Question about RCA Televison & Video
My RCA HDTV model # D61W20B will come on make a short squeal and turn off and will repeat this over and over. What is the problem how can I fix it ?
  • RCA Master
  • 15,973 Answers
That set uses a color wheel on a high speed motor and a ballast to power the lamp. It is hard to guess at this point what it is without further info.
Posted on Apr 21, 2015
  • 375 Answers
SOURCE: RCA HDTV Model #M50WH72S
set has a fault and has gone into shut down to protect itself and possible further damage.
Posted on Apr 13, 2008
  • 1779 Answers
SOURCE: High Squealing Sound
There is a stand up coil about 1" tall and the dia of a nickel close to the HV transformer, the iron core glue comes loose over usage. This can be cured by replacing it or using a sealer/caulk and re-seal the coil. Hope this helps, it is not an expensive job for service.
Posted on Feb 13, 2009
  • 6 Answers
SOURCE: TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Posted on Jun 21, 2009
SOURCE: will not turn on RCA
the tv won't turn on with the remote or with the power button
Posted on Feb 07, 2010
hardrocko
  • 1476 Answers
SOURCE: rca hdtv big screen won't turn on lite for power
It sounds like there is definitely a short in the unit. If it turns off immediately it is probably the low voltage power supply that has the problem. If your unit is 6 or more years old and the lamp has not been changed I would do that first. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which explains how to do this and where to get the parts at the best price. If changing the lamp does not work I have a tip at http://www.fixya.com/support/r4606286-troubleshoot_dlp_tv which explains how to troubleshoot a dlp tv in terms anyone should be able to follow. Let me know if you need more assistance.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 10, 2010
Screen only shows red and green
i have 61" rca model # D61W20B
the pic was working fine then all of a sudden
got blurry
Feb 23, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Will not turn on RCA model D61W20B
Jan 30, 2010 | Televison & Video
How to activate HDTV on RCA D61W20B
U can't only receive HD the mode is 1080i is the HD signal.Some HD signals are free the rest must order HD package from cables or satalites signals to have more.
Nov 07, 2009 | RCA HD52W59 HDTV Projection Television
Wont turn on, power light for 2-3 sec, squeals for 1 sec,
Hi
you have defective power oscillation from the inverter section..
Thanks!
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
RCA D61W20B
On the Deflection board CK capacitors cp150,cp114 cp120,If cp 150 is puffed up on top it is bad so replace all 3 capacitors 2200uf 16 use 25v and Two left are 220uf 35v Resolder pinns on flyback Transfomer and when re hooking board back up make sure you have second ribbon connector in good. Board next to Deflection is the SSB it has turners on it where you hook cable.
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Model R52WH73 hdtv
Thw itc222 is in shutdown the procesor has detected a short a overvoltage or any of 25 different cuircits that have a problem. ussally whine the noise or squealing occurs the horizontal output transistor and flyback have shorted. this is repairable. at my shop abot 150 repair
Oct 26, 2008 | RCA R52WH73 Projection Television
Rca d52w26 makes a long whistle noise
how long? 3 seconds.. does it sound like chirping? is it comeing from back. smell anthing?
Nov 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
53 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
