A/c make humming noise and the impeller at the back of the a/c won't spin. This a window unit 15'000 or 12,000 btu
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Sounds like a motor start up capasator
Posted on Apr 20, 2015
3 Suggested Answers
SOURCE: won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Posted on Nov 11, 2011
  • 643 Answers
SOURCE: water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Posted on Oct 08, 2012
Pump making a buzz noise but won't start up
it sounds like the motor has seized. if not seized, there may be something blocking the impeller. disconnect the power and try to spin the impeller
Sep 10, 2014 | Hayward Pool & Spa
Pump makes humming noise impeller spins slowly
sounds as if pump has stuck start winding switch , try giving Motor not the pump a sharp knock with a rubber mallet when you 1st turn on , this might jar it loose if not a new motor might be needed , if motor was larger then say 2hp then id say get it fixed at a motor repair shop due to cost saving but smaller sizes it's not worth it most times
Nov 23, 2013 | Pentair 1.0 Hp Whisperflo Pump
Frigidaire window air conditioner, new, fan won't run
slide out and spin blade by hand. should be able to tell if anything restricting rotation
May 05, 2013 | Dometic Rooftop RV Air Conditioner
Frigidaire affinity front load washer
If the unit will not spin at all and makes a humming noise, sounds like something has seized up in the back of the unit. This could be a belt broken, motor seized up, or the transmission, if your unit has one, is gone.
Jul 17, 2012 | Frigidaire ATF6000ES Front Load Washer
My saniflo macerator plus has stopped working-it had been making a humming noise not draining-now it's not making a noise at all-what might be wrong please?
It could be a blockage in the blade, impeller or the discharge line. Also could be a defective starting capacitor, since the capacitor spins the blade and impeller, if the capacitor goes bad it will make the unit hum and not pump out the waste until eventually it shuts off completely and would not kick on and off at all. At this point, the capacitor may have to be replaced. You should contact Saniflo to order parts.
Aug 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Saniflo permanently on,
If the blade and impeller spin freely by hand after removing the obstruction but does not pump out the waste after assembling the unit back together, then could be a bad capacitor, since the capacitor spins the blade and impeller. If the capacitor goes bad then it will just make a humming noise and not pump the waste out.
May 20, 2010 | Saniflo & Saniplus& Macerator Pump
Maytag Neptune purchased brand new in 2007. Tumbler won't spin and water doesn't get pumped out, all I head is a humming noise coming from the water pump. I opened the back and could feel the water pump...
There is something jamming the impellers in the pump (coin, nail, bobby pin, ect.) You need to manually get the water out, remove the pump, and see if you can find and remove the obstruction. If you find something in the pump and remove it, check the impellers before you put the pump back in. There are 3 plastic impellers, make sure none of them broke off. If they did not break off, your good to go. If one or more broke off, you will need to replace the pump, you cannot buy just the impellers. good luck.
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
There is a noise (hum) when the spin is set. No spin.
probably pump plugged if that is a front load remove bottom panel pump has a clean out port clean thoroughly and retry is still only hum pump impeller may be jammed or damaged ..removing pump will allow better acess to impeller area
Aug 22, 2008 | Whirlpool Washing Machines
Kenmore Window unit 15,100 btu, Model 25372156200
with the hum noise sounds like you have a bad fan motor
May 26, 2008 | Maytag M7Y15F2A Air Conditioner
Washing Machines Logo
Top Washing Machines Experts
