Question about Cub Cadet Garden
Where is the oil drain plug located on my Cub Cadet DE 40 edger ?
    Champion:
  • 223 Answers
In your manual
Posted on Jun 02, 2016
  • 48 Answers
SOURCE: I cant start my cub cadet cc989
sounds like a plugged high speed jet
Posted on Oct 24, 2008
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
Engine is smoking on Cub Cadet LE-100 edger. Is it because of old oil, and if so, howdy I empty the old oil?
Sounds like the rings are leaking. Changing oil will help. look on engine crankcase and see if there a screw type plug the bottom of plug should be facing down. Look in yellow pages and find a repair shop and ask them how much to repair. Sometimes it may cheaper to buy new unit
Jul 02, 2017 | Cub Cadet Garden
Location of oil drain plug
If this is the same as my Craftsman, it is very convenient, but sneaky.
There is a hose attached to the side of the engine. To drain the oil, unclip it, open the top, and then lower it indo your dirty oil collector. If it does not have this gizmo, there will be a drain plug near the lower edge of the engine.
Sep 14, 2015 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
How do I change the engine oil on my Cub Cadet DE Lawn Edger ?
yes check either side of the block . possibly under neath too
Apr 20, 2015 | Cub Cadet Garden
Oil drain location on cub cadet rt65
How old is it? Lots of newer small engines don't have a drain plug. You tilt it on its side and let the oil run out the oil filler hole after removing the dip stick. I put a piece of plastic shopping bag over the gas tank hole and put gas cap back on to help keep gas from coming out. Good luck.
Jul 26, 2014 | Cub Cadet RT65E - RT65E 18" 208cc Dual...
I have a cub cadet LT1018 with 800 hrs. The engine, B&S 18.5 hp, started running rough and sputtering while mowing. Disengaged PTO to return to garage - mower died. Cleaned air filter and restarted,...
Sounds like water in your carberator. Remove the bowl and check for dirt and water, drain some gas from the tank into a bowl and check for water in the gas. Remove air filter housing and lubrcate all of the carberator linking with a product such as WD-40. Reassemble everything and start again. While you are at it check the spark plug too.
Oct 20, 2017 | Cub Cadet Garden
What type of oil and how much do you use in the Cub Cadet 1440?
It would take 3 and 1/2 pints of Cub Cadet Engine oil (Recommended):
SAE 30 for temps > 40 degrees Fahrenheit
10W30 for temps 0 - 40 degrees Fahrenheit
5W30 for temps
Sep 27, 2010 | Garden
Unable to serivce or operate cub cadet edgers DE
Hello. go to this link and hopefully you will be able to get what you need
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1
If the manual is not listed call cub cadet and ask them to send you one. Joe
May 05, 2010 | Garden
I have a cub cadet with a kohler command series 16 engine..It runs rough,oil gets on the spark plug and smokes a little what is wrong with it?
This usually means that is's been overfilled with oil, or the engine has been tipped enough for oil to run into the cylinder. Drain oil if it's above the line at all, and the problem will go away once the oil's burned out of the cylinder.
Mar 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
How do i change oil on a cub cadet riding lawnmower
Jul 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
