Question about DKNY Watches
How do I remove the back off my DKNY ladies watch to replace the battery?
  • 29 Answers
SOURCE: Dkny watch- repair, need extra links
I suggest calling DKNY customer service @ 1-800-231-0884 This is their return or repair department they should be able to help with links for your watch.
Posted on Mar 12, 2008
VOTIT
  • 2071 Answers
SOURCE: Replacement battery for DKNY NY1050
I found a "battery" website that had some suggestions that should be typical of any snap back case watch.
http://www.online-batteries.co.uk/whichb...
specifically they said that when you try to press the back on it must be flat (not one edge down as I had been trying) Put the watch face down on a non scratch surface and press with both thumbs evenly. If that doesn't work a press will be needed. If you have a vice a couple of blocks of wood to distribute the load on the front and back may work, otherwise take it to a jeweler with the proper equipment.
The thumb routine didn't work for me. I have a vice but figured many wouldn't so I tried something else first. I put the watch face down on a piece of wood. I found a small 2" long scrap of wood (3/4" x 1.5" approx) that spanned the back. I centered the back (aligned properly) placed the block of wood squarely and centered across the back and tapped the end of the block with a hammer. First try didn't work, second one did. I used a rubber mallet as the hammer but a regular hammer or other heavy object would work. The trick, I think, is to get everything lined up and square so the blow is centered and even.
Also, I'd suggest cleaning the back and the groove in the case and be sure the rubber gasket is properly positioned. This will give you the best chance of retaining the waterproofing. And remember to check that the watch is running before you do this. Some need to be reset (usually with a very small screwdriver or pin) after replacing the battery. There should be a small hole with some printing next to it. You may need a magnifying glass to see/read it.
Hope this may help you;
DON'T FORGET TO RATE:
Posted on Sep 06, 2008
escapement
  • 2334 Answers
SOURCE: replace the back of a dkny watch after replacing the battery,
For closing your caseback you need the man with very strong hands first, but it might not work as some casebacks can be closed using special tools only.
Before you visit the watchmaker, try this: first of all open your bracelet by taking out spring lug. This will make more space at the back. Then take watch caseback and check for groove in it. Align that groove with stem (pin going into watch movement) and deepen grooved caseback side as it should be. Then without turning caseback apply great pressure with both hands to the watch(from caseback and dial sides). If hands are strong enough, caseback should snap on into place.
In case if it doesn't work, find a piece of thick leather (wide mens belt will do) and place it on completely flat surface (table top). Place the watch face down on that leather, adjust caseback groove with stem again and try to press caseback down with both hands, only this time using your weight.
If all mentioned above doesn't work- you have to go to see watchmaker.
Good luck.
Arthur
Posted on Dec 17, 2008
dmbgo
  • 58 Answers
SOURCE: Need screw for watch Style#NY-4285
Hi, you should be able to get one from a watchmaker
Posted on Jun 22, 2009
  • 183 Answers
SOURCE: dkny ladies watch winder lost and watch stopped
DKNY is typically a quartz movement and doesn't have a "winder". I believe the part you are referring to is the crown. The watch may have stopped working for several reasons. The first three things I would suspect is that the battery died, the watch is in the set position, or the movement was damaged when the crown was coming off. If the watch is in the set position then pushing the stem in will cause the watch to run. The next thing to do is to replace the battery since it is only a few bucks. If it runs then you can replace the crown and your set. If it doesn't run I would suggest replacing the movement along with the crown and that you will have to price and see if it is within reason since this type of repair wont be covered under warranty.
Depending on the model of DKNY you may have to go through DKNY for the part. Remember that they are manufactured by Fossil. You could save yourself a lot of time by going to your local watch repair shop.
Thanks!
Posted on Sep 19, 2009
DKNY NY4062 Watch how do l take the back off to replace battery
Take your DKNY watch to a jeweler for a demonstration of how to remove the back without mangling it. You may even be able to persuade the jeweler to install a new battery - all for a reasonable sum.
Mar 27, 2018 | DKNY Watches
L have a DKNY WATCH model no. NY4062 unable to get back off to replace battery can you please help
Take your DKNY watch to a jeweler for a demonstration of the non-destructive way to remove the back. You may even be able to persuade the jeweler to install a replacement battery, all for a reasonable sum.
Mar 25, 2018 | DKNY Watches
What is the battery specifications for DKNY ladies Watch NY3971?
If you look at the movement inside the watch it should be possible to find the movement number (you might need a loupe or magnifying glass to see it clearly) and name (e,g, Seiko-Epson, Miyota etc.)
If you can supply that information I can tell you which battery it requires.
Oct 03, 2016 | DKNY Watches
I am looking for a replacement glass for my DKNY watch, model no: 250109
please see attached website.www.esslinger.com/watch-crystals/
Jul 16, 2016 | DKNY Watches
Hi. Can You replace a Crystal for DKNY ladys watch model NY-4609 Thank You.
It is probably replaceable. Try to locate a watch repair shop or and jeweler who repairs watches. If they don't have one, then contact DKNY directly.
Jan 13, 2011 | DKNY 1035 Wrist Watch
I cannot open rhe back of a 3950 lady watch DKNY
most of this kind of watch can be open by a skilled repair man using a knife, you can try it. but the hard part is not opening it but closing in the cover. it is close by pressing in at the sides of the watch. Better to see a repair man for this.
Dec 13, 2010 | DKNY Modern Edge Lady Watch # NY3901
My dkny ladies watch stops when I take it off. After resetting and putting back on, it works again. Why does it do this?
mcdevito75 here, It"s possible the battery could be so ever slightly loose, or the battery could be weak and need changeing. Also possible, the quartz mechanism could be going bad and movement of the watch while wearing it keeps it going, with the watch off your wrist and at rest, it's just to weak to keep moving on it"s own. Best Bet is to look for a small watch repair shop in your area and have them check out your watch.
Aug 22, 2010 | DKNY Modern Edge Lady Watch # NY3901
Dkny ladies watch winder lost and watch stopped
Thanks!
Sep 19, 2009 | DKNY Watches
Jun 16, 2009 | DKNY NY5045 Watch for Men
Mar 09, 2008 | Watches
Watches Logo
120 people viewed this question
Top DKNY Watches Experts
Ansel Alberto
Ansel Alberto
richie46
Are you a DKNY Watch Expert? Answer questions, earn points and help others
