Question about Dishwashers
My dishwasher will not turn on i have power to the switch but thats all the fuse inside is ok as well any ideas
    Top Expert:
  • Dishwashers Master
  • 46,218 Answers
Sorry but we must be blind see no make or model listed can't look for help you see
Posted on Apr 20, 2015
Kitchenaide dishwasher KUDS25SHBS1
I have listed COMMON problems / reasons why a dishwasher won't start..
The thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Dec 15, 2013 | KitchenAid Dishwashers
My amana dishwasher won't turn on. No idea what's wrong. Last load came out clean as usual.
Amanda,
I dont mean to insult you so bear with me. I have gone on service calls with this issue and the problem was........the wall switch that turns on power to the washer was turned off. Often it is an ignored switch because its never used and its reason for being there has been forgotten.
That being said: many washers have fuses that are inside the door as part of the control module. Unless your a technician I dont recommend messing with it as you could get shocked. But FYI, often this fuse attaches to the side of the control module box but it does not really look like a fuse. Have your best handiman friend who is qualified check these two possibilitys out.
Oct 12, 2013 | Dishwashers
No indicator lights Whirlpool wdt710paym dishwasher
If it doesn't run and you have no indicator lights, check the circuit breaker for that outlet. If it is ok, test the output voltage at the plug-in for the machine (115Vac). If it is "live" then check inside the control panel (turn off the breaker first) for a fuse that appears blown. If no fuse problem, CAREFULLY (with breaker back on) see if the main switch is getting power. If it is getting power, the control board is shot...replace it!
Dec 28, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Whirlpool dishwasher adp4407 wont start
be sure the door is shutting properly the door switch may also be bad
Apr 24, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Trips mains fuse when switching on
Disconnect the heating element,remove lower panel and take the 2 wires off the heater and tape.Reset the breaker and turn it on,if it's ok you know the heaters bad if not let me know.
Apr 11, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher won't start - non responsive
Check the door switches. Both. and the wiring going to them
Jan 23, 2008 | Whirlpool DUL300 XTL Built-in Dishwasher
Westinghhouse 907 dishwasher Sydney Australia
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
Nov 03, 2007 | Westinghouse 24 in. MDP531 RF...
Dishwashers Logo
46 people viewed this question
Top Dishwashers Experts
