Question about RCA HD61W66 61" Projection HDTV
I just want to change the setting to have cable on it
    Top Expert:
  • RCA Master
  • 46,272 Answers
Change the input from antenna to cable
Posted on May 02, 2015
How do I change my audio setting
It depends on what you want to change about your audio setting. My cable box remote has two audio settings: one for changing the SAP language sound from English, to Spanish or French; and a setting that changes two separate audio functions: one changes the broadcast sound from Dolby Digital (TM) sound to regular stereo sound, and the other will allow using either a fixed setting (cable box sound level is at a fixed level allowing one to use the sound control on the TV, or other audio receiver), or a variable setting (allowing the use of the cable box to adjust the audio level).
My Sony TV control also allows me to adjust the tv's audio treble, bass, balance, and special effect sounds, and if needed, to turn the tv speakers off. Hope this is helpful..................Gary
Apr 23, 2014 | Sanyo DP26640 LCD TV
Tip
Reset your Wii Video Settings to the Default
One annoying thing about the Nintendo Wii is that there is no way to reset the video settings once you have changed them in the Nintendo Wii System Menu.
It will not detect which cables you are trying to use and just tries to use the last settings that you set it to.
So, if you have changed your Nintendo Wii from using the regular cables that came with the system to using component cables, then switch back to a TV using regular RCA cables (these are the yellow, red and white cables) then you need to reset the settings on your Nintendo Wii to the default video settings.
You can reset your Nintendo Wii video settings to use Composite (or RCA - Yellow, Red and White) cables by doing the following:
1. Make sure the Nintendo Wii is powered off and a red light is showing.
2. With the power off, unplug the video cables from the back of the Nintendo Wii, leave them plugged into your TV (these should be the RCA/Composite cables)
3. Press the Power button on the front of Nintendo Wii. Make sure the cables are still unplugged.
4. Keep the Nintendo Wii powered on and plug your cables back into it with it still running.
5. If all went well, the picture should appear normally now.
6. Once the picture has reappeared, you should go into the Nintendo Wii Menu (the Wii button in the bottom left hand corner) and change the display back to 480i to make the changes permanent.
I hope this tip helps!
on Apr 09, 2010 | Video Game Consoles & Games
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
While on vacation my daughter was house sitting and my home theater set up stopped working. Specifically, with cable to my cable box and HDMI feed to the Yamaha RX-V465 receiver, I get good HD picture on...
If you suspect a setting was changed why are you tampering with the cables?
Get into the manual and go through every setting. Troubleshooting sections usually help. If it's just the Cable Box audio look at IT. Assign the port. If it's ALL audio start with the test tones.
Aug 23, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
Tried using usb to seriel adaptor but unable to read while reading 2way radio software. pretty sure its between the usb/adaptor
make sure that both the cable and the software that you are using are set to same Com ports.
Ex. the cable set to Com4, the software must be set to Com 4
To change the Com ports of the cable you just got to Device Manager under System Properties then on the properties of the serial cable there is an option to change the Com port settings.
To change the Com port setting of the software just simply go to its settings or preferences.
Jun 16, 2009 | Belkin USB/Serial Portable Adapter...
Cannot set screen width
Both the TV and the Cable box have Aspect(height/width) settings. You must confirme the setting on the cable box and then do the TV.
1. Set TV to Native, this should show image exactly as the cable box sends it.
2. change Aspect settings on the cable box until you get one that works
3. if you get a good one, then your OK. You will just need to find a setting between the 2 devices that work for you. Also, these settings may change automatically for the TV or cable box based on the channel
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Hard drive problem
Although I covered most of the ways to speed up Windows boot time in another article, I encountered a unique roadblock recently that made me write this article.
During the last week I was asked by a customer to upgrade one of their office computers from Windows 98SE to Windows XP. Normally this is pretty standard, however because their current hard drive was only a 20GB with a gig or so remaining I wanted to upgrade their hard drive as well.
I proceeded to ghost the drive to a larger hard drive and then installed an upgrade version of Windows XP on top of Windows 98 to preserve all of their settings and programs.
Everything went flawlessly, until I was finished...
After I completed the Windows XP upgrade, I shut down the computer completely and restarted it. The computer took FOREVER to boot into Windows XP. It was literally 2 minutes before I saw the Windows XP logo screen and another 30 seconds more before the desktop appeared. This was definitely a problem.
After checking multiple settings in the BIOS, I compared the old and new hard drives. Everything seemed to be normal, except one. The old hard drive was setup to Cable Select and as my normal routine I had set the new hard drive as a Master drive. I changed the new hard drive to Cable Select, rebooted the computer, and the Windows logo screen came on seconds after the POST screen as before. Therefore, I have to add one more item to my list of ways to make Windows boot faster. Try changing the hard drive from Master to Cable Select, check the boot up speed and switch back to Master if you don't see a change.
Master/Slave Settings
Now for a refresher course on hard drive connections. When connecting more than one hard drive to a computer on the same IDE controller, you generally have to assign one as the primary (master) and one as the secondary (slave). You do this by changing the jumpers on the hard drive next to the power connector. Normally, the drive will have a diagram to let you know which jumper should be set for a master drive and which to set for a slave drive. You'll notice in the picture below the jumpers are circled on the end of the drive and the top of the drive shows the diagram to follow.
After changing the jumpers, connect the hard drive cable from the motherboard to the hard drives. Under normal circumstances, the end of the drive cable attaches to the Master hard drive, while the inside connector on the cable connects to the Slave drive.
What About Cable Select?
Cable Select (CS) settings were designed to make it easier to connect hard drives because you didn't need to bother with setting the Master/Slave jumpers. You just connect the drives and depending on where you connected them to the cable the computer would know which is Master and which is Slave...in theory. Now comes the confusing part.
With cable select, you first needed a special 40 conductor IDE cable that would determine master/slave connections. This was different from the normal IDE cables at the time. Also, the Master connector on CS cables was the inside connector not the end connector. This made for a very confusing switch from everyday master/slave configurations.
80 conductor Ultra DMA cables WILL determine the Master/Slave settings through Cable Select however. So as technology advances, Cable Select as a concept may still catch on. With the newer Ultra DMA cables, you can set both drives to Cable Select (CS), connect them and they will work. Another change with the 80 conductor cables, the Master connector is on the end of the cable where it should be. In situations where you are using a newer Ultra DMA drive and cable, you can use Cable Select or standard Master/Slave jumper settings and the drive will boot properly.
In my scenario to start this article, the change from Master/Slave to Cable Select for this particular computer reduced the Windows boot time by more than 2 minutes.
For more information on Master/Slave settings versus Cable Select visit the following pages:
Mike's Hardware: How to Connect IDE Hard Drives
Configuration using Cable Select
UnixWiz.Net: Using IDE Cable Select
Oct 18, 2008 | Computers & Internet
Ethernet cable port does not worked only the usb port worked
Have you tried changing the lan settings, or better still use the disc that came with modem and it will auto install modem and configure settings.
Jul 27, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Need help changing from antenna to cable without a remote
have cable attached to the TV. But, I lost my remote so I cannot change the TV setting from "antenna" to "cable." There is no menu selection on the TV itself. Is there any way to do this?
Feb 17, 2008 | Daewoo DVN-14F6N 13" TV
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
RCA HD61W66 61" Projection HDTV Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
