Question about Samsung SyncMaster 750S Monitor
Display trepoizal and vertical centering not happening
Display trepoizal. and vertical centering not happening.
  • 25 Answers
If you go into Menu and Image control it should be there
Posted on Jul 23, 2009
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Small vertical pink line on the screen Garmin Nuvi 3590LMT
Most defects of the picture on the LCD display, typically points toward a defective display. We've repaired a lot of units with lines, splotches, color problems, etc. just by replacing the display.
Mar 18, 2013 | Garmin nuvi GPS
Screen show vertical lines from center to left. I open the front bessel and everything looks ok but when i apply some presure to the upper center between the two latches. that will make the display be...
Do the lines go away with the bezel off? You could put a piece of foam on the screen behind the bezel. Sounds like something is loose and if you can't tighten it, you possibly can keep the pressure on the screen to keep the display normal.
May 24, 2010 | Dell InspironTM 1501 Notebook
Tv goes to straight line in center of picture then
It happens when Vertical deflection stops as Vertical Out IC becomes hot or does not get vertical signal.
Please check electrolytic capacitors and dry solder joints in vertical out section in TV.
Aug 12, 2009 | Sanyo Televison & Video
We have an orion 2501B TV.no vertical display
The vertical Ic maybe are damaged and some of the electrolitic capacitors near by
Jun 30, 2009 | Orion Televison & Video
Black vertical bar about 4 and a half inches wide down center of screen
hi...
It sounds like an Intergrated Circuit (IC) has fried.
Your best bet in this situation is to contact ur tv service operator and let them recommend an authorized service center in your area....
rate me!!
Jun 01, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Screen is distorted
hi there, Below the monitor, on the center are option button, you can explore that in adjusting your screen display. You can widen the display, or tweak it depending on the angle that you need to. Just press the center button and choose from the menu.
Oct 25, 2008 | Dell E771p 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
T.V. has no picture
I noticed a bright horizonal line about 1/4 in.wide centered in the middle running from side to side. Audio is fine. This just all of a sudden happened it was not gradual. it is due to vertical section failure. please minimise bright to protect crt. solution. solution 1 check supply to vertical section. 2 check for ic failure in vertical section 3 check vertical output section parts. Is it fixable or dumpable?? Please HELP!!!! yes it is fixable it is common problem not major one. good luck.
Oct 07, 2007 | Televison & Video
Samsung SyncMaster 750S Monitor Logo
76 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
