Question about Eureka 2998AR Uno Bagless Upright Vacuum
Why did it turn off while using and will not turn back on?
Happened after all filters and hoses cleaned
    Genius:
  • Eureka Master
  • 1,585 Answers
Faulty switch?????
Posted on Apr 21, 2015
Why can't I use the attachments to clean my couch?
You may want to check for a pinched hose. Unwind the hose completely and lay it out and try your sprayer again. If that doesn't work than try reseating the tank (turn the unit off, remove the tank and then replace it, wait 1 minute and turn the unit back on.) AND, if you haven't been cleaning the filters now would be a good time to do that. In the tank there is a lint filter on the lid and there is another filter under the flow indicator (turn flow indicator cap counter-clock wise, remove rotor, remove filter. clean filter and replace everything in reverse manner. Hope that helps. If not Bissell Consumer Care number is 1-800-237-7691.
Nov 30, 2015 | Bissell Carpet Cleaner Powerbrush Deep...
My Hoover Elite Rewind just lost power while vacuuming and wont power back on?
Hi! It appears your thermal protector sensor has kicked in and caused your cleaner to power off. This is usually due to a clog or a filter that needs to be cleaned or replaced. Try these steps to get your vacuum back up & running!
1. Remove the dirt cup canister from the vacuum. Twist off the dirt cup lid.
2. Remove the primary foam filter. Hold filter under running water until water runs clear. Squeeze out the filter and allow 24 hours to air dry.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash)
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
Your vacuum should turn back on after it cools off, this can take up to an hour. Hope this helps!
Oct 07, 2014 | Hoover Vacuums
My Hoover Elite Rewind just lost power while vacuuming and won't power back on?
Why won't My Hoover savvy won't turn on
Hi Denell! Your vacuum has a thermal protector that will shut it off automatically if it becomes overheated. This is usually caused by a clog or a filter that needs to be cleaned or replaced. Follow these quick steps to check your vacuum for clogs.
1. Remove the dirt cup and the dirt cup lid.
2. Grasp pre-filter frame and pull up and out of dirt cup.
3. Separate the pre-filter and Hepa cartridge filter. The pre-filter can be cleaned with a brush and then rinsed with water. Allow 24 hours to air dry.
4. Clean the Hepa cartridge filter by tapping either of the ends until dirt stops falling from the filter. The Hepa filter should be replaced once a year.
5. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
6. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose
The vacuum will turn back on after it cools off. This can take up to an hour. If the vacuum has been off for over 24 hours we recommend taking your vacuum in to a service center for repair. Follow the link to locate the nearest authorized service center to you.
Service Center Locator
Hope this helps!
Aug 13, 2014 | Hoover U8145-900 Savvy Bagless Upright...
My Dyson DC33 isn't working correctly. It's not picking up like it used to. The brush isn't turning and the belt is fine. I've checked all filters, hoses and cleaned everything. Why is the brush not...
Is it possible that you have accidentally changed the brush control setting? I say this because it happened to me and I thought it had broken. I must have caught the dial with my foot! Here a link that might help:
Jul 09, 2014 | Dyson DC33 Bagged Upright Vacuum
Why does the thermal protection keep shutting the vacuum off?
1. Remove the dirt cup canister from the vacuum. Remove the dirt cup lid.
2. Remove the primary foam filter. Clean the filter as suggested by the owner's manual.
3. Slide the Hepa filter out. Tap the filter against the trash can until dirt stops falling. Replace the Hepa filter. (Do not wash) Filters should be replaced once a year.
Jun 28, 2014 | Hoover Vacuums
The vacuum won't turn on. Overheat light and filter lights alternately flashing.
some motors have a reset button that has to be pushed to get power back to motor after over heat. it is ussually located near the rear of the motor
Oct 20, 2012 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Carpet setting: the brush drive does not work with the carpet setting. Is there a way to remove the bottom to determine if something is caught in the system?
To determine if you have a clog, first remove the attachment hose like you were going to put an attachment on. With the vacuum in the upright position, turn the vacuum on and place your hand over the hose. Do you feel a strong suction? If not remove the hose attachment by turning the locking ring at the end of the hose on the back of the vacuum counterclockwise, then remove the hose. Stretch the hose to it's fullest length several times. I would do this over some plastic or outside to keep the dust down.
Once you have done this replace the hose turning the locking ring clockwise to lock it in place, give the hose a little tug to make sure it's attached and locked.
Again, with the hose free from the agitator turn the vacuum on and fee for a good suction.
If you still don't have one then you likely have a plugged filter.
You will need to remove the dust bin.44d2af9.jpgOnce the dust bin is removed, over you trash can empty it by pressing the dustbin door release downwards. Now rotate the dustbin lid counterclockwise to remove the primary filter. With the lid removed grasp the filter and turn counterclockwise to remove the filter.
Pull the filter out over a trash can. Once out inspect it, if it's dirty you should wash the filter in warm water until the water is clear. When finish let the filter air dry for 24 hours before reinserting it.
Upon reinserting the filter, turn it clockwise to lock it in place, install the filter cover with a clockwise rotation to lock it in place and reinstall the dust bin.
Now plug the vacuum back in and again with the hose removed from the agitator or brush and ready to install an attachment then the vacuum on and you should have a solid suction.
These vacuums are really prone to poor suction if the filter get dirty. Because they have washable filters, you should take time about one a month to clean the filters.
Thanks Dorrian
Aug 13, 2010 | Kenmore Progressive Bagless Upright with...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Hose has very little suction
ok dont know but if you havent already where the roller sits underneath it where the dirt sucks threw i had a problem a little like yours i did every thing you did same thing happened.but i had a clog in the vacuum i used a pressure with out the dirt canister on i blew out a real nice hairball.after that i tried it and what do you know it worked. hope that helps
Jan 05, 2008 | Bissell 6594 PowerForce Bagless Upright...
Eureka 2998AR Uno Bagless Upright Vacuum Logo
48 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
