Question about Taylor Health & Beauty
How do I fix the light on my taylor bathroom scale 5579s? It has new batteries and the weight readings are correct. It does not illuminate the numbers.
SOURCE: conair ww39 glass bathroom scale won't work- batteries in wrong maybe? Help please!
Googled around until I found specifications for an unrelated brand of a similar bathroom scale. It mentioned making sure batteries were flat side uppermost in their compartment, which did the trick.
Posted on Sep 26, 2008
r321567499
  • 74 Answers
SOURCE: taylor digital bathroom scale
This link allows you to trouble shoot directly with the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
Posted on Jan 07, 2009
SOURCE: Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Posted on Jun 24, 2009
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
How do I delete a person no longer using scale?
You may try to remove the batteries and see if this worked.
Sep 02, 2013 | Taylor Body Fat Digital Bathroom Weight...
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
7506 Glass digital lithium scale battery replacement. I need the battery no. please...
The lithium battery is a 3-Volt CR2032. The manual for the scale is available here: http://www.taylorusa.com/media/IBs/7506_ib.pdf . Additional information and a link to the manual is available here: http://www.taylorusa.com/weight-management/glass-electronic-scales/glass-lithium-electronic-scale.html .
I hope this helps.
Apr 19, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
The Taylor bathroom scale is giving an error message. How can I fix this?
If the scale is moved or bumped, or the battery is replaced, the scale needs to be initialized before use.
To initialize, just press on the platform with your foot. The display will turn on and off. The scale is ready for use once again.
Sep 26, 2010 | Taylor 5593 Body Fat/Body Water Scale
Feb 23, 2009 | Taylor & Digital Scale Lithium Scale
display the Error.
REMOVE YOUR FOOT.
Regards,
Linda DLT
Consumer Relations
& Salter Housewares
866-843-3905
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Taylor digital bathroom scale
Oct 15, 2008 | Health & Beauty
Health & Beauty Logo
69 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
