Question about OMC Water Temp Gauge, 60-240 Degree, 981298, 175472, Lot 2632ml169
Location and how to replace for 1992 toyota corolla
Alarm button no workin, whn i press it, lights up bt no sound,
May need a new one then if u already changed battery out
Nov 21, 2014 | 2009 Toyota Corolla
1992 toyota corolla starter replacement
If you like doing your own repairs, I'd like to recommend having a Haynes service manual on hand; it will give you all the info you need to do home-based repairs:
'92 Toyota Corolla manual
We have a manual for each of our vehicles and even when a job is destined for a workshop, you can get a rough idea of how much labor it entails and therefore how much it should cost.
Oct 20, 2009 | 1992 Toyota Corolla
1992 Toyota Corolla does not turn over. No click.
may be it is the ignition switch. don't turn it on fully. try to rotate the key half-way. trouble with the contacts of the switch.
Aug 12, 2009 | 1992 Toyota Corolla
1992 toyota Corolla Temp gauge does not work
find the wire that goes to temp sender and apply earth to it turn ignition on the temp gauge should read hot if it does replace water temp sender if gauge dose not move gauge needs replaging
Jan 26, 2009 | 1992 Toyota Corolla
OMC Water Temp Gauge, 60-240 Degree, 981298, 175472, Lot 2632ml169 Logo
262 people viewed this question
Top OMC Science & Laboratory Experts
Wbix
ray gallant
L Pfaff
L Pfaff
Are you an OMC Science and Laboratory Expert? Answer questions, earn points and help others
