Question about iHealth Ibaby Monitor For Apple Iphone , Ipod Touch And Ipad - Wh
How do I get my ibaby monitor to work over 3g
They said to set up port forwarding. I have airport extreme and followed every direction exactly and still it doesn't work.
Hey Amy,
One way to help resolve the issue that you are experiencing is by lowering the resolution settings within the iBaby application menu. Try setting it to low, and let us know if that works.
You also mentioned that you were able to successfully port forward you router. May i ask what is the make and model of your router?
Posted on Apr 22, 2015
Tip
Setting up a printer for an airport extreme using windows xp
This faq might help in setting up the printer however this is not guaranteed to work every time if the printer in question is not supported by the router...
If you use Windows XP, you can print to a USB printer connected to an AirPort Extreme Base Station. Just follow these steps:
1. Click Start and point to Printer and Faxes.
2. Click Add Printer, follow the onscreen instructions.
getattachment.aspx&hm__qs=file%3d4ca801e0-b793-4a7b-90f4-4728584aca0a%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdi_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07793a2c077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
3. Select "Local printer attached to this computer."
4. Deselect "Automatically detect and install my plug and play printer."
getattachment.aspx&hm__qs=file%3d7be85aeb-bc68-47f1-a4a1-8658d4d12044%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdm_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07793dd8077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
5. In the "Select the Printer Port" screen, click "Create a new port."
getattachment.aspx&hm__qs=file%3d4892b6cc-f180-4ed6-8697-395b7850118f%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdq_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_077940dc077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
6. Select Standard TCP/IP Port from the pop-up menu.
7. Click Next, and follow the onscreen instructions for the Add Standard TCP/IP Printer Port Wizard.
8. In the Printer Name or IP Address field, enter 10.0.1.1. "IP_10.0.1.1" is generated as the port name.
Note:
If you are using an alternate IP address range, then you need to enter the IP address that AirPort Admin Utility displays for the base station when connected to it wirelessly.
getattachment.aspx&hm__qs=file%3d0cf55cb8-a610-485e-9b9b-6373a09d6bb3%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdu_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07794724077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
9. Select Standard for Device Type, and choose your printer from the list.
getattachment.aspx&hm__qs=file%3d3f0dfbda-a299-4888-95db-9ed638a48c0b%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdy_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07794a2c077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
on Apr 02, 2010 | Office Equipment & Supplies
D_Rossetto@msn.comWhen I set up airport extreme I dont remember setting up a password when other people visit and try to connect to Airport Extreme it asks for a password how do I find out what that...
If you are sure that you didn't set the password, then the default password must be set with your Airport Extreme System. It depends on the model, some have none, some have; admin, tech, unknown, security, etc.. etc..
You can find all the lists of available passwords for Airport Extreme for deferent models. here: click here to open the direct link
If you need further assistance, you can refer to this Tutorials.. (click here).
Good luck
Thanks for using FixYa.
Aug 07, 2010 | Apple AirPort Extreme Router
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Apr 17, 2010 | Apple AirPort Extreme Router
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
Airport extreme stopped, front light dead, back lights flash
Your airport just died, contact apple support and request a replacement.
Jun 21, 2009 | Apple AirPort Extreme Wireless-N Wireless...
HP DeskJet D2460 only prints grayscale through Airport Extreme
did you try going to printer properties? i think you will most likly find your answer there.
Jun 07, 2009 | Apple AirPort Extreme Wireless-N Wireless...
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
Cant connect to internet with Airport Extreme 802.11n
An airport extreme is just a dunb Wireless Access Point. It could be that it has been mated to the Linksys router and is looking at a different set if IP addresses that are not coming from the etherent connection out of the wall.
If you know how to obtain network addresses on your computer, find out what you get from the wall jack and from the airport through the Linksys. You can try to reset and reconfigure the Airport, but if you are not familiar with the hardware, get someone who is to help you. The manual offers several tips and procedures to do this http://manuals.info.apple.com/en/AirPortExtremeBaseStationSetupGuide.pdf
Carl
Oct 09, 2008 | Apple AirPort Base Station
Can't get internet connection
Check the following
If your link light on the swich port turn green when you connect the Airport to the switch then the connectivity is okey. if not then try connecting the airport with a crossover cable.
If the link is on, then I need the following information. please draw the connectivity and upload and the switch configuration.
Nov 26, 2007 | Cisco Catalyst 3560-24PS Switch
iHealth Ibaby Monitor For Apple Iphone , Ipod Touch And Ipad - Wh Logo
70 people viewed this question
Top iHealth Computers & Internet Experts
David Payne
David Payne
Are you an iHealth Computer and Internet Expert? Answer questions, earn points and help others
