Question about Chef's Choice 1.75-qt. International Cordless Electric Kettle. by Che
The switch paddle wont stay down at all. how do I fix it?
The switch paddle wont stay down at all. the exception is when the kettle base is off. (not the base with attached cord that the kettle is lifted off of to pour. instead the base of the kettle, which I disassembled). obviously I shouldn't use the kettle with bottom removed but it only works that way. otherwise the paddle switch pops back up as soon as I push it down. the kettle stopped working after maybe 2 years from purchase. the paddle would stay down or a couple seconds before I tightened the screws in the bottom compartment after unscrewing the base. that was even with the base cap on. then I plugged it in and depressed the switch paddle the and it stopped even doing that, including after unplugging. I don't understand if or how connecting the kettle to power would make a difference after I unplugged it. anyway, my question, again, is how to make the power switch stay down until the kettle boils (or at all for that matter). Thanks.
freetek
  • 5568 Answers
SOURCE: WK 200 just stopped working - its almost new!
Please look at my response here:
http://www.fixya.com/support/t563235-morphy_richards_opera
as it could well apply to your problem too.
Posted on May 01, 2008
SOURCE: Stopped Working!
Have had same problem several times. My fix was to remove the five screws on the underside of the pot and lube all the plastic linkage with WD-40. Apparently the linkage gets a bit warped with heat. The pot lasted about five years and today the switch contacts melted inside. I doubt that parts are available, so...
Posted on Jun 04, 2009
  • 78 Answers
SOURCE: I bought it ~2 years ago and loved it! Until it
wow ok cool
Posted on Mar 08, 2010
  • 9 Answers
SOURCE: kettle does not automatically shut off
stop using it. If the kettle boils dry it could damage it irrepairably, or worse, start a fire. It sounds like the switch is dodgy, look into getting it replaced, or just replace the kettle.
Posted on May 23, 2010
  • 5 Answers
SOURCE: My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Posted on Feb 18, 2012
My kettle wont start. it seems the connection from the base to the kettle is not connecting. if I hold the kettle firmly down it will start but as soon as I take weight off the kettle it stops.
The contacts inside the base are carboned up and possibly misaligned. Take the base apart and clean the contacts with a nail file, check the alignment and correct if needed. Also clean the contacts on the bottom of the kettle. If you still have the same issue, open the base and inset a small piece of cork gasket material under the three contacts so they will not drop down when you put the kettle on top of the base. Don't make the cork pieces too thick or the kettle will not sit flat.
Mar 05, 2015 | Magimix Brushed Stainless Steel Jug Kettle...
Dualit kettle on switch wont stay on
The switch is worn out. If you feel confident about taking the kettle apart and reassembling it, you can buy a new switch at the link below. Otherwise, take it to a shop to have it repaired.
http://www.spares2go.co.uk/browse-DUALIT-72001-ON/OFF_SWITCH_-_RED-m125-p159253-s161139.htm
Jan 18, 2014 | Dualit Axis Cordless 1.7 litres Cordless...
Aroma AWK-161 Water Kettle not turning on
A power outage happened and all of a sudden Aroma kettle was not turning on. I tried different outlets that I knew worked... nothing. So, problem was certainly the kettle. I gave some good sold raps to the base of the kettle and then some to the base that plugs into wall. Walla! The kettle is now working. I pray it continues. And, from now on I'm unplugging base after each use :)
Jan 15, 2012 | Kitchen Appliances - Others
I have a dualit 72402 kettle which is not heating,when put on base, switch will stay down and neon lights possibly the element has gone but I cannot unscrew base of kettle to check it,do you sell this tool...
I have a similar problem and spoke to Dualit who say that the element is probably blown. As the unit is sealed into the base it is not repairable and should be scrapped. Not really a solution more a way forward
Feb 17, 2010 | Dualit (7202) Cordless Electric Kettle
Kettle will not stay on
Sounds like the switch is weight sensitive. A safety feature to prevent overheat as contents run low? The baseplate is probably not moving freely enough to move accordingly.
Sep 13, 2009 | Alessi MG32 Cordless Electric Kettle
On Off switch problem
Look under the kettle at the round circular connector in the bottom. Inside there is a small button that is depressed when the kettle is put on the base. If this is not pushed in far enough it will have problems.
The cause is that after some use the connector in the base plate collapses into the base by 1-2 mm This means the switch is not pushed in far enough.
My kettle had similar issues... I pulled the base plate apart (3 screws I think) and cut a round disk of plastic to lift the connector up by about 1-2mm and then reassembled the base.. No more issues
Jul 08, 2008 | Russell Hobbs RHOK3123 Cordless Electric...
Switches off before full boil
Nov 23, 2007 | Russell Hobbs RHOK3123 Cordless Electric...
Red light flickers, goes off, no heat
I had a similar failure with my Braun WK600. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettleful's; so far so good!
Oh, and if you take your kettle apart and your house burns down it is not my fault.
Nov 22, 2007 | Braun WK600 Cordless Electric Kettle
How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Nov 11, 2006 | Cuisinart KUA-17 Cordless Electric Kettle
Chef's Choice 1.75-qt. International Cordless Electric Kettle. by Che Logo
195 people viewed this question
Top Chef's Choice Kitchen Appliances - Others Experts
Rommel Balcita
Tom Chichester
AJMAL KHAN
Are you a Chef's Choice Kitchen Appliances - Other Expert? Answer questions, earn points and help others
