Question about Maytag Dryers
My Maytag electric dryer medc400vwd runs for a short time and shuts off. I all ready replaced the thermistor and thermo cutoff. Still shutting off
  • Maytag Master
  • 2,159 Answers
Are you sure you have great airflow all the way thru the venting??
Posted on Apr 21, 2015
  • 27 Answers
SOURCE: Electric Dryer problem
the timer has a small motor to advance the timer. the motor is the likely problem. on some old maytags you can get just the motor, but you probably will have to replace the complete timer. hope this helps.
Posted on Nov 02, 2007
watugot
  • 290 Answers
SOURCE: Trouble with Maytag Legacy gas Dryer
Please provide the model number and I will see if I can figure something out.
It sounds like you have covered the common problems. Usually a motor is the cause for this problem, it gets hot and shuts down until it cools off. I have had some problems with the auto dry controls on the Maytags also.
Are you equiped to do some voltage checks if we need too? This would help in knowing where you have power when it quits.
Thanks/Mike
Posted on Dec 12, 2007
SOURCE: Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Posted on Jul 13, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
  • 351 Answers
SOURCE: no heat
Hello, Im Mark and im highly trained in whirlpool dryer repair. Here is my Site. Whirlpool Dryer Parts. Anyways i would need to know what model your whirlpool dryer is, and the model number. Then from there it is a breeze. Simply give us a call and we can have you up in no time.
Mark
Posted on Apr 14, 2009
I have a maytag Neptune dryer mdg9700aww and its throwing a code 02 and 03 and 10. Can you please help.
O2 is a not heating error. Unplug the dryer and check the heating system components. For an electric dryer, check the house circuit breakers to see if one has tripped. For a gas dryer, make sure that the gas supply cut-off valve is fully open.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Mar 09, 2015 | Maytag Dryers
Can someone help on a Maytag Neptune dryer MDG6800aw not heating up?I've changed the ignitor and it runs but after around 10-15 minutes I hear a grind like a stuck switch and the dryer is not heating up....
Mar 07, 2015 | Maytag Dryers
My Maytag bravo Dryer is not drying my clothes correctly. The timer on the dryer keeps going up higher indicting it needs more time to dry?
Oct 13, 2014 | Dryers
My maytag centennial electric dryer will not heat the model # is medc499vwo I need know if u have a video that shows me how and also if its the heating element or what?
Oct 04, 2014 | Dryers
Kenmore elite quietpak 9 he4 cuts off after drying clothes for a while. clothes are still damp
GOD IS STILL GOOD !!!!
Sep 27, 2014 | Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Why won't my inglis dryer heat up
if electric? check ur thermal shut off and thermistor with a multimeter. does it run at all? if it does it wont be thermal shut off but may be ur heating element? is it gas or electric? Gas? 1. may need to check ur coils which regulate the flow of gas, ? 2. CHECK Igniter which ignites the flame, or 3. CHECK THE glow bar. there are also thermostats on the heating eleemt you will want to check with a multimeter. the thermal cutoff, the hi-lo thermostat and the element itself.
Aug 16, 2014 | Whirlpool Inglis IP8200 Dryer
Maytag dryer MDET446AYW shuts off after a minute or so
Does it come back on right away when you start it again? or do you have to wait. If it starts, stops, starts, excetera..if so you will need to replace the control board. Part Number: AP4046791 made by WHIRLPOOL. Now it is not a cheap part, but most have a 30 day moneyback. The slight chance of a broken element shorting, causing the thermistor to over heat, cool down and run for a short time. is also a possible issue. But for the Maytags I have worked on in this model, most of the time it has been the control board. I am hoping it is the element issue for finace purposes. It is a good dryer unit, I own one. : )
Dec 29, 2011 | Maytag Dryers
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Neptune Dryer
My maytag neptune dryer quit heating, after my wife changed the temp setting on the console from regular, to extra low drying temperature. The heating element reads 10.5 ohms. The thermal cutoff reads 0.02 ohms. The hi-limit thermo reads 0.02 ohms. The power coming into the dryer is 240 volts. What can I check or need to replace.
Dec 05, 2006 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
57 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
