Have tried pressing power button and holding it on with no luck, PC will not power up.
Check your RAM sticks. Try powering ON using one RAM stick at a time if you have more than one installed. Take the RAM modules out of the laptop ( situated on the bottom of your machine beneath a small hatch ) Push aside the silver clips either side of the RAM and they will flip up slightly . Holding the RAM sticks carefully on the sides gently pull them toward you . Look closely at the RAM you will see a small notch ( cut out ) on the RAM It needs to return to the slot the same way you take it out. When replacing the RAM slide gently (The RAM )back to it's slot and gently push into the slot and then gently push down on the sides till it clicks in . Remember to only replace one module at a time and try to boot and see if your machine responds . If 1 stick will boot then it could be ( after checking both modules individually ) that the other stick has failed .
Try unplugging for 15mins
