Question about Toys
On my 4 year old son's John Deere gator prediger riding toy when you put battery in it goes before you push the accelerator?
    Novelist:
    Scholar:
  • 134 Answers
It sounds like the foot switch is wired backwards or if the switch was put in backwards. I would take out the foot pedal and check the switch and make sure that is wired correctly.
Posted on Apr 23, 2015
  • 156 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: I have a John Deere Ride on Toy stuck in reverse
Are the actual shifter levers not engaging or are the switches not clicking?
These Peg Perego Parts are available at http://www.shopjandl.com/, but I would check to make sure if it is the switches specifically or the levers under the shifter.
It is simple to check the shifter by taking the 2 screws out that hold the shifter in.
Hope this helps.
Let me know what you find.
Posted on Apr 16, 2009
SOURCE: Please let me know how I can change the rear tires
I want to add additional traction to my John Deere electric Gator. I have heard that you can somehow slip a bicycle tire over the plastic tires. Has anyone done this and how do you do it?
Posted on Dec 23, 2009
  • 670 Answers
SOURCE: battery is charged but car is still not working,
I have the switch go bad on the gas pedal. You can find a replacement here http://tigerimports.net/sunshop/
Posted on Dec 24, 2009
  • 670 Answers
SOURCE: We just replaced the battery and it worked fine
Use a meter to confirm whether the battery is still working. The meter should read around 12-13 VDC if the battery is good. The 12 Volt Peg Perego battery is made with 2 6 volt batteries connected in series. Maybe the connection broke when the battery fell out. Check the connection and also check with a meter if either battery is pumping out 6 volts.
Posted on Jan 03, 2010
Hubby went to charge the gator and the plug part that goes into the wall outlet became very hot to the touch. What could it be? Could it be the charger or the battery?
If the battery is completey drained or very low the charger will get hot to the touch, The charger put out 14.6 volts and then trickle down to 13.8 volts once charged, i would check the charger with a multimeter and check and see what kind of volts its putting out. if the battery is bad the charger wont think that it has completely charged it and will continue to push 14.6 volts into it
Apr 16, 2012 | Peg Perego John Deere Gator HPX Ride on...
We have a Peg Perego John Deere tractor that won't go. We've tried recharging the battery but it still doesn't work. The last time it was used, my son was repeatedly pushing the accelerator...
check the battery with a multimeter and make sure you are getting at least 12 volts, if its not showing any voltage one of the wires from under the plastic housing has become disconnected, if it is showing voltage but not 12 volts recharge it then check it again after about 12 hours and make sure it is showing 12 volts, if it isn't check your charger with a multimeter and make sure that its putting out at least 13.8 volts, if it is then you have a bad battery
Jul 15, 2011 | Peg Perego John Deere Gator HPX Ride on...
Battery is good but the gator wont move when pushing the accelerator
A lot of times the problem is with the accelerator switch going bad. To check, remove the red and white wire form the accelerator switch and connect them together. If you gator moves, then your switch is bad. You can get a replacement at mypegperegoparts.com
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Apr 18, 2010 | Peg Perego John Deere Gator HPX Ride on...
My sons john deere gator started going forward in reverse and reverse in forward.....any idea what part needs replaced?
It sound to me that you have put the battery on the wrong way round.
Check that it is connected the correctly.
Regards
Alan Hood
ami-man
Apr 06, 2010 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
839 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
