Question about Toshiba Televison & Video
Toshiba 62mx196 dlp TV picture freezes, blacks out, scrambles, weird colours. No noises. Sound works fine. Problem happens on all media. Dvd, wii, cable, etc. I hope you can help. Thank you James
SOURCE: SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
got mine working better unplugged the sound and wiggled the plastic coated wire above the large fan works but freezes maybe once in a day some days never have the sound running through the receiver (surround) I shut it off and it comes back on when it does freeze figure loose connection
Posted on Jan 06, 2008
SOURCE: Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Posted on Jun 09, 2008
SOURCE: scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Posted on Jul 29, 2008
SOURCE: problem with HL-R6167W green vertical lines
You need to do an aggressive reset on the TV. This solved problem completely for me. You must unplug the TV when it is on. Repeat this several times until the TV is jolted back into the factory default settings. The issue is actually with the programming I believe. The clue was that the display worked 100% perfect in HDMI mode, and the problem only existed in the cable setting, no matter if wires were attached or not.
Again, do an aggressive reset to the TV by unplugging it several times while it is on. It may not register the reset at first because after all, the actual problem is a programming issue and it's having trouble recognizing commands in the first place.
Good luck!!
Posted on May 31, 2009
  • 41 Answers
SOURCE: Tv picture freezes then goes black 10seconds later HL-R5067W
Sounds like the digital board needs replaced.
Posted on Jul 11, 2009
I have a Toshiba 1080i DLP hdtv.. my son & i were
the lamp exploded it happens u need to replace the lamp ensure its the exact type, the lamp is the light source and without light the dmd cannot sync colours nor pix
Jul 10, 2013 | Televison & Video
Fuzzy/Scramble screen when first turned on.
check solder joints on top of screen some screens were sub contracted to a chineese company called chi mai and had inherant defects
Nov 30, 2012 | Samsung LNT5265FX 52 in. LCD Television
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Toshiba 32a43 32' picture garbled mess
If you can get the tv to display the blue blackground(usually happens when there is no antenna or cable feed to tv) check to see if the whole screen is a solid blue, if it shows discolored areas around the screen then you might have to "demag" the screen. See if you can rent a demad coil from a tv shop and with tv on turn the coil in circular movements all over the front of screen till blue is solid.good luck!
Aug 03, 2009 | Toshiba 32A43 32" TV
Video is black and white
Are you using the same SCART socket that you use for your other consoles or a different one? My SCART3 input on my Panasonic telly has two different modes - one which displays in colour, and one which displays in a sort of grainy black n' white. There is a purpose to it but I can't remember what it is. :-)
Anyway, you switch between the two by pushing the AV button and then hitting the colour button which corresponds to SCART3 a few times 'til you reach the correct setting.
It probably isn't that, but... y'know. Sanity check.
Tune your tele and check you've got it on the right PAL/NTSC setting.
Oct 18, 2008 | Nintendo Wii Console
Lost color, loud buzzing sound HLP4663W
This can be the colour wheel assembly, or the servo drive board, or a fault on the circuit board that does the sync processing for the colour wheel.
You will have to have the set properly serviced.
Jerry G.
Mar 29, 2008 | Samsung DLP HL-P5663W 56" TV
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
