out then look in the shifter hole you will see 2 notches take a screwdriver and a line the notches together the drop in the shifter wiggle it back and forth it will start shifting then replace bolts on shifter and replace the 4 screws holding bracket with rubber attached to it and your done ...this happens alot if you put it in 4 wheel and dont lock hubs so dont do that this is bad and you can read that on the yellow stickers abovr your head if there still there but glad i can help let me know if you get it????????????????????
Oct 18, 2009 | 1987 Suzuki Samurai
Iam changing the timing belt need to know the marks to set it on on a 1990 ford mustang 4cyl
If you mark your timing gears, crankshaft & camshaft against the cyl. head & block with white paint before removing the old belt you really can't go wrong. After fitting the new belt rotate the engine by hand and re check your marks.
Aug 12, 2009 | 1990 Ford Mustang
Is there a transmission fluid dipstick for a 2004 V6 Chev Epica
the dipstick is usually right new to the oil dipstick.. right abovr it..
May 23, 2009 | 2004 Chevrolet Malibu
Error E00001-0000
Problem w/fuser check:
lamp
thermistor
thermofuse
Nov 04, 2008 | Canon imageRUNNER 5020 Copier
Need battery for a gd-986 translator
You might buy 4AAA batteries.I did, it worked.
Aug 10, 2007 | Ectaco GD986 Dictionary/Translator
Toys Logo
48 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
