Question about Dryers
Just replaced hi/lo thermostat and heat pak but still no heat
  • 932 Answers
Chris,
Did you make sure that you have 240 volts to your dryer? Got have that for the heat to work. There can also be a problem with a thermal cutoff if you did not replace that. If you can find your wiring diagram, I would suggest using it to follow the current path to make sure you have correct voltage all the way through. You could also have a problem with the block where your power comes into the dryer. I have seen that block go bad on both dryers and stoves. Hope this helps!
Posted on Apr 21, 2015
Hunter 44860 touchscreen thermostat- My thermostat displays "LO". My wife said she played with it and can't fix it. He heat won't shut off! I thought it was the batteries so I replaced them. I noticed...
I suggest to everyone NEVER to buy a cheap thermostat from any box store regardless of brand. Always go with Honeywell or White Rodgers high end stats and DO NOT lose their booklets.
Feb 19, 2015 | Heating & Cooling
Model 110.62982101 dryer kenmore elite electric
sounds like maybe bad heating element first check out ur thermostats hi-lo, thermal shut off, and cycling thermostat with a multimeter. also check element for continuity
Sep 15, 2014 | Dryers
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
My tumble dryer isnt heating up
bad element or thermostats , check for continuity with multimeter, the thermal cut off and the hi-lo thermostat. Its electric right? if Gas need to check Flame igniter, glo bar, condenser coils, additionally
Sep 13, 2014 | Indesit Dryers
BE SURE ITS NOT UR THERMOSTATS B4 REPLACING THE ELEMENT? THERMAL SHUT OFF THERMAL CUT OFF, HI-LO THERMOSTAT ETC
Apr 28, 2014 | Frigidaire 131475320 Dryer Heating Element
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Furnace transformer/fan-relay wiring to fan-motor
All you need is 2 fan speeds, 1 for cool and 1 for heat. Leave the low speed disconnected. Normally we have high speed for cooling, and med. or low for heat. So either speed connected to the heating circuit is fine.
Apr 12, 2017 | Heating & Cooling
Kenmore Thermostat
hi,
order or study the wiring diagram, could be a hi/lo heat setting circuit, the dryer should spin no matter what heat problem, jump the door switch
J
Jul 11, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
57 people viewed this question
Top Dryers Experts
